Question about Hadco TC151-12TP Accessory Transformer
Where is reset button on hadco transformer - Hadco TC151-12TP Accessory Transformer
We have a Malibu 300 low wattage transformer for 13- 20 watt landscape lights.
Try connecting a lamp (correct voltage, etc) directly to the transformer. Most likely, the wire from the transformer to your lights is broken... The reset button can't reset anything, if there's nothing wrong there.
Jun 16, 2016 | Intermatic Malibu 300W Power Pack...
Vmos200 microwave-set microwave timer goes down no power but when open switch is pushed in a little bit it works holding it in slightly
On these, this is usually due to a failing bottom door switch, or its mount. Sometimes the door can also get misaligned due to slamming.
See my help file on door switches here.
The Viking VMOS200 is essentially just a rebranded Sharp R-530E-series oven. The R-530E service manual is here and it's helpful in working on your unit.
All the internal parts will be the same, but outer parts are cosmetically different.
You can order Sharp parts from Encompass here or you can call them toll-free at 866-779-5835.
Viking Customer Support is at 888-845-4641.
For Viking parts, on the West Coast call 1-800-488-9868. Otherwise call Hadco at 800-241-9152 or see http://www.hadco.net.
Aug 27, 2012 | Viking VMOS200 Microwave Oven
Using Lowes mechanical timer in Hadco TC654-15 landscape lighting transformer. Have tried 3 timers now and timer clock does not work when plugged into the transformer. if I bypass the timer, low voltage...
Always a good idea to check outlet with cheap circuit analyzer.
And move timer to different outlet to see if difficulties are outlet-specific.
Try timer at neighbor's house.
Having 3 defects in a row is unusual.
There are no repairs for defective timers.
Timer clock motors stop working for many reasons, bad manufacturing of plastic gears and power surge and dirt and reversed polarity among the causes.
Using household plug-in timer is typical solution since clock modules are not sold separately.
Following link gives tips for having low-voltage power pack last longer, in case you decide to buy Intermatic-Malibu from Home Depot:
http://waterheatertimer.org/Malibu-power-pack-stopped-working.html
Aug 31, 2011 | Hadco TC151-12TP Accessory Transformer
I have a hadco timer that needs to be reset....where can I learn how to do this?
Hadco T6 looks like Kitchler 15558WH
http://waterheatertimer.org/pdf/Kitchler-15558WH-timer.pdf
There are several brands of timer that look same-similar:
Open following link for images and manuals:
http://waterheatertimer.org/Woods-timers-and-manuals.html#59377
Add a comment and say which manual matches Hadco timer.
Jun 15, 2011 | Hadco Digital Timer Model T6
How do I get a manual for the use of a Hadco T5 analog timer?
Follow the below link to the Philips HADCO website where you can download the instruction sheet. I would have attached but was unable to do so.
Thanks !
http://hadco.com/Hadco/Public/ProductDetail.aspx?pid=280&s=t6
Nov 20, 2010 | Garden
We are adding a light and need to know how to put in this wire into the transformer box? We do not have the box or instructions for our Hadco Landscape Transformer 30600. A diagram and instructions would...
Could not find that exact transformer number, but if you go to this URL you will see transformers that are most likely similar to yours or you can contact Hadco/Phillips.
http://www.hadco.com/Hadco/Public/SearchVisual.aspx?FamId=24
As long as you are using the proper voltage bulb, you should not have a lot of difficulty hooking it up.
Feel free to contact me in the event you run into problems.
Sep 14, 2010 | Garden
I Need to locate the laptop reset button on it
to reset most labtops all you have to do is hold down the power button for about 15 seconds and it should reset
Mar 25, 2009 | Dell Inspiron 1000 Notebook
Hadco TC151-12TP Accessory Transformer Logo
Top Hadco Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you a Hadco Hardware and Accessory Expert? Answer questions, earn points and help others
