Question about LG WD-1280FHD Front Load Washer
Water leaking after i have installed a new drain pump in LG
I have installed new drain pump and the water is leaking it is LG front loading washer what should i do
    Genius:
  • 1,066 Answers
Obviously you need to find the leak and repair it...duh
Posted on Mar 12, 2009
LG WM2075CW seems to leak AFTER a load is finished. Wtare found front left under washer and also in the drawers of the pedestal. Anyones best guess?
(1) If the washer is leaking water the drain pump might have a hole or crack. Or, the bearings might be worn out. Replace the drain pump if it is leaking water, they're not repairable.
(2) Check the tub seal for tears or cracks.
(3) Check the door boot seal for condition.
(4) Also check the tub-to-pump drain hose for cracks or tears.
(5) Lastly, check the drain hose for condition.
Replace whichever offending part that is found to be defective.
Mar 01, 2015 | LG Washing Machines
My LG WM2455 has water leaking from lower front near the front access door. I have checked the catch basin and drained the tube but still get leakage after the next load. What could the problem be?
Check the condition of the drain hose that connects the tub to the pump.
Aug 25, 2014 | LG WM2455 Front Load Washer
Why is the water running out of the lint filter on front loading washing machine
Check also the condition of the hoses and clamps going to and from the pump and the filter rubber seal.
Jun 17, 2014 | LG WM0642H Front Load
LG WM2140C front load washer overflows during drain cycle
This sound like the water is leaking from the drain pump.
Dec 22, 2012 | Washing Machines
I have an LG washer front load WM2032HW. It won't
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 26, 2011 | LG WM2042 Front Load Washer
LG front load washer has a drain error message
Clean out the filter behind the small access door on the front lower left side of the machine. The small hose is there to drain the water out first. If there is nothing in the filter, you may need a new pump motor. (pump impeller comes off shaft sometimes, requiring pump motor replacement)
May 07, 2010 | LG WM-2277HW Front Load Washer
My LG front loader is washer leaking water.
Could be the bladder from the drum to the door of the door seal. It could also be the drain pump hose.
Sep 13, 2009 | LG Washing Machines
LG steam washer leaks a small amount of water from underneath the washer between loads.
Hello.
Welcome to Fixya.
  • Inspect the water supply connections.
  • Inspect the drain hose.
  • Inspect the Water Pump.
  • Inspect outer tub for cracks or corrosion.
  • Inspect the tub seal.
  • Inspect the tub bearing.
Good Luck.
May 05, 2009 | LG WM2487H Front Load Washer
LG WD-1280FHD Front Load Washer Logo
294 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
