Question about KitchenAid Superba KSRG25FK Side by Side Refrigerator
Kitchen aid refrigerator KSRA251 - KitchenAid Superba KSRG25FK Side by Side Refrigerator
SOURCE: kitchen aid superba side by side refrigerator
I slid our unit out tonight and took off the cardboard cover and vacuumed the back area out.  If you do this unplug the unit. I didn't see the spinning fan blades next to the compressor until after the vacuum nozzle touched them.
I then took off the front cover down by the water filter.  We have 2 long hair cats. 5 years of fur had collected and was preventing air from circulating out the front of the unit. I vacuumed out the fur.  I then took a short flexible rubber tube and hooked it to the vacuum and got as much fur and dust off the coils underneath the fridge box.
Once I had everything put back together and plugged back in the frame cooled down and I think we are OK.  My guess is the hot air could not escape so it was gradually heating up the frame.
Good luck.
Posted on Aug 20, 2008
Sea Breeze
  • 4655 Answers
SOURCE: Kitchen Aid Refer: KSSC42FMS01: The freezer, doesn't go below 32
How long have you had this refrigerator and is this the first time this has happened? Your refrigerator has a control board and I believe the board is causing the refrigerator not to defrost every 8 hours. Let me know these questions and I will help you resolve this. Thanks, Sea Breeze
Posted on Mar 19, 2009
Sea Breeze
  • 4655 Answers
SOURCE: kitchen aid refrigerator freezing in refrigerator
Could you look inside the door near bottom outside frame of fresh food side and get the model numbers for me to assist you better. Also if you have a way to check the temperature as you change settings on the thermostat for the fresh food section. We need to see how the thermostat responds to changes in settings. If no changes then we need to focus on the thermostat. Also there is duct that comes from freezer that can have a damper opened or close to different settings. Let me know the model and I will pull up the drawings for your model. Thanks Sea Breeze
Posted on Mar 20, 2009
  • 41 Answers
SOURCE: my kitchen aid refrigerator model KSB251NBL..NO ICE
Problem could be a couple of things.One There is a little control in the very back,its should be on the lower right side looking at the freg. from the back.It has a water line running up to the ice maker.If that is ok,you will need to replace the ice maker.It is not a big problem on either.Cost is for the little controll about $30.For the ice maker about &90.
Posted on Aug 29, 2009
SOURCE: kitchen aid top shelf warm
  1. check gasket
  2. check the light switch on top of the refrig. section. If then pushed the switch turns the light off, but the light is still on with the fridge door closed - door needs adjustment.
Posted on Oct 14, 2009
My kitchen aid refrigerator won't stop buzzing
If everything is cooling right, take the front grille off at the bottom of the fridge and move the plastic drip tray. It might be touching the motor or pipe, causing the noise.
Jan 28, 2015 | KitchenAid Kitchen Aid - KSC23C8EYY...
Is the filter behind the kick plate on the Kitchen Aid Superba made in 1998?
Hi, the filter should be on the bottom kick plate and should have a cap of the same color as the kick plate.
Hope this helps
May 23, 2014 | KitchenAid Superba Architect KSCS25INSS...
Kitchenaid superba ksrg25fkwh01 wire harness
Called Kitchen aid and protested, frig was 4 years old at the time. door was almost $1200 to replace. Kitchen aid paid for new door and installation
Sep 19, 2012 | KitchenAid Superba Architect KSCS25INSS...
I have a Kitchen Aid Md# KBLA20ERSS The
Lack of airflow up to the refrigerator. could be a defrost problem, a fan motor not running, a damper staying closed, a food obstruction, or something else altogether.
May 09, 2010 | KitchenAid (KBLA22ER) Bottom Freezer...
I have a kitchen aid refrigerator freezer. The
the supply line of the ice maker might be blocked please check it.
Aug 18, 2009 | Refrigerators
Kitchen Aid KSRP25F Ice Maker
The ice maker is not working, no ice ice is coming in the tray on my Kitchen Aid KSRP25F Refridgerator, the red light keeps on
blinking
Del
Dec 05, 2008 | KitchenAid Superba Architect KSCS25INSS...
Agitator will not work
kitchen aid is hte same as the whirlpool so if you have directions for that one it will work on your current one,, part number 80040
Oct 23, 2008 | KitchenAid Superba Architect KSCS25INSS...
KitchenAid Superba  KSRG25FK Side by Side Refrigerator Logo
52 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
geob91
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
