Question about Craftsman 6.75 Gross Torque ft/lbs. Log Splitter, Briggs & Stratton
Oil capacity craftsman 917.370410
Engine oil capacity
2 Suggested Answers
  • 1383 Answers
SOURCE: Oil capacity for craftsman air compressor circa 1978 model #106..
I have a 2hp craftsman air compessor with a two cylinder pump, Here is the info from my manual as far as oil capacitity:
Remove oil fill plug and slowly add
a compressor oil until it is even with the
top of the oil fill hole. NOTE: Do not
allow oil to be lower than 3/8"
from the top at any time. When filling
the crankcase, the oil flows very slowly
into the pump. If the oil is added too
quickly, it will overflow and appear to
be full. NOTE: Crankcase oil capacity is
approximately 16 fluid ounces.
I buy my compessor oil from Lowes in the tool department. It comes in 16oz and sells for about $3. I wouldnt worry about how many ounces it holds but rather that the oil level is to top of filler hole. Lowes also sells a synthetic oil for about $7 and is recommended for severe conditions (hot / cold / used all day). Good Luck!
Posted on Apr 26, 2009
How much oil in a 2012 fat boy low ?
2013 Softail
a. Use 3.5 quarts (3.31 liters) of engine oil for a wet
capacity refill.
b. Use 4.0 quarts (3.79 liters) for a dry capacity refill.
NOTE
Use wet capacity values for engines that have just had
the oil drained. Use dry capacity values for engines that
have been disassembled, cleaned in solvent and dried.
2013 DYNA
a. Use 2.5 qt (2.4 L) of engine oil for a wet capacity refill.
b. Use 3.0 qt (2.7 L) for a dry capacity refill.
2013 Touring
Initially add 3.0 quarts (2.8 liters) of engine oil
2013 VRSC
Oil capacity with filter 5.0 qt 4.7 L
2013 SPORTSTER
Oil tank with filter 2.8 qt 2.6 L 2.8 qt 2.6 L 2.8 qt 2.6 L
Sep 04, 2014 | Motorcycles
I changed the oil on my sears riding mower and it run fine for over an hour and then started smoking real bad.
What weight of motor oil did you put into the tractor? And how much? The capacity of the crankcase is 1.7L (1.75 qt.). The recommended engine oil is SAE 30. If you put a 10W-30 product into the engine and operated it under heavy load or heat conditions, the oil may not be capable of providing sufficient lubrication.
Aug 05, 2014 | Craftsman Garden
17ARCACK099 manual
here is link for owners manual
http://www.managemylife.com/mmh/pd_download/lis_pdf/OWNM/L0709180.pdf
oil capacity is in the engine manual. Get model # off of the engine tag and look that up for your engine oil capacity.
Jul 11, 2014 | Craftsman Garden
What would cause a craftsman mower not to have enough power to start #917272672
Low compression most likely. Try changing the spark plug and change the oil. Sometimes the mower won't start if the oil level is too low. If that doesn't correct the problem, then you need to either rebuild the engine or replace it.
May 19, 2014 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Fuel mix for 25cc trimmer
For two stroke engines of this capacity the ratio of fuel to two stroke oil is (25:1) 25 fuel to 1 (two stroke) oil. Eg 200 ml of two stroke oil to 5 litres of fuel.
Jan 27, 2012 | Craftsman 25cc Gas Line Trimmer
I need a manual for the Craftsman Walk behind mower #917.388930. The main thing I need to know is when changing oil what is the capacity? SAE 30 non detergent I assume. Thank you.
No, you do not use non detergent oil. You must use only SAE high quality detergent oil with API service classification SG-SL . Use SAE 30 weight or 5W30 if you use the mower during cool conditions below freezing. I highly recommend you use Synthetic oil in this air cooled engine and change your oil once each year. The oil capacity is 20 ounces. You can see the owner's manual at this link. Just click Manual Location and put in the captcha and click submit. No need to sign in or register. http://www.hammerwall.com/Manuals/Craftsman/Description/917.388930/Craftsman%20Walk%20Behind%20Lawn%20Mower%206%20HP%2021%20Inch%20Rear%20Discharge/L0605486/
Jun 27, 2011 | Craftsman Garden
Apr 25, 2009 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Craftsman II mowre oil capacity and filter type
The outstanding Briggs opposed twin engines have an oil capacity of 1.5 qts. The recommended oil is 10w30 full synthetic and 50 hour change intervals. Some engines were equipped with an oil filter, if so, the capacity is 1.7 qts. fantastic engines, take care of it.
Mar 28, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Craftsman 6.75 Gross Torque ft/lbs. Log Splitter, Briggs & Stratton Logo
43 people viewed this question
Top Craftsman Heavy Machinery Experts
Matt Olenzek
Matt Olenzek
Tom Chichester
ray gallant
Are you a Craftsman Heavy Machinery Expert? Answer questions, earn points and help others
