Question about Home Security
Where can I buy a wecla coded garage door opener model no 203004 can you help please.
This is a wickes wecla garage door coded opener fitted to outside of garage door frame. Model no 203004.
glenmann62
  • 91 Answers
SOURCE: Resetting a keypad for a garage door opener.
simple , i was a sears installer for 10 years installing garage door openers so your in luck , just locate the smart button on the machine ,it would be on the back or if your looking from the back at the back ,it could also be on the right side depending on if the machine is a sideways mounted machine or frontmount, after locating this button which maybe green/orange /or purple in color also depending on your model ,the newest sears machines are purple buttons ,and 5 years ago they were orange and the older ones would be green ,...ok so after you,ve located it just push it once and you will see a solid yellow indicator light come on , now go over to the keypad and put your 4 digit personal code in after that press the enter button AND HOLD IT for around 3 seconds , at that time you will see the lightbulbs on the machine go off and then click back on , and THAT,S IT! plain and simple , now go proramm your remote! hope i was of help to you , and if i was leave me a nice rating Sincerely Glenn mayer
Posted on Mar 07, 2009
SOURCE: Remotes don't work
I recently had Verizon FIOS equipment installed in my garage (for phone, internet and TV), which is plugged into a 110 volt electrical outlet. Thinking this equipment might be causing some RF interference, I unplugged the FIOS equipment, and both garage door openers immediately worked perfectly again!
After reconnecting the FIOS equipment, I then plugged the garage door opener into a different electrical outlet approximately 15 ft. away via an extension cord, and the openers continue to work fine. Fingers crossed, I hope the issue is permanently resolved.
Posted on Aug 08, 2008
  • 3197 Answers
SOURCE: I have LiftMaster garage door model 41A3039 and
To program the keypad, first unplug the garage door opener from the electrical outlet. Next remove the nameplate from the console that the keypad plugs into and locate the program/operate switch. Flip the switch to program. Next enter your desired four-digit PIN number into the keypad. Slide the switch back to operate and plug the garage door opener back in. The keypad should be programmed.
Posted on Jul 13, 2009
  • 3197 Answers
SOURCE: Sears Craftman Garage door opener model # 41A3493-1
That isn't the model number you give it is the part number for the logic board. The model number is on the opposite end of the motor unit and starts with 139. If you are asking if the opener should reverse when it hits an obstacle the answer is yes. If it doesn't it is not adjusted correctly or is faulty.
Posted on Dec 01, 2009
blanchettohd
  • 143 Answers
SOURCE: I have a Merlin Powerlift-Model 2500L Garage door ...
This is a foreign design but here is what the instructions say to do.
Remove the light cover then remove the colored plastic rectangle strip located underneath. This will reveal a red Learn/Delete? button. 1. Push Learn/Delete button for 2 seconds the lamp will blink continuously to alert you that it is in Learn Mode. 2. Push the big button on your remote for 2 seconds 3.Push the little button on your remote for 2 seconds Minimum of 1 second is required between each action Your remote will now operate with your motor b) Overhead Doors Remove the coloured plastic rectangular strip located next to the Merlin label on the front of the motor. This will reveal a red Learn/Delete button. 1. Push Learn/Delete button for 2 seconds the lamp will blink continuously to alert you that it is in Learn Mode 2. Push the big button on your remote for 2 seconds 3. Push the little button on your remote for 2 seconds *Minimum of 1 second is required between each action Your remote will now operate your unit. Thanks BB
Posted on Sep 03, 2010
Can not activate garage door with Skylink Model G5MC; my
The mirror damaged the sensor while getting out of garage , first repair miror and then change the sensor pad on side of garage door .
Dec 25, 2013 | OEM REPLACEMENT MIRRORS - KAWASAKI FITS...
I've got an old wickes garage door opener, we've just moved in and no remote supplied. I want to wire a push button open/close inside the garage to test and make sure the motor system works before I buy a...
You can also get remote units that connect to the same terminals that you would hard wire a button to. You really do want a later remote, as they all now use rolling code technology. Essentially you have to "invite" a remote and the unit and remote agree on a code. From that time on, the code changes every time that you use the remote (automatically, you do nothing). Way better security, and a guy cannot just run a frequency generator and open your door.
Sep 17, 2010 | Garden
Neighbor opening our garage door
Report this problem to the Manufactuer stating your model number of controller and remotes too and they may help solve your problem faster than getting offside with your neighbour,apart from that the remotes and motor controller may need replacing to give you more security and control over your own secure enviroment,
I have fitted many security devices,alarm panels,cameras,sensors,keypads,etc,
and never had to repair this type of fault as the supplier or manufactuer has always assisted with their products thru warantee or advice,
I have 20 years of experience in the industy in NZ,Thanks MISTERDJ
Jun 12, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door will only close with keypad code it will not open
UNPLUG THE UNIT AND WAIT 5 MIN.
WHEN YOU PLUG IT BACK IN CLAER ALL CODES BY HOLDING DOWN THE PROGRAM BUTTON FOR 20 SECONDS.
NOW TRY TO PROGRAM EACH REMOTE AND KEYPAD - IF THERE IS STILL A PROBLEM CHANGE THE BATTERIES AND REPEAT THIS PROCEDURE.
I HOPE THIS HELPS
Mar 31, 2009 | Sears Craftsman LiftMaster Chamberlain...
Craftsman garage door remotes and keypad won't hold the code.
DID YOU BUY THE KEYPAD AND REMOTES WITH THE OPENER. IT SOUNDS LIKE YOU MAY HAVE THE WRONG ONES FOR YOUR OPENER.
CHECK THE FREQ. AND IS IT ROLLING CODE.
Mar 24, 2009 | Sears Craftsman LiftMaster Chamberlain...
Need to replace an old garage door remote
will not offer support on this old, unsafe unit. sorry. replace it for $160
Dec 13, 2008 | Sears Craftsman LiftMaster Chamberlain...
Changing code on keyless pad on old garage door opener
NOT FAMILIAR WITH CRAFTSMAN MODEL NUMBERS
IF THE UNIT HAS SAFETY EYES YOU SHOULD BE ABLE TO FIND A SQUARE PROGRMING BUTTON.
PRESS AND RELEASE YOU NOW HAVE 20 SECONDS TO INPUT THE NEW CODE ON THE KEYPAD AND PRESS ENTER.
HOPE THIS HELPS
Sep 08, 2008 | Sears Craftsman LiftMaster Chamberlain...
Garage door opener
THE ODDS OF IT WORKING ARE SLIM
YOU CAN BUY A UNIVERSAL REMOTE FROM CHAMBERLAIN / LIFTMASTER / CRAFTSMAN THAT WILL WORK WITH YOUR EXISTING REMOTE A MUCH BETTER SOLUTION.
HOPE THIS HELPS
May 04, 2008 | Sears Craftsman LiftMaster Chamberlain...
Home Security Logo
51 people viewed this question
Top Home Security Experts
Lawrence Oravetz
Are you a Home Security Expert? Answer questions, earn points and help others
