Question about Ryobi 30 Cubic Centimeter Curved Shaft Gas Trimmer
Ryobi 790r fuel line routing - Ryobi 30 Cubic Centimeter Curved Shaft Gas Trimmer
5 Suggested Answers
  • 6 Answers
SOURCE: What is the correct fuel mix for the ryobi 790R
The window ratio should be fine between 40/1 to 50/1.
Reduce oil ratio by increase gas part if some unburned oil can visible from the exhaust.
Someone else could have a better voice on this matter..
Posted on Jun 24, 2009
SOURCE: I have a ryobi 790r weedeater and i need the
On the 790R you will have to remove the carburetor and the four screws of the plastic housing behind it. The gas tank will then slip out.You will need to replace both the housing and carburetor gaskets.
Hope this is of some help, Lamar
Posted on Jun 28, 2009
panilling9
  • 284 Answers
SOURCE: Ryobi Gas trimmer fuel line routing
The fuel fillter line goes directly to the carb.inlet first
the outlet on carb.
goes to suction side of primer and outlet side of primer back to tank
primer draws fuel through carb. to prime
Posted on May 09, 2010
Testimonial: "Thank you"
rycgl
  • 1545 Answers
SOURCE: I HAVE A RYOBI VAC/BLOWER MODEL RGBV3100 THE FUEL
The small diameter line out of fuel tank (has filter in-tank on end) connects directly to the side of the carburetor that has the fuel pump....that is the cover without the hole in it. Other larger diameter fuel line out of tank connects to the longer nipple on the external purge/primer bulb. The bulb "pulls" fresh fuel from the fuel tank to the carb and then out of the carb to itself, where it then "pushes" any air/old fuel back into the fuel tank. The remaining larger diameter fuel line in this setup goes from the metering chamber (has cover with writing on it and a vent-hole) side of the carburetor to the smaller nipple on the purge/primer bulb. Again, on the primer bulb, the longer nipple has a line going directly from it to the tank. This is the return line. The shorter nipple on the bub has a line from it going to the metering chamber side of the carb. If the purge/primer bulb is on top of the carb...small line from carb body to small hole in tank with filter. Larger diameter line goes from the bulb on the fuel pump side of the carb to the larger hole in the fuel tank where sometimes the line is held in place with a nylon nipple connector that keeps the line from pulling out of the tank. Otherwise, the line should enter the tank for about 1/2" or so
Posted on Feb 19, 2011
French owners manual for weed eater ryobi model 790r
On internet go to www.manuals.ryobitools.com and search for 790r. Next scroll down the page looking for the trilingual manual. Download the PDF version and you will have it quickly.
Jul 25, 2016 | Ryobi Garden
I have a Ryobi 790R "E Z" and need to know how to
It is not too hard. Just make sure to cut the new fuel filter line long enough so that you can get ahold of it inside the fuel tank to install the filter. The fuel return line only has to go into the tank 1/2" or more to do it's job, so lenth is not a problem unless you wish to install one of the little nylon connectors on it's end so it doesn't pull OUT of the tank. That is optional.
Jul 19, 2011 | Ryobi Garden
Won't start , can not get primer to work even after replacing primer bulb.
If your fuel filter is clean, and none of the fuel lines are pinched, then you probably need to replace the diaphragms, gaskets, and screen in the carb. Some carbs with the primer bulbs mounted on the carb have a check valve in the primer system. This is the least likely problem, but it is possible that the check valve is defective.
May 07, 2011 | Ryobi 30cc 17" String Trimmer Zrry30530...
Need a repair manual for a Ryobi 790r fuel line diagram
Here is a page that will take you to a download of the exploded view of the trimmer ..
http://safemanuals.com/user-guide-instructions-owner-manual/RYOBI/790R-SERIALS-810046371-THRU
on the right side there is a place to select the download .
Jun 02, 2010 | Garden
Gas lines fell apart and I have new ones for a ryobi 790r trimer but do not know what line goes where there are 3 hoses could some one show me or tell how to fix this trimmer??? warren9@hotmail.com
Typical fuel line routing is:
One line (the one with the fuel filter in the end of it) comes out of the fuel tank and goes to the bottom fitting on the carburator. The second line comes out of the tank and goes to the bottom fitting on the primer bulb. The third section of line goes from the top fitting on primer bulb to top fitting on the carburator. Hope this helped and best wishes.
Sep 30, 2009 | Garden
I have a 790r and the detent pin on the lower
That pin should be the same as other Ryobi trimmers. Find one for one of them and compare. Lee
Sep 15, 2009 | Garden
What is the correct fuel mix for the ryobi 790R trimmer?
Jun 22, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Ryobi Cultivator 410r
The linefrom the tank with the filter goes to the mixture inlet on carb. The fuel return goes to the suction side of bulb. The bulb outlet line goes to the tank. Hopes this helps
Mar 19, 2009 | Ryobi Factory Reconditioned 18" 40cc...
Ryobi 30 Cubic Centimeter Curved Shaft Gas Trimmer Logo
26 people viewed this question
Top Ryobi Garden Experts
Nick Olsen
Rexter1
Roland W VanLue
Roland W VanLue
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
