Question about Bosch Dishwashers
Bosch dishwasher error code e15
Error code e15
SOURCE: I have a bosch dishwash e15 check water
I found this solution on elsewhere on fixya. it relates to a little float switch designed to detect water leaks I think. 1. turn off power and water 2. tilt back machine about 45% (have towels ready to soak up any spill off 3. when all the water has emptied, right machine and retry. if the problem keeps reoccurring, you may have a genuine water leak. I had to try a few times but this worked for me and saved me at least 4 days of hand washing over a long weekend. good luck
Posted on Oct 27, 2011
SOURCE: Error code E:24
bosch logixx error code: e24?
Posted on Sep 20, 2009
SOURCE: bosch dishwasher has e24 error code and does not
An error 24 code on your Bosch dishwasher means that you have a clog or that your pump is bad. Check and clean out your airgap. If that doesn’t work and your machine is still under warranty, call Bosch. Bosch won’t tell you what the error code means, only that you need a service call, and they will then give you some phone numbers for Bosch authorized appliance repair places, one of which was Mr. Appliance. The appliance repair place will want to put in a new part whether you need it or not so that they can get paid by Bosch. I found this out the hard way. Hey Bosch, be smart and tell your customers what the error codes mean so that they are informed and you don’t look like you are trying to rip them off. Leave that to Mr. Appliance. You can always remind the customer that working on the actual dishwasher voids the warranty. It doesn’t take a rocket scientist to figure out how to clean out the airgap, which isn’t a part of the dishwasher, but rather part of your plumbing connected to the dishwasher. I suspected this to begin with, but because you told me I needed a service call, I had to assume it was beyond basic owner maintenance. Great way for you to flush money down the toilet and look bad doing so.
Posted on Apr 30, 2010
SOURCE: What does the error code E01 for bosch dishwashers
my dishwasher e01cod show then turn off
Posted on Jan 26, 2011
ZJLimited
  • 17970 Answers
SOURCE: E15 error message making a funny noise, is the a
E15 indicates the anti flood device in the base of the appliance has been activated.
Unplug the appliance.
Take the cover below the door off.
Take the insulation out of the way.
Remove any water in the base that is lifting the float.
Once removed, try the appliance again. Watch through the open inspection panel to see if the appliance is leaking.
If the float isn't up activating the switch then the switch, wiring or control board is faulty. Check the float and check the switch.
Your machine is still under warranty so you do need to be careful about what you do.
Trying to repair it on your own may invalidate the warranty.
Hope helps.
Posted on Apr 27, 2011
Bosch Dishwasher fault E 15 explain
Bosch Dishwasher Error Code E15
Fault Condition:No water in dishwasher or not sensing water.
Repair or Check: Tilt dishwasher back and the error code should disappear. While you tilt it press off button to clear. Stand it back to normal turn back on and dishwasher should run normally.
Parts Required:Tilting machine
Hi i found this answer on this link, scroll down the page and it's the 3rd error code (in red) Hope it helps...
https://removeandreplace.com/2015/10/09/bosch-dishwasher-error-codes-how-to-clear-what-to-check/
Mar 16, 2016 | Bosch Dishwashers
E15 i want reset it ?
If this is a Bosch dishwasher, the E15 error indicates water in the base of the unit. You need to unplug the dishwasher and pull it out (if it is an under-counter unit) carefully. Empty the water from the base. Sometimes tipping the unit so that the base is tilted 45 degrees from the floor will help the water flow out. Make sure that the entire base is dry.
Replace the dishwasher under the cabinet (if needed) and plug it back in. If the error repeats at the next cycle, you need to determine where the dishwasher is leaking. It could be the outlet hose, the pump or the tub. Replace the bad part. If the dishwasher is under warranty, contact Bosch.
I hope this helps.
(if you recently had a flood either under the kitchen sink or an overflow at that sink, you just need to dry the dishwasher base.)
Apr 16, 2015 | Dishwashers
I have a bosch dish washer with a E15 error and warning light to check water flow
E15 fault is water into base and has activated the anti flooding device.
You will need to remove the water from base and investigate for leaks.
Jul 10, 2014 | Bosch 24 in. SGS43C12 Classixx...
Error code e15
The E15 error message specifically indicates that there is a flood issue on the unit. This usually happens when the bottom part of the unit becomes flooded with water.
STEP 2
If this happens, there is a possibility of a leakage somewhere in the system. This occurs mostly on the drainage system of the unit where the water passes through different hoses pipes before finally releasing the water to the sewage. STEP 3
This problem can be solved by inspection. Remove the unit and take off the cover. Drain all the water and look for the source of the leakage.
Mar 04, 2014 | Bosch SGE63E15UC 24 In. Stainless Steel...
Alarm e15 up and can't reset
Bosch SMS Series Dishwasher Fault Codes E15
Water in base
Float sensor in the base has been activated. You can try to empty the base and restart the dishwasher as you will find noted many times in the forums but, if there is a leak this error code will simply be displayed again, you must find the cause of the leak.
but if you have a different model it can be something else
Dec 26, 2013 | Bosch Dishwashers
Code E15 bosch super silence dishwasher
Use dish washing rug and soak water out trough salt inlet. Only 10 degrees tilt needed. Boch Super Silent dishwasher. E15 error code.
Mar 02, 2013 | Dishwashers
Bosch dishwasher showing e:15 error code.....how do you fix it?
E15 means that unit doesn't think it's getting water
If there is not water inside the tub then you have a problem with your electronic water valve and will need to have it replaced. If you do have water inside but it's still giving you the error, then you have a bad flow meter that iwll need to be replaced
Nov 18, 2012 | Dishwashers
Its out of work and shows E:15
This error message is normally an indication that there has been an overspill of water in to the base and triggered the antiflood mechanism.
Try tilting the dishwasher back to allow excess water to run out and then retry the wash cycle. If it still gives the E15 code then there is a leak on the system.
Jul 29, 2012 | Bosch 24 in. SHU43 Built-in Dishwasher
The control panel on my dishwasher is showing a tap and E15
Mine's a bosch, same problem but started with E25 due to broken glass in the pump impeller, after struggling to remove it and then testing, it eventually moved to E15 as rightly so, no water was entering the machine due to the E25 code. The advice above is good, but take the device out first and tip the machine. This cured my faults without the need for a service call or spare parts.
Mar 27, 2010 | Bosch 24 in. SHU43 Built-in Dishwasher
Dishwashers Logo
1,147 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
