Question about Westinghouse Refrigerators
Fridge lights are on,fan blows,but compressor don`t start
It quit after two years
how does the grill come off front?
looks dirty.....there was a dog living there.
could it be something simple to fix? cheap?
is info free?
Freezer is freezing up, Refrigerator is cool, but not enough to cool food. Replaced the condeser fan. Lights are blinking on the front panel and wondering if any knows how to re-set or any other solutions?
Posted on Mar 12, 2009
Does canned dog food make Pomeranian's sick?
It can. If you dog gets sick eating a canned food brand, you should try another. Consult with your veterinarian about this problem.
Not all canned dog food is made the same, and many can be too rich for toy breeds.
Mar 03, 2015 | Dogs
3 year old Amana NED 7200 dryer has film of black grease in drum back portion and grease is on clothes after coming out of dryer.
Check the thermostats for continuity. Sounds like the dryer is getting to hot and may have melted something. There is nothing with grease in that area of the dryer,
Nov 06, 2012 | Amana NED7200TW Electric Dryer
Outside surface gets hot to touch
The most likely problem is a dirty or clogged up condenser grill (under your unit). When the condenser grill is dirty it can get rid of the system heat build up, so it transfers the heat to the cabinet.
Remove the front grill and vacuum it the best you can, a small brush would help loosen up the dirt. Then move the unit away from the wall and remove the rear panel and use an air compressor to blow it out.
Make sure that the condenser fan is operating or that could also be the problem.
If none of this remedies the problem then your unit could need to be charged with freon. Because if the freon is low the compressor has to work harder to cool.
Aug 07, 2011 | Kenmore Top Freezer Refrigerator
Fridge running warmer than it should, Cooling fan on back doesn't turn, the compressor/condensor running very hot , and no new ice being made. Cleaned the cooling grid which was full of dust.
Here is the basic idea on how to keep the refrigerator, air conditioner, or vacuum cleaner to work properly. Air is moved by an electric fan or blower in order for that product to work properly. If air movement is blocked the fridge won't get cold, the central air conditioner won't cool enough, the vacume cleaner won't clean as well. Check on your fridge's air movement by inspecting the bottom of the fridge for dust and cob webs. Remove the front bottom clip-on plastic grill. Or also even access the lower back of the fridge by removeing the screws holding up the heavy cardboard cover to see inside. Blockage of air flow will prevent a fridge from getting cold. Just like a vacuum cleaner stops working when the bag is filled with dust and fibers. The air could be blocked by the accumulation of dust and fibers. Look under your fridge if it is cloged, it will look just like the stuff on a dirty central air filter.
Dust and fiber buildup blocking the fridge's air movement from back to front (or visa-versa) of your fridge will slowly (years) prevent how good it cools. The build-up of dust and cobwebs prevents your fridge from cooling (more specifically prevents the heat to disapate from the metal heat disipating fins attached to the metal tubes to be blown off by the fans air). OK! Remedy for a vacuum cleaner REPLACE THE CLOGED VACUUM BAG.
Remedy for your fridge manually REMOVE THE CLOGING DUST AND FIBERS FROM UNDER YOUR FRIDGE. SORRY fridge manufacturers do not provide a dust filter like the vacume cleaner and central air systems manufacturers do. You have to figger out the best way you can clean it. Possibly vacuum with a crevice tool, or use a small brush than vacuum. The extreme would be unplug the fridge ( so you won't get electrocuted) bring a water hose into the kitchen and spray water at cobweb buildup at the bottom fridge, than wet vac the floor then wait 20 minutes to dry before pluging the fridge back into the electric outlet.
When you stand in front of your fridge and you hear the fridge electric motor turn on, the fan will blow air.The fridge
Apr 11, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
Came home and all the ice has melted in icemaker and everything defrosted. Some cold air is blowing, but not much. A distinct clicking noise happens every few minutes. No power outage and we tried...
There is hope but not a great deal. That clicking sound you hear is the compressor (that part of the refrigerator that creates cold air) trying to start. It may be very hot. The reason usually is that there is dust clogging the coils at the base of the unit that must be cleaned out. There is a fan motor, usually mounted in the back of the fridge in the base next to the compressor. That fan may not be turning. If that is the case, the compressor will shut down to prevent overheating (a good thing).
Here is what you should do.
0 Pull out the fridge taking care not to damage the water line to the ice maker
1 Unplug it to let it cool down completely.
2 Put your salvageable food into camping coolers with bags of ice.
3 Purchase a long skinny refrigerator coil cleaning brush (I've seen these at Walmart)
4. Change into real work clothes. This will be a dirty job.
5 Remove the "grille" on the front of the fridge, at the base. Just pull it straight off.
6 Brush out the dust from the coils from the front bottom.
7 Replace the grill.
(Sorry. Your not done.)
