Question about Kenmore 21.7 cu. ft. Top Freezer Refrigerator w/Acceler-Ice & Internal Water Dispenser
The two lights are on refrigerator donot work
The other day I opened the refrigerator door and the two lights blew out when I opened the door. I replaced them with new light bulbs but they donot work. How can I fix this problem?
    President:
  • Kenmore Master
  • 2,651 Answers
Id be curious as to if there is a control board locatd on the sidewall next to the compressor, behind the refrig. usually encased in awhite housine mounted directly to the cabinet, ifso I'd open that boxup andlook for a burn mark, that s the culprit for no interior lights in refrig
Posted on Mar 12, 2009
Light bulb burned out
Did you have a hinge kit recently replaced? If so call them back they missed something. If not, look into the light circuit a if it goes to ground this light issue would happen. Most of these issues I found in the upper section behind the upper grills. I hope this helps
Dec 25, 2013 | Viking Professional VCBB363SS Stainless...
My light blew out I changed the bulb but it is still not working
I suppose you should have checked that bad bulb and the new bulb in a working table lamp. If they work there then the door switch for the light may be defective or a connection has opened in the supply voltage. 90 percent of electrical problems are not shorts -but opens.. OPPS! something is missing. The voltage is not getting there
Jan 28, 2011 | Refrigerators
I donot have a problem but my son is bringing me a filter from the US. What is the filter 3 please
Hello and Welcome to FixYa!
Actually the filter is used to provide clean, fresh tasting water and ice specially designed for the side by side refrigerators manufactured by SAMSUNG. The filter is replaced after 3-6 months depending on the use. There is a indicator light installed on the display that reminds you the time to replace the water filter. For detailed information you can visit the below quoted link: Click Here
Have a nice day,
Please do Rate the solution, if this helps you,
Concerned.
Aug 11, 2010 | Samsung 24.6 Cu. Ft. 4-Door Side-by-Side...
Inside top of refrigerator hot light don't turn off.
There is a service bulletin related to this, dealing with deformation / melting of the lamp cover. The fix is to change the lamp wire harness to one that now has a thermal protector incorporated in it (part number 6621JK2003B) along with changing the main PCB board to one that uses a larger relay for this function (part number 6871JB1423N).
In case you want or need to replace the following,
The lamp cover is part number 3110JA1096A and the lamp holder is part number 3034JA1009A
I tried to cut and paste a few photo's, but was unsuccessful. Sorry. Make sure to test that fans and light switches work after part changes.
Apr 11, 2009 | LG LFC21760 Bottom Freezer French Door...
No power to control unit in fridge
Turns out we had a bad control board. One of the coponets was blown and it had to be replaced. $400.00 and its good as new.
Dec 16, 2008 | Whirlpool 25.6 cu. ft. Side-by-Side...
KSRS22FGWHO4 INTERIOR LIGHT LOCATION
As I mentioned previously, I had previously tried a new bulb behind the control panel and it didn't work. I tried again, but first I unplugged the refrigerator, and then installed the new bulb. And when I plugged the refrigerator back in, the light worked!
I am not sure why unplugging the refrigerator before installing the new bulb worked, but it did.
Darrell
Sep 11, 2008 | KitchenAid (KSRD22FKST) Side by Side...
Grill, top oven and all lights not working after grill element blows
Brinkmann has a terrible customer service dept. You are better off with a new unit.
Jul 30, 2008 | Grilling
INSIDE LIGHT
I'd say the door switch is bad. Jiggle it. Spray some WD40 into it. But ultimately, remove it and test it for continuity. If there is no continuity in the door-open position, replace it.
But be careful. Some refrigerators have a second door switch with opposite function. It turns the fan OFF when the door is opened.
Jun 05, 2008 | Candy CPCA270FFK Bottom Freezer...
Refrigerators Logo
73 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
acrman404a
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
