Question about Whirlpool Refrigerators
How do you remove the freezer door on a gx5shdxvb03. It has the freezer on the bottom
SAFELY REMOVING DOORS FOR SHIPPING
Good Morning Jill,
I see that you are trying to remove the doors on your Frigidaire refrigerator, model# FRS23R4A, for shipping purposes. Below are the instructions you will need to follow for both the refrigerator and freezer doors.
DOOR REMOVAL INSTRUCTIONS:
If it is necessary to move the refrigerator through narrow doorways, follow these steps to remove the doors.
IMPORTANT: Before you begin, turn your freezer and fresh food controls to "O" and remove electrical power cord from the wall outlet. Remove any food from the door shelves.
1. Disconnect electrical supply.
2. Open both doors, then remove toe grille.
3. Close doors.
To Remove Refrigerator Door:
1. Remove top hinge cover screw on refrigerator door and remove cover.
2. Trace around hinge with soft lead pencil. This will make it easier to realign doors when they are replaced.
3. Remove top hinge and lift refrigerator door off bottom hinge pin. Set door aside.
4. Remove bottom hinge, if necessary.
5. Reverse this procedure to reinstall refrigerator door.
To Remove Freezer Door:
1. Disconnect water line coming from lower hinge of freezer door at connection located under front of freezer: Press outer ring against face of fitting, then pull to remove tube.
2. Remove top hinge cover screw on freezer door and remove cover.
3. Disconnect wiring harness connector plug at top hinge: place your thumbs on flat sides of each connector and bend both parts back and forth, then with firm grasp, pull both pieces apart.
4. Trace around hinge with soft lead pencil. This will make it easier to realign doors when they are replaced.
5. Remove top hinge, allowing wiring harness to pull through hinge and lift freezer door off of bottom hinge pin. Lay door down flat to avoid kinking water line.
6. Remove bottom hinge, if necessary.
7. Reverse this procedure to reinstall freezer door.
When both doors have been reinstalled, connect water line by inserting tube and push until mark touches face of fitting, replace toe grille and plug in electrical power cord. Turn both temperature controls to center position. Adjust settings as necessary. Hope this is helpful.
-Best Regards-
WP
Mar 14, 2014 | Frigidaire FRS23R4A Side by Side...
How to remove bottom (freezer) door on my subzero refrigerator/freezer
With the door closed. Remove the cover over the bottom door hinge by removing the two screws holding it in place. This also allows the door closing mechanism to be removed. Rotate the door closer away from the refrigerator and slide straight down. Now open the freezer door. Take a pencil and mark around the hinge on top of the freezer door so you will know where to put the hinge back in place later. Remove the three large hinge screws and two small shipping screws. This will release the door on the top. Rotate the door away to get free from the hinge and pull the entire door straight up.
Dec 08, 2013 | Refrigerators
Removing samsung freezer drawers
There are 3 bolts that hold the bottom of the freezer door in place, if you remove them the door will fall to the floor then youmcan pull it off then you can access the drawer
Sep 07, 2012 | Samsung RFG237AARS Bottom Freezer French...
Model #GX5SHDXVB03 freezer floor filling with ice (water run down back then freezes)
So I figured out what the real problem is with this model of freezer. There is an updated drain that needs to be installed. The old version gets plugged from dust and no amount of thawing will fix it. if your appliance is less than 2 years old the manufacturer will pay to have your appliance updated with the new part. If your appliance is over two years old they will send you the new part for free.
http://www.amazon.com/gp/product/B0156NFUV4?psc=1&redirect=true&ref_=oh_aui_detailpage_o00_s00
Feb 28, 2012 | Whirlpool Refrigerators
Water running out of tube from fridge into bottom of freezer door that leads up to water dispenser ?
Is the water leaking from the bottom of the freezer door ? ( new door ) line is not replaceable inside the door .
Is the water leaking from the tubing at the connector ( about 6" from the bottom of the freezer door ) ( remove both lines from the connector , cut off about 1" of each tube and reinstall into the connector )
To access , remove the kickplate by either removing 1 screw on each side or just pull off ( held on by clips ) .
Apr 17, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Mod# RFG297AA:Need to remove the freezer section or handle/latch
there are two screws on each side of the bottom freezer unit you need to remove. they can be removed after de-installing the front bin with the two plastic sleeves on the right and left. Then you can remove the bottom drawer door and the bins inside. next, open both top doors and angle the fridge with one door inside the door frame, then "walk" the fridge over the doorstoop, turning towards the inside door as you push. Follow thru with the rest of the unit, then re-attach the bottom drawer.
Apr 08, 2010 | Samsung RF265AA Bottom Freezer French Door...
I have a frigidaire refrigerator with top freezer. model frt21nfrd2. About 12 years old. With a light inside you can see light in the top right of the refrigerator door. Seems to seal good every where...
remove freezer door. now remove hinge on top of bottom door. lift bottom door off. now place a washer on bottom hinge and re install everything. this should solve your problem.
Feb 01, 2010 | Refrigerators
How do iremove the doors on my conquest
Remove the hinge cover at the top for both doors . Remove the bottom kick plate from the fridge . On the freezer door , follow the white tubing at the bottom about 6" to a connector . Remove the hose from the connector . Unplug the receptical at the top of the freezer door and remove the 3 screws from the top hinge . Lift the door upwards , pulling the bottom tube thru the bottom hinge . For refrig door , just remove the 3 screws holding the top hinge and lift door off bottom hinge . Hope this was helpful .
Aug 20, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Door Removal
If you don't have the manual, go to Samsung's website and download the manual. It explains how to remove and adjust the doors and bottom drawer.
Jun 23, 2009 | Samsung RF265AA Bottom Freezer French Door...
Elite trio
Hello bigmikeegator
Welcome!
You said, you have the Kenmore Elite Trio Bottom Freezer. You moved your refrigerator to a new home and removed the bottom freezer door, but can not seem to figure out exactly how to put it back on correctly.
It's too much for me to tell you myself.
This is easier!
Page 9 shows you how to remove and reinstall doors.
http://www.managemyhome.com/mmh/lis_pdf/OWNM/L0523115.pdf
Thank you,
Huuum,
Please remember to leave a rating!
Oct 06, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Refrigerators Logo
41 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
