Question about iflo Home
Replacement outlet pipe for iflo enigma shower
2 Suggested Answers
SOURCE: LOOKING FOR WIRING DIAGRAM FOR IFLO ENIGMA 8.5 KW
Wiring diagram needed
Posted on Jul 31, 2011
When i hooked up a delta faucet for a handicap tub i had to put it on the right side of the wall so that the older guy could reach the handle to turn the water on and he wanted the shower head closer
Not usually, but there should be an inverter or other unit to activate the shower. Often it is in the tub outlet and blocks the tub outlet to force water up the shower pipes. If there is no such or if it is just not working you may need to run the piping up to a sufficient height and then back down to the shower head to create enough pressure resistance if it is as you say, requiring a specific height of pipe to get a specific back pressure. But there also needs to be a mechanism to force the water up the shower pipe. Look up Delta on the web and get a phone number as there will be someone at Delta that can fully advise you about this.
Oct 04, 2014 | Delta Home
Shower not draining iflo waste
The domed drain plug has to be removed periodically, disassembled, cleaned, and reassembled. Be sure to disassemble it in order so you can reassemble it correctly.
While the drain plug is removed, apply drain cleaner in accordance with the directions
Nov 10, 2013 | iflo Home
Leak
1.How did you attribute the leak to the shower?
2. where did the water drip etc show up?
Jul 13, 2013 | Home
When i switch on my iflo enigma shower the power indicator goes out and the shower runs cold
You should not be taking an enema shower, especially with cold water.
Jan 06, 2013 | iflo Home
I have an iflo thermostatic bar shower mixer which no longer delivers hot water for the shower. Do i need a new Bar Mixer?
To get rid of this problem, you should consult with a professional. Apart from this, you can buy attractive and best quality shower mixer by visiting this site: showerenclosures
Jan 02, 2013 | iflo Home
Water coming out of small pipe next to water outlet to shower head whats the cause
its the overflow, you need to clean/descale the shower head/pipe,or have it serviced
Sep 25, 2011 | Home
Replaced delta valve with moem. when water to toub is turned on at high pressure water comes out of the shower head. Valve is installed correctly. Took cartridge out of valve and blew back through shower...
The pipe going from the main valve to the tub spout(not the sprayer above)needs to be a full 1/2" pipe if you used a pex 1/2" to the tub spout-the inside is usually smaller and causes it to back pressure and make water release thru the sprayer above-needs to be installed with a full 1/2" ID PIPE-AND DONT USE GALVANIZED
Sep 29, 2017 | Moen Posi-Temp Single HandleTub And Shower...
Water pressure to main hose has ceased, with water now pouring out of a small outlet pipe at bottom of unit next to fixing for main hose.
Sounds like your outlet at the top has clogged with grit/dirt. Turn the shower off, remover the entire shower head hose from its base (where it screws into the wall or pipe. Turn water back on. If you get a steady flow (as you should) the problem is isolated to the shower head/hose. Detach the shower head from the hose and clean the screen inside, attach hose back on first, try water again, if this flows then your blockage is in the head itself. After removing and cleaning the screen inside the shower head, reattach and run water, this should fix your problem, if not, you may need a new shower head. If the water will not flow to the outlet pipe alone, either your shower switch is broken or you have a serious plumbing problem.
Apr 16, 2009 | Home
Our Saniflo - Saniplus works fine and efficiently when we flush the toilet, if we use the shower or bath,when emptying the water the flow is not as strong/as much pressure like a toilet flush & the...
Sounds like a restriction in the outlet pipe, the 2 galls from a flush are OK but the bath or shower is more, especiallly if you have flushed before you shower, try drain unblocking chemicals or flushing the outlet pipe with mains water from a hose
Mar 09, 2009 | Saniflo & Saniplus& Macerator Pump
Home Logo
164 people viewed this question
Top iflo Home Experts
john h
Tom Chichester
Are you an iflo Home Expert? Answer questions, earn points and help others
