Question about Pool & Spa
Change power cord on SP1515 - Pool & Spa
I changed a three prong power cord to a four prong cord now it will not heat
Hi Grady, The link below is a short youtube video on how to change a 3 prong power cord to a 4 prong power cord... I hope it helps.... CHEERS..
https://www.youtube.com/watch?v=np5o1Zi6Gc4
Mar 30, 2016 | Maytag Dryers
No power to printer. changed power cord to new.
Is better to buy a new one because it will be very expensive.
Jan 14, 2015 | Canon PIXMA Office Equipment & Supplies
I have a hayward power flo matrix 1081 sp1515-z-1-esc pump.
if you have indications of a motor problem, you shouldnt need to disconnect it to diagnose. if your pump is higher than the level of the pool, there should be unions both at the front and top so that it will disconnect from the system quickly and water loss is minimal. if your pump is below the level of the pool, there should be valves to stop water flow as well as the unions to remove it from the system. plan B is to describe what you hear\see and let a pro point you in the right direction.
Jun 17, 2014 | Hayward 2HP Pool Pump Motor A O Smith...
I have a Hayward Power-Flo LX SP1515-Z2-EBK3 that is being used to pump water through 2-4x8 solar water heater panels. The pump intake is 1 1/2 inch, discharge out is also 1 1/2 inch. The pump is located...
I have a 3/4 hp hayward pumping thru solar panels, too. 1-1/2 discharge thru 50 ft of 2inch pipe, up 12 ft then thru (4) 4x12 panels. Mine is on 115 volts ac.
You have plenty of pump and when you run a pump with low flow, amperage is low. You are not tripping your breakers, it sounds like the pump is overheating. Is it hot to the touch when it shuts down?
Do you have an ammeter so you could check your amps?
What size wire is running the 60 ft to the pump?
I don't have any other ideas to share.
Gary
Sep 06, 2011 | Hayward Power Flo Lx
All I want to do is find a replacement switch for my 1.5 hp pump motor. It is a hayward power-flo matrix, sp1515-z-1-esc
Please post the model and serial number from the motor. The number you have is the part number Hayward assigned to the AOSmith motor on your pump. I'll need AOSmith's info to get you pricing on the correct switch. Do you need the stationary only or the stationary and govenor?
John
Oct 19, 2010 | Hayward 2HP Pool Pump Motor A O Smith...
Sony vaio pcv 2244 wont turn on. after a while it will attempt to turn on but no luck.
This is power problem, i advice you change the outlet you are trying to plug your printer to see if it will power up, it that did not solve the problem, then you will need to change the power cord to that printer because it could be that the power cord is malfunctioning and not supplying full current to power the printer, so i suggest you change the printer power cord to test another power and see if it will power up.
Take care.
Jun 01, 2010 | Office Equipment & Supplies
Too many prongs on dryer power cord???
Do not just swap out the cord on the dryer. It has 4 prongs for a reason.
You will need to call a licensed electrician to change your outlet for the different service.
Jun 17, 2009 | Whirlpool Dryers
Changed from 3 prong to 4 prong power cord ,now theres no power.
Please review the following link:
http://www.fixya.com/support/r793520-3_prong_4_prong_power_cord_conversion
Do you have your power cord wired correctly? Please read through the link thoroughly and confirm the wire color coding and the placement of where you have the wires terminated. I hope this helps you. Let me know if you have further questions.
Jan 04, 2009 | Estate EED4300SQ Dryer
Pool & Spa Logo
15 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
