The "loading0S" message on your Vingcard terminal handheld screen means that the terminal is still loading the operating system. This message can appear for a few seconds or for several minutes, depending on the speed of the terminal and the size of the operating system. If the message is still there after several minutes, you may need to contact Vingcard support for assistance.
Here are some possible reasons why the "loading0S" message might be appearing on your Vingcard terminal handheld screen:
- The terminal may not have been properly initialized.
- The operating system may be corrupt.
- The terminal may be low on memory.
- There may be a problem with the terminal's hardware.
If you have tried restarting the terminal and the "loading0S" message is still there, you should contact Vingcard support for assistance. They will be able to help you troubleshoot the problem and determine the best course of action.
Here are some troubleshooting steps you can try before contacting Vingcard support:
- Restart the terminal.
- Check the terminal's power supply.
- Make sure that the terminal is connected to a network.
- Try updating the terminal's firmware.
If you have tried these steps and the "loading0S" message is still there, you should contact Vingcard support.