8 When the fridge is out from the wall (you will want to sweep and mop what you see back there)
9 Remove the cardboard cover from the rear. (You will likely need 1/4 inch or 5/16 inch nut driver to remove hex head screws). Observe the cardboard covor as you will need to bend it to remove, after the screws holding it are off. (You may also want to wear gloves keep fiberglass from getting onto your skin.)
If you accidentally tear the cardboard, don't fret as it can usually be fixed with duct tape.
10 Now after all that,(which really doesn't take long). You will be looking at a black metal case with small pipes running out of it. That is the compressor.
You will also be looking at (depending on the design) a condenser fan.
11 If there is a Condenser Fan (usually on side-by-side refrigerators) then finding out if it works or not will be part of the diagnostic steps.
12 Plug in the fridge after it has cooled down completely (several hours) and see if the compressor comes on.
It may come on instantly. If it does check to see if the condenser fan blade is turning.
If it is not turning and the compressor starts to run. shut the Fridge down.
13 Check to see if there is an obstruction to it turning (such as a small toy). If there was an obstruction, plug the fridge back in and see if the fan now turnes. If it does, you have likely repaired the broken component.
14 If the fan blades does not turn, unplug the fridge again and replace the condenser fan motor.
You will need some tools to do this such as a 1/4" socket set, Wiring tools, Wire Stripper, Wire Nuts, Wire Ties. A handy man level of experience is required for replacement of this part.
15 When done replacing it (or removing the obstruction), make sure the back cardboard panel is reinstalled. It is vital to the efficient operation of the fridge.
16 Plug the fridge back in. Give it two hours of running time to see if it will start to cool. Probably will. If not, there could have been a refrigerant leak. If so, only a professional is licensed to do the work. If there is a refrigerant leak, then the repair is likely not recommended.
I hope this helps
Best Regards,
Dec 26, 2010 | Maytag MSD2454G Side by Side Refrigerator
Weak flame on front burner
it may need a clean or the burner or block
Aug 01, 2010 | Weber Genesis Silver B Grill
Display on bord [service EC]
that could be caused by a freon leak in the evaporator coil,sometimes you can reset the board but if it comes back you know there's a problem,a clogged condenser coil or the condenser fan is bad but basically it's telling you it's running to warm, if you cleaned the coil and the fan is blowing strong most likely you have a leak in the sealed system usually the evaporator coil has to be replaced.i know this is to late you probably already fixed this problem would just like to tell you how i clean out the coil up top,unplug the machine with the quick disconnect up top or flip the breaker,i use a stinger shop vac,it's a small shop vac,i clean the front of coil with the brush attachment and then clean all the walls and wherever else i can get with the brush,then i put a towel up to cover the top just like the front grill does,set the vac to blow and blow through the coil,the towel keeps most of the dust inside when you blow it,do that a few times on the right side,after every time you blow it lift up the towel and vac up anything that blew out,then go to the fan side and do the same thing,also blow out the whole top cabinet too,any dust that's in the back or under the wire harness where you can't get will blow out and you can vac it up,then remove the towel and hit it a few more times,you can stick a flash light or drop light on the right side of coil and look through the fan side,if it's clear you're done.this should be done at least once a year,it could be the difference of having no problems with overheating,you'll save your compressor,the fan motor will last longer,if you don't do it and you cook a compressor you're looking at around a 2000 dollar repair,take a half hour once a year and clean out your coil.i have some old ones out there 25 to 30 years old,i go once a year to clean out peoples coils,it will add years to your machine,good luck with your ore thing that happens is the drain can clog,junk can get into the drain or the drain troft,if you find water dripping in the fridge section you'll know the drain is blocked,just a heads up.
Dec 30, 2017 | Sub-Zero 661/F Side by Side Refrigerator
Major oil leak near timing cover oil escapes under pressure
front seal near timing sprocket may be compromised. real simple to fix and the seal itself is dirt cheap but it will require some getting dirty.
May 25, 2010 | Hyundai Motor 1999 Elantra
Digital external readout stays at 50 degrees, constantly. Not a big concern, just annoying. Heat and A/C work fine Digital reads change when using those functions but exterior always says 50. If cheap,...
External sensor is most bad or cloged. Remove the plastic cover that the hood prop rod fastens to and you will see the sensor. I purchased mine from the dealer for twenty dollars. If it gets worse and reads below 32 degrees your a/c will not come on. This happened to me in July.
Jan 21, 2010 | 2002 GMC Envoy
Refrigerators Logo
Top Westinghouse Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Westinghouse Refrigerator Expert? Answer questions, earn points and help others
