Question about Dryers
My ge front load electric dryer model pcvh640ej1ww turns itself off after you turn it on within a few seconds of turning it on
catriver
  • 878 Answers
SOURCE: Dryer turns itself on & beeps, then off again
aye, see if you can enter the diagnosis mode. What we are looking for is the F-02 code. This will flash when there is a stuck button or user interface problem and only displayed in the test mode. With the unit plugged in and all indicator lights off, select any button except stop. Press for 3 seconds, release for 3 seconds, press for 3 seconds, release for 3 secnds and press for 3 seconds. If you did it right 88 should appear. Press the same button again and if there is a error, it should show up. If no error code shows, open the consol and check the p-5 connector. This will be the interface ribbon to the board. Reseat it and see if the problem stops. Catriver
Posted on Jul 16, 2007
IFIXALL
  • 868 Answers
SOURCE: ge dryer makes grinding noise when drum is turning
If youve made sure that its not a roller thats dry or a belt idler pulley that dry,than yes its the motor,and oiling that will only make it worse.
Posted on May 21, 2008
Illeagle
  • 525 Answers
SOURCE: Frigidaire electric dryer
I was unable to locate a similar complaint through my service database, so this is going to be a hit or a miss answer.
This model has an electronic control board in it and it is possibly picking up a static discharge from your body and powering up the start relay. This may be due to improper grounding or a recent power issue. This type of failure apparently does not happen with a 240 volt appliance often enough to be in the books. I might suggest that you unplug the dryer for 10 minutes, then plug it back in to see if it corrects the problem. If not, you will want to have your outlet inspected by an electrician. You may also have to replace the control board, if the electrician finds the outlet satisfactory. You may also just want to consult a factory authorized servicer that would be capable of checking the outlet AND testing the board before replacing it.
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Posted on Jun 20, 2008
jumptrout51
  • 3361 Answers
SOURCE: Hotpoint Electric Dryer Model NBXR453EVOWW squealing when turned
Replace the drum support bearing at the rear of the drum.
Posted on Jun 11, 2009
  • 4088 Answers
SOURCE: GE dryer, model DBXR453EVOWW - squeaks at start up
It could be the rear drum bearing, or the belt needs replacement.
Posted on Aug 28, 2009
My LG Model DLEX3360 dryer will turn on, run about 20 seconds and stop running -- but displays still says it is drying.
Dryer Thermal Fuse Replacement - LG Electric ... - YouTube
? 5:29
https://www.youtube.com/watch?v=b74Mt5sSgRI
Dec 21, 2012 - Uploaded by RepairClinic.com
Dryer Thermal Fuse Replacement - LG Electric Dryer Repair (Part ... The most common reasons for replacing the thermal fuse are when the dryer won't start or ... I have an LG GAS DRYER model # DLGX8001V and it will not ... My front load dryer won'tturn on. .... My LG dryer recently stopped working.Missing: seconds
LG Electric Dryers, no heat? Try this first... - Home Forums
ths.gardenweb.com > Home Forums > Laundry Room
Apr 1, 2006 - I own an LG Electric Dryer model DLE0332W. ... Serviceman: The part you need is a heat regulator and its going to run you about $20 and the labor ... Look into the hole to the left and you will see the Heater Unit right within reach. .... Came back a second time because it still wouldn't dry my clothes (maybe ..
Nov 24, 2015 | LG Dryers
Tensioner pulley doesn't turn in my dryer
Try to turn the pulley by hand. If it is frozen up you will need to replace that assembly.
Jun 20, 2012 | Dryers
My GE DBSR453EB1WW electric dryer doesn't turn on. It worked fine yesterday morning for one load and when I put in my second load, it wouldn't start. It is plugged into the outlet and the breaker is fine....
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Nov 15, 2010 | GE DBSR453EBWW Electric Dryer
Dryer - GE model DRSR483 ED2WW Worked fine a few days ago with a light load. Now, just a loud beep when I try to start it. It doesn't come on. I can turn the drum manually (slowly) - almost sounds like...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
heatman101
Sep 01, 2010 | GE DBSR453EBWW Electric Dryer
Moved dryer out to reattach vent hose, now when turning on it buzzes for about 10 seconds then shuts itself off
Sounds like a poor electrical connection. Check where the cord connects to the dryer, and where the cord plugs in to the recepticle. Could easily be where the wires connect onto the recepticle.
Nov 06, 2009 | Whirlpool WED5100SQ Front-Load Electric...
I have an electric ge dryer. when i turn the
check the belt, it may not be tight enough around the drum and idler to engage the motor.
Oct 04, 2009 | Dryers
GE Profile Harmony Dryer Drum will not turn
the inertia switch on the shaft of the drum motor has failed This will require removal of the drum motor
Jun 01, 2009 | GE Profile Harmony DPGT750EC Electric...
GE Dryer Question
hi thanks for the question on the ge dryer the blower loosens off the motor shaft and then rubs on the front to check disconnect power open door a few screws on the inside of floor top remove screws lift top remove 2 screws on inside of front remove front set aside blower is on left see if the blower is too far forward if so loosen 3/8 nut push blower back tighten the nut good and tight re assemble and try te dryer thanks the appliance doc
Apr 17, 2008 | GE DBXR463EBWW Electric Dryer
Ge dryer shuts off
turn the drum by hand see if it turns fairly easy if it does then you may need to replace or clean the drive motor if not may need to service the tub rear bearing tub glides etc
Dec 30, 2007 | GE DBSR453EBWW Electric Dryer
Dryers Logo
85 people viewed this question
Top Dryers Experts
