Question about Dishwashers
Whirlpool GU2500XTP dishwasher went dead in mid-cycle.
Replaced control panel without success. No lights on control panel and no response to controls.
Wondering if this model has had reliability issues with the circuit card.
  • Anonymous Mar 12, 2014
    The control panel will not light up and will not work
  • 188 Answers
"Wondering if this model has had reliability issues with the circuit card." ...If by circuit card you mean the electronic control board, that part number is used in many other models as well. In my experience with these control boards, I believe they have a low failure rate.
Make these checks if you haven't done so yet...
Check for 120V (breaker). Look for loose/shorted wiring connection at the dishwasher's junction box. Check all wiring connections to the control panel, electronic control and thermal fuse. Test the continuity of the thermal fuse (part # 8193762). If that's ok, you have already replaced the control panel so the problem is likely with the electronic control board (part # 8564546).
Good luck.
Posted on Mar 12, 2009
Why is my GE front load washer is non responsive. The control panel went blank. Not a power issue since the outet is good. Model GBVH5140HWW
It could still be a plug or wire problem but if not a power problem inside the machine or a printed circuit board or other internal failure. It will not be possible to diagnose the problem without a lot more inforamtion.
Sep 12, 2014 | Washing Machines
My control panel keeps lighting up on its own.
Good Afternoon Marleen,
I understand the control panel on your Frigidaire washer, model# ATF6000ES, keeps lighting up. I also see that you have to keep hitting the cancel button and are wondering if it is a safety issue. I wouldn't think it would be a safety issue. I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Restore power and start any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jul 04, 2014 | Frigidaire ATF6000ES Front Load Washer
Dsxh47eg0ww
I would replace parts. It still is cheaper than a new unit. So get the new control panel and do it yourself and save money. The average life of a dyer is dependant only on when the owner gives up. I just serviced on last week that was 25 years old.
Jul 08, 2013 | GE DSXH47EGWW Electric Dryer
Regency problems
follow this steps and fix it. God bless you
Touchpad and Control Panel
If the buttons don't work on the control panel the entire touchpad and control panel assembly may need to be replaced. If the display works but the dishwasher functions are all out of synch, or some of the buttons don't respond properly the entire touchpad and control panel might need to be replaced.
Enter your model number to see parts for your dishwasher.
Help me find my model number
Touchpad
If the buttons don't work on the control panel, the dishwasher touchpad might be at fault. Generally speaking, if the dishwasher display is working and some of the buttons respond correctly but some don't, the problem is with the touchpad.
Main Control Board
The dishwasher has a main control board which regulates nearly every function in the dishwasher. If the control panel buttons don't work, and other causes have been ruled out, the main control board might need to be replaced.
Jun 14, 2013 | Maytag Dishwashers
For some reason, the remote just stopped working. I would press the buttons to try and get a certain channel or increase the volume and the light would blink but there was no response. My first thought...
SOUNDS LIKE A REMOTE ISSUE,IF ITS NEW I'D TAKE IT BACK,IF NOT I'D BUY A NEW ONE LIKE RCA OR ONE FOR ALL,THEY ARE BOTH RELIABLE REMOTES,STAY AWAY FROM RADIOSHACK AND SONY REMOTES"JUNK".
Oct 07, 2010 | Radio Shack 15-2200 Remote Control
I have a Whirlpool double oven (model RBD275PDS14). The control panel goes blank about every 2-3 months, and the oven won't heat. Although, the light inside the oven will still work. When the panel lights...
Your error code is for a stuck keypad. You can try pressing every button at random several times each to unstick.'
When the control board is changed on these ovens the keypad assembly is supposed to be changed also.
Nov 21, 2009 | Whirlpool Ovens
Control panel doesn't light up
HI, this issue concerns the touch pad(control board led). This will happen in certain models. it could be some minor corrosion within the wire contact clips that are not allowing the proper current to illuminate the led that is used to light the specific button or, it could be a minor circuit issue within the control board as well.
i recommend inspecting the control panels wire harness contact clips that are behind the actual control board. make sure they are not corroded or lose. if they are lose or corroded, i suggest replacing the entire wire harness. this could be the possible reason for some of the lights that are not illuminating during operations.
If the wires and contacts are in good condition and the harness is in good condition as well, this could be an internal control circuit board issue, concerning the LEd lights. they may have burned out due to the age or heavy usage.(heat related)..
Please rate and god bless:)
Apr 20, 2009 | Electrolux 30" Built-In Single Electric...
Dishwasher works only in Rinse and no lights on the Control Panel
I HAVE SEEN THIS BEFORE ON SEVERAL DIFFERENT MAYTAG MODELS AND EACH TIME, IT HAS BEEN THE ACTUAL TOUCH PANEL WHERE YOU MAKE YOU SELECTIONS. I HAVE PROBABLY SEEN A DOZEN OF THESE IN THE LAST COUPLE OF YEARS. HOPE THAT HELPS.
Jan 29, 2009 | Maytag MDB9600A Jetclean II Built-in...
Dishwashers Logo
442 people viewed this question
Top Dishwashers Experts
