Frigidaire dryer model glgq2152eso have error code of re5 or s dryer will spin but noheat basemnt had 8 in of water
2 Suggested Answers
SOURCE: Frigidaire Affinity dryer error code?
HELLO,
I HAVE A FRIGIDAIRE AFFINITY DRYER (AEQ6000CE32). WHENEVER I PUT THE CLOTHES IN IT JUST SPINS FOR 10 TO 15 MINUTES AND SHUTS OFF BEFORE THE ALLOTTED TIME. THERE IS NO HEAT IN THE DRYER. ANY SLOUTIONS?
Posted on Sep 26, 2009
Error Code re5, dryer runs but no heat.
Good Afternoon Henry, thank you for your post!
I see that your Frigidaire dryer is displaying an error code of "re5" and will not heat. I have researched our available information for dryer and without having the model number the error code appears to be invalid. I would recommend performing a reset on your dryer and you can do that by unplugging the power cord for roughly ten minutes. If you restore power and continue to receive the error code can you please comment back with the model number? You can locate the serial tag (which lists your model number) on the door frame of your dryer. With that information I would be happy to assist you further. -Matt
Feb 22, 2016 | Frigidaire Dryers
My frigidaire infinity dryer after 5 minute the cycle stop.
ADD= automatic dry detector this would explain why it stops after 5 min , must be a fault with that
ive had to clean them off inside the drum many times with glass cleaner (nothing stinky) or it will transfer to clothes
mounted just under the lint trap is two shiny steel bars , or some models it's in the back near the center softener sheets come off and coat them up
Apr 21, 2015 | Frigidaire Dryers
Dryer will not run
Hi Carolyn - Error code RES commonly refers to RESUME. Let's trying pressing the RESUME button or START on your dryer. If it proves ineffective, let's reprogram the unit by either unplugging it or flipping the household circuit breaker to the off position. It is important to wait roughly ten minutes and then turn the appliance back on. Once you select an option, the unit should resume to normal operations. However, if the issue persists then the dryer may possibly be experiencing a communication error with the control board or a potential wiring failure. In this regard, I would suggest contacting an Authorized Service Technician that will be able to assist you in the diagnosis of your appliance.
Jul 12, 2013 | Frigidaire Affinity 5.8 Cu. Ft. Electric...
Frigidaire gas dryer, gallery series model GLGQ2152ESO - no heat,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Jul 27, 2010 | Frigidaire Gallery Series GLHS269ZDB 36"...
PLEASE HELP! Dryer cuts off and gives an E68 code.
e68 code
this is a fault code that means there is a stuck key on the board you may have to remove the control panel and check the keys if this does not work you may have to replace the panel or control board
Good luck
Oct 05, 2009 | Frigidaire Dryers
Frigidaire affinity dryer problem
the thermistor in air outlet duct is very common for these. with front panel off find plastic duct from blower at bottom. pull out thermistor and look at inner side. it has triangular shape and if you can see shiny redish color at tip instead of all black then its worn. this causes numerous heat and control issues.
Mar 29, 2009 | Frigidaire AEQ6000ES Electric Dryer
Frigadaire front loader washer
Frigidaire, Zanussi, AEG, & More....
EFO = Filter Blocked (low flow) and it is accessible from the bottom front of the machine.
1. there is a blockage in the filter or drain hose.takes too long to drain out.
2. over dosing of powder or liquid. again can cause an air lock in the pump which slows the drain pump down.
Check the filter and drain hose and test again. this fault will only come up at the end of a cycle.
You do not need to reset the machine to get rid of the fault code as this is automatically deleted.
Run an empty load with no detergent in an attempt to get rid of the code.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!!!!
Nov 03, 2008 | Frigidaire GLEQ2152ES Electric Dryer
message "ad" showing on my affinity frigidaire, anything wrong with this?
Apr 01, 2008 | Dryers
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
