Question about Turbo Air TGM-5R
Tgm inverter air conditioner code PO
Code po
What is the value of r704 resistor on sharp slim tv 21v-fk220m
pa help naman po mga master..my rerepair po ako sharp tv..model21v-fk220m sira po ung regulator..strw-5453 sunod din po ung resistor na mlapit sa regulator..problem po d makilala ung resistor..anu po kya value nito meron po code na r704...slamat po sa sasagot godbless po..
Sep 24, 2016 | Sharp Televison & Video
Fault codes PO 193 FRP -- PO 101 MAF -- PO 380 -- PO a 09dc/dc -- PO 238 TURBO/ super charger-- PO 118 ECT -- PO 283 fuel temp sensor -- U 2023 brake sensor
101,380 and 118. These together is a no start. Take it to a garage. Just a guess, but I would be looking into the wiring. You waited to long to have a problem fixed. One bad part over time will lead to many codes. The PCM is trying to adjust to make the engine run right. Throwing other sensor out of range. Out of range pops a code.
Aug 06, 2016 | Ford Cars & Trucks
What could PO 302, PO 300, PO 105, PO106, PO 110,PO 115& PO 120 CODES Mean on a Toyota Camry 2000 model sedan car?
what engine, what size. that is first question.
misfire, map ,maf, iat, ect,tps and cat fail and low coolant temps.
very odd mix there. did you pull connections, key on???????
it means they all fail a test.
DIY? or just curious?
login to alldata.com
the question is , which is the most important.
all are cept 420, (last that, and bet goes way. later.)
reset the ECU, and see which come back.?
check all fuses.
then post codes that repeat, after fuse checks.
does the engine get fully hot running, 180F minimum?
Nov 27, 2013 | 2000 Toyota Camry
2000 Honda Accord po-7*** errors
You can't fix these types of complex electronic engine control problems without special equipment.
Jun 12, 2013 | Honda Accord Cars & Trucks
Code number for o2 sensor voltage low
Forget to write it down?
Generic or Manufacturer?
There are 41 Generic O2 Codes
PO 131--bank 1 sensor 1
PO 137--bank1 sensor 2
PO 143--bank1 sensor 3
PO 151--bank2 sensor 1
PO 157--bank1 sensor2
PO 163--bank2 sensor 3
Nov 23, 2012 | 2009 Toyota RAV4
Po316, po 300, po301, po305 2004 ford freestar
These codes are making me lean towards the ignition coil pack.My stepson's 2001 Sable 3.0 v6 had one cylinder misfiring(5-code P0305),which shares a coil with cylinder 1(code P0301).I diagnosed it by trading wire 1 and 5 at the coil,and the code changed to P0301.You have codes for the two cylinders on the same coil,so this is most likely it.(these codes would also trigger P0300(Multiple Misfires Detected) and P0316(Misfire Detected First 1000 Revs)).
Oct 14, 2012 | 2004 Ford Freestar
Pano po ba mag surf sa net gamit ang tm sim???
nakakapag surf lang po kayo pag activated po ang GPRS ninyo, so globe po automatic na yan,once inilagay ninyo ang sim sa phone,may darating po na text message mula sa nasabing operator,ito po ay ang configuration settings ng GPRS, i-save ninyo lang po at pag humingi ng code, 1234 lng po ang i-enter ninyo,dapat po may load po kayo para makapag surf o makapag internet.
good luck po.
Jun 29, 2011 | Cell Phones
Error codes po 134 po 153 po 154 po 155 po 171 po 174
PO 134 = 02 SENSOR CIRCUIT NO ACTIVITY DETECTED (BANK 1 SENSOR1)
PO 153 =02 SENSOR CIRCUIT SLOW RESPONSE (BANK 2 SENSOR 1)
PO 154 =02 SENSOR CIRCUIT NO ACTIVITY DETECTED (BANK 2 SENSOR 1)
PO 155= 02 SENSOR HEATER CIRCUIT MALFUNCTION (BANK 2 SENSOR 1)
PO 171= SYSTEM TOO LEAN (BANK 1)
PO 174= SYSTEM TOO LEAN (BANK 2)
I WOULD SAY YOU HAVE FAULTY OXYGEN SENSORS CAUSING THE ENGINE TO RUN TOO LEAN REPLACE THEM AND YOU SHOULD BE BACK IN BUISNESS
Feb 23, 2011 | 2004 Suzuki Grand Vitara
MY CAR WAS PUT ON A MACHINE AND IT CAME BAC THE FOLLOWING CODES: PO 301, PO304, PO335, AND PO 750. I DONT KNOW WHAT TO DO MY MECHANIC SAYS THAT THE SHIFT SOLENOID IS LOCATED IN MY TRANSMISSION AND HE...
hi p -codes are as follows po 301 cylinder 1 missfire detected
po 304 cylinder 4 missfire detected
po 335 crankshaft position sensor A circuit malfunctio
po 750 shift solenoid A malfunction
Feb 23, 2011 | Hyundai Sonata Cars & Trucks
Turbo Air TGM-5R Logo
167 people viewed this question
Top Turbo Air Refrigerators Experts
Dennis Boxerman
ray gallant
John Tripp
John Tripp
Are you a Turbo Air Refrigerator Expert? Answer questions, earn points and help others
