Question about Belkin Computers & Internet
Belkin 54 g wireless router....cant find on the net. need to port forward to host blizzard.net games HELP!
    Scholar:
  • 26 Answers
Make sure your private IP address is statically set.  Your public IP address is obtained from your ISP and is what other users will be connecting to.  You can not manipulate your public IP address so if your ISP is running DHCP, it is very possible that your public address is changing.  Also if you are frequently disconnecting your modem, it is possible your ISP is leasing you a new public IP address each time.  So try to keep things as static as possible.  As far as the battle net stuff.
Diablo, Warcraft II Battle.net Edition, and StarCraft:
Allow port 6112-6119 TCP and UDP out and in
Diablo II:
Allow port 6112 TCP out and allow established sessions in
Allow port 4000 TCP out (realm games)
Allow port 4000 TCP out and in (hosting open games only)
Warcraft III:
Allow port 6112 TCP in (hosting custom games)
Allow port 6113-6119 TCP out and in (hosting custom games if you've changed the default port in the Options/Gameplay screen)
If you are still having problems after you open up the required ports, try opening 116(TCP) and 118(TCP). I don't really know if these ports are required or not.
I have had people tell me that opening up those two ports have helped them connect to battle.net.
Hope that helps.  For manipulating ports in your router I suggest consulting your user manual, or online FAQ.  Save your router config before applying any changes, and always remember, opening up ports subjects you to different types of security threats so be aware that is a risk you are taking.
Posted on Mar 12, 2009
I have a belkin -n1 wireless router.. it is a great router because it works all the way through the house. the only problem with it is that i cant update my xbox with it, neither by wire or wirless. if it...
first check whether the gaming ports for xbox have been forwarded in the belkin router or not....if not do it first....if you dont know the port numbers call xbox support and get the list of port numbers to be forwarded....
then enable DMZ for the ip address of XBOX in belkin router...
then enable UPNP in belkin router....
atlast Disable firewall in belkin router.... your XBOX will go online and GET UPDATE..... you can call belkin tech support of your country to assist you to forward ports for XBOX in belkin router... if you reside in USA/Newzealand/Australia/Canada you can call this toll free 1800 2 BELKIN(235546)...... or you can call my personal mobile... Im from India country code +91 Mobile number 9003593572
Apr 09, 2010 | Microsoft Wireless Network Adapter Xbox...
My wireless adapter light is green, yet i cant connect to xbox live!
Apr 08, 2010 | Microsoft Wireless Network Adapter Xbox...
Problem hosting games on sc broodwar
Hi!
Depending on your router, you should forward the ports, as detailed here:
http://portforward.com/cportsnotes/battlenet/battlenet.htm
That should let you host!
Good Luck!
Nov 14, 2009 | Blizzard Entertainment StarCraft Brood War...
When i host a game on xbox live, The whole games lags up and i get kicked, I never used to have this problem, And i have 10meg BB is this a router problem? When im not the host i can play fine, Usually...
Is your Xbox hard wired or wireless? If its wireless, try changing the broadcast channel (to like 11) your are probably getting interference. If its hard wired, you probably need to forward the port on that IP address for the Xbox
Nov 11, 2009 | Gateway Belkin 54g Wireless DSL/Cable...
I have a Belkin Wireless router and I have a PS3
Actually you don't need to forward ports when playing online games. The router should automatically locate the ports for the game because it has UPnP function. Here's what you can do. Disable the port forwarding and DMZ that you set on the router. Look for the UPnP function of the router and disable, Save it. Enable it again, then save. Now power cycle your router. If you have Static IP on the PS3 network settings, try to set it first to automatic IP and automatic DNS.
Hope that helps.
Sep 23, 2009 | Belkin N Wireless Modem-Router F5D8633au4A
Need To Configurate To Host A Bnt game
You need to log on to your router. Go to Start>Run>type http://192.168.1.1. then a login window appears. Leave username blank and admin for password. There you will find the port-forwarding, DMZ stuff that gamers use. Here is the link for Linksys info for your router http://www.linksysbycisco.com/US/en/support/WRT160N Steve Medley
Jan 20, 2009 | Linksys WRT160N Wireless Router
W850G Motorola Wireless Router Ports
You need to get the manual for the router, get into the configuration pages and enable port forwarding or dmz for your pc.
Aug 28, 2008 | Computers & Internet
Unable to host game of DFLW
you could try forwarding the port that the game uses through your router www.portforward.com can walk you through it
Jan 16, 2008 | Gateway Belkin 54g Wireless DSL/Cable...
Router blocking my downloads
k i think why its happend probabally there is a port blocking is there in the belkin router so try this set static ip address on the pc in the range of belkin>and login to belkin router and enable DMZ on the belkin router the dmz host ip should be the one which u assigned statically on the pc
Oct 13, 2007 | MSI Wireless-G RG54G3 Router
Computers & Internet Logo
527 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
