Question about Boating
Replace lift belt onminn kota genesis 74 - Boating
2 Suggested Answers
SOURCE: minn kota maxxum 74 trolling motor
http://www.minnkotamotors.com/
800-227-6433
Posted on Feb 18, 2009
Only have a model number and need to order a Minn Kota electric motor propellor
Minn Kota go by the thrust which is mentioned on the top plate. I got mine off Craigs List as well.
  • Minn Kota Prop Compatibility Chart - TrollingMotors.net https://www.trollingmotors.net/blogs/selection/86967623-minn-kota... Minn Kota Prop Compatibility Chart Minn Kota Prop Charts. ... Minn Kota with a serial number and they can recommend a compatible prop for your older Minn Kota motor. ...
  • Minn Kota Motors www.minnkotamotors.com Prop Selection & Part ... Electric Anchor Winches; Shop All; APPAREL. ... A combination of a Minn Kota motor and foot controlled rudder steering allow you truly ...
  • Trolling Motor Replacement Props - Minn Kota www.minnkotamotors.com/Accessories/Trolling-Motor-Accessories/... Minn Kota builds the world's toughest ... Electric Anchor Winches; Shop All; APPAREL. Mens; Ladies; Youth; Shop All; WHAT MOTOR DO I NEED? LET US HELP YOU ...
  • Minn Kota Replacement Propellers - www.fishntech https://www.fishntech.com/minn_kota_propellers.html ... Minn Kota Electric Trolling Motor Replacement Propellers & Nut Kits, ... Minn Kota Replacement Propellers . ... Minn Kota Electric Trolling Motor Replacement ...
  • Minn Kota props replacement props for Minn Kota www.minn-kota.com/minn-kota/minn-kota-propellor/page/2 Minn Kota Replacement Props for propellor Weedless Wedge 2 Props ... Minn Kota MKP 3 Prop 2061151 ... MinnKota Trolling Motor Power Center $57.58; DeckHand Electric ...
  • MINNKOTA MKP 37 2091170 TROLLING MOTOR PROPELLER ' ... www.ebay.ca/sch/...nkw=MINNKOTA+MKP+37+2091170+TROLLING+MOTOR+P... Find best value and selection for your MINNKOTA MKP 37 2091170 TROLLING MOTOR PROPELLER ... MINNKOTA MKP 37 2091170 TROLLING ... MINN KOTA ...
  • Jun 08, 2016 | Minn Kota Endura 30 Freshwater Transom...
    My minn Kota deackhand 35 won't lift a 28lb anchor
    How heavy is the line that is attached to the anchor - you need to add that weight to the amount being lifted as well. Some general things to consider: Are you providing the correct voltage and current? Is the wire supplying the motor large enough - or is it getting hot? Check & clean as needed ALL connections at terminals, relays, etc for corrosion and tightness. Make sure the unit has been serviced and lubricated as required.
    Sep 29, 2015 | Minn Kota Boating
    Replace belt genesis upright
    Turn vacuum upside down on flat surface, remove the 6-7 screws from the bottom of the power nozzle, lay it on it's side and pry on the two accessible internal tabs to pop top cap of the nozzle off to access the pn motor assembly. Lay flat on it's back again and remove the screws that hold the roller brush in, remove the roller brush, remove old belt, install new belt on brush roll and pn motor geared spindle, push brush roll back in place, replace screws and pn top and VOILA!..you're back in bidness! Hop that helps!
    Jun 25, 2014 | Electrolux Vacuums
    My minn kota 70lb thrust motor is 2 years old. Brand new batteries and it will turn left & right, but the prop will not work.????
    Minn kota 74 lbs. prop runs when head turns when rotating motor from centre to right, but stops when you turn motor from centre to left. The light on top stays on.
    Aug 30, 2010 | Minn Kota Maxxum 70 Freshwater Bow Mount...
    I just bought a 74 lb Minn Kota trolling motor that is 24 volt. It is used and has 4 wires (2 black & 2 red) coming from rolling motor. Can you please tell me how the wiring is connected to the...
    I have uploaded a image of the wire system. folllow it carefully. the fuses rating should be no more than than thirty amp. go to your local outboard dealer they sell inline breakers that are designed for trolling motors. i prefer them because you don't have to replace them after a overload. you just reset the breaker.de79e02.jpg
    Oct 29, 2009 | Minn Kota Riptide St Saltwater 80 Bow...
    My trolling motor maxxum 74# thrust feels like i have broken something in the shaft. It is almost impossible to turn and everything in the head looks fine (cables,gears,etc.). What is in the shaft that...
    Here's a schematic for your motor:
    Maxxum 74 Bowmount
    I suspect the the bearings and cups are damaged and binding the tubes. Have a look at key #'s95, 78, 58, 59, 78A, 79. as these are the actual brgs and cups.
    Good luck on your repair!
    Mike
    Sep 23, 2009 | Minn Kota Maxxum 70 Freshwater Bow Mount...
    TOOK THE BOLTS OUT OF MINN KOTA AND CANT GET THEM IN. 2 SHORT.
    Hi!
    Here's a schematic:
    Max 74 Bowmount
    Make sure the end housing #7has a small mark in it pointed to the bottom (towards the skeg). The bolts can be a pain to line up!
    Also make sure the armature is all the way forward it can go....past the brushes is the toughest part to get through and lined up. Keep it up, you'll get it!
    Best of luck
    Mike
    Jul 05, 2009 | Minn Kota Maxxum 55 Freshwater Bow Mount...
    Minn kota 68pd motor
    Your armature has a dead spot. Either replace it or get a generator rebuild shop to test it on a growler, and fix the open winding. You can do it if you ohm between ajacent brush blocks and re-stake the wire clamp on any that ohm over 1 ohm. You MIGHT only have a dirty commutator which can be solved with crocus cloth.
    Aug 12, 2008 | Minn Kota 74 AutoPilot Motor/Sonar Combo...
    Boating Logo
    109 people viewed this question
    Top Boating Experts
    Steve
    Steve
    ray gallant
    Andrew Taylor
    Andrew Taylor
    Are you a Boating Expert? Answer questions, earn points and help others
