Question about Dryers
Kenmore 70 series electric dryer hums but won't tumble
Our basement flooded a few months ago while I was in Afghanistan, submerging the lower half of our electric dryer. The washer works fine, but the dryer only hums when the start button is pushed. The lights come on, I can smell the heater element warming up(not the smell of burning wiring), and the drum turns with the normal amount of resistance. The belt is still on, and I can move the belt by hand when I reach in from behind. Does the motor have to be replaced, can this machine be repaired? If so, how the heck do you get to it? I removed one panel only to be faced with a jumbled mess of blower and heater elements. I would like to avoid the cost of a new dryer until we build our new home. Thanks.
  • david_perdew Mar 15, 2009
    the description was spot-on, making the repair easy. now I'm waiting on a replacement motor instead of buying a new dryer. Thank you.
  • 163 Answers
You do need a new motor.ypu need to take 2 screws out of top where lint filter goes.take top up and their will be 2 screws one on each side take scres out and pull upward and forward and the front panel will come off.you will need to remove belt and tub then you will see motor.you will need to be able to grab back side of motor that attaches to blower and front shaft of motor and turn opposite way to come loose from blower.you will then take back clip off and front clip and unplug motor and pull out.good luck hope instructions helped.
Posted on Mar 12, 2009
Why wont the motor on a top load roper washer work after a flood
If the motor was submerged in water it's probably shot. They aren't made to function during and after exposure to water.
May 20, 2014 | Roper RAS8445KQ Top Load Washer
Kenmore dryer 70 series 66722690 - has power but won't start (no humming noise, no ticking noise from timer, and no light when you open door) nothing!
I would check the breaker before you go any further. Here are some things to remember when you do this. 1) The breaker for the dryer is generally located outside on the side of the house somewhere near the electric meter. Most 220vac breakers are, which include any electric range, cooktop, wall oven, etc. 2) When your checking the breaker, actually physically touch it. Sometimes breakers can trip a but the spring that actually pulls the breaker to off position is weak and by visual inspection would appear on. Just simply reach in and tap the bar lightly in the off direction. If it pops over to the off position, turn it back on then go check your dryer. If the breaker passes inspection, I would unplug the machine because there migfht be a short at the terminal block where the plug connects to the dryer. After you've unplugged it, remove the back and check to see if everything is ok. I have a strong feeling that you won't need to get to this point cause I'm betting on breaker.
Apr 30, 2012 | Kenmore Dryers
4 month old admiral dryer. Basement got flooded. Very little water hit bottom of dryer. It tumbles but has no heat. What do I do?
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 30, 2011 | Dryers
My basement flooded and dryer was partially submerged can this be repaired
anything can be repaired, but the question is..cost. I would start by calling around and finding an appliance repair shop, ask them how much for a used dryer motor. everything else should be fine. Hope this helped Tim
Mar 11, 2011 | Estate Dryers
I have a kenmore front loader dryer. My basement recently had a flood and the bottom of the dryer was wet. When i tried to start it, it hums but will not run. What is the problem?
the motor is cooked,i live in the boston area and we had some bad floods a few months ago,all i did for two weeks was change out dryer motors,you can try to spin the drum and hold in the door switch and have someone else hold in the start button to see if it will start but you have to change out the dryer or get a new one if it's in rough shape
Aug 05, 2010 | Kenmore 73952 Gas Dryer
Kenmore dryer thats not drying
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Jun 01, 2010 | Dryers
Kenmore 70 series gas dryer - does not start when pushing the start button
heatman101
May 19, 2010 | Kenmore 77632 Gas Dryer
Dryers Logo
467 people viewed this question
Top Dryers Experts
