Question about Measuring Tools & Sensors
Intermittent beep on 2202 voltage tester
Intermittent beep with circuit breaker off. What does that mean?
  • 1462 Answers
SOURCE: Intermittent Beep
check door switch is operating and the light switches off. an easy way is to prize back the seal a bit with door closed and if light is still on you can see it
Posted on Jun 21, 2007
  • 107 Answers
SOURCE: Frigidaire gas wall oven clock unit sometimes says F1 and beeps.
F-1 is USUALLY a touch pad error, it thiniks something is stuck. The sensor error code is F-3.
Posted on Mar 17, 2009
  • 744 Answers
SOURCE: Intermittent Power fading on all electrical circuits
This sounds like a bad connection somewhere. If you are comfortable working on electrical equipment, remove the main circuit breaker panel cover and sometimes an inner cover depending on the panel make.
Turn off the breakers one at a time - Check the wiring connections on ALL circuit breakers after they have been turned off. It's not unusual for wiring to loosen up on breakers after several years. Tighten all the screws where the wires are attached, usually with a flat-blade screwdriver. Then tighten all the white wires attached to the neutral buss. If you see any green wires, tighten them too.
Look for any burned or discolored wires, indicating that something is loose or overloaded. Do not place your other hand on anything metal while you tighten the wiring and use an insulated screwdriver. The best bet is to put your free hand in your pocket so you don't lean on something grounded accidentally.
You should also check the wiring on the main breaker to the home, but this can be dangerous and should only be done by trained personnel. This task may require removing the electric meter outside your house. It's even possible that the wiring on the primary side of the meter is loose - if it looks burnt, call the utility company - they will usually respond to this issue.
Hopefully, tightening all the wiring on the breakers will solve the problem. Residential circuit breakers are usually "stab" type, meaning they ""stab" onto the phase busses.
Above all, please be careful. If you aren't sure, it's usually best to call a licensed electrician.
Ask again if you need more help.
Posted on Mar 31, 2009
brnspncr
  • 67 Answers
SOURCE: Intermittent tripping of circuit as oven just reaches temp
Sounds like the oven element is cracked and absorbing moisture when the oven cools down thus causing it to trip. Should buy a new element. there are hundreds of suppliers on the internet.
Posted on Jun 11, 2009
  • 97 Answers
SOURCE: I have a bad circuit (S type 15 amps fuse) that
please describe what type of device or circuitry you are having the fuse repeatedly blow so that I have a better idea of understanding your specific circumstance. A constant blown fuse normally indicates a short somewhere or an overloaded circuit somewhere. The type of tester you need is a ground fault receptacle tester you can purchase them at any hardware/electrical supply store for between $10-15 that tester when plugged in will show whether you wiring is correctly installed or not. please respond with further info and I can be of more assistance
Posted on Aug 07, 2009
What does the error code PO119 mean on my 2013 arctic cat 500 atv mean
From Repair Pal:
Auto Systems and Repair
Engine Coolant Temperature Circuit Intermittent Our emissions expert has put together the following information about the P0119 fault code. We have also included diagnostic procedures you can take to your repair shop if the mechanic is having difficulty analyzing the code.
OBD II Fault Code
  • OBD II P0119
Fault Code Definition
  • Engine Coolant Temperature Circuit Intermittent
What does Mean?The Engine Coolant Temperature Sensor measures the rise and fall of the Engine Coolant Temperature. This provides critical data needed for the Powertrain Control Module (PCM) to control the Air Fuel Ratio, the Ignition Spark Timing, the cooling fans, and many components of the Emissions Control Systems. The Engine Coolant Temperature Sensor converts the coolant temperature into a voltage that is high when the engine is cold and low as the engine warms up.
Code P0119 indicates an intermittent voltage input from the Coolant Temperature Circuit to the PCM.
Sep 16, 2014 | Arctic Cat 2013 500 TRV Core
WHAT DOES P0123 MEAN?
SYMPTOM
P0123-THROTTLE POSITION SENSOR VOLTAGE HIGH
WHEN MONITORED
With the ignition ON and battery voltage above 10.4 volts .
SET CONDITION
Throttle Position Sensor voltage at the PCM goes above 4.5 volts for 3.2 seconds .
POSSIBLE CAUSES
  • Clock spring shorted
  • Throttle position sensor sweep
  • Intermittent condition
  • Throttle position sensor signal circuit shorted to 5 volt supply circuit
  • Throttle position sensor signal circuit shorted to battery voltage
  • Throttle position sensor internal failure
  • Sensor ground circuit open
  • Throttle position sensor signal circuit open
  • PCM
hope this helps, Tim 423 327 4108
Jun 06, 2014 | 2001 Dodge Dakota
Winshield wiper delay intermitent module making noises
The wiper delay is in the steering column. It's a small box about 2 x 2 inches with a wiring harness attached. With the testing procedures I found below, you should be able to figure it out. I found wiper delays on eBay for around $10 to $20. Good luck.
WINDSHIELD WIPERS CHEROKEE, COMANCHE & WAGONEER 1. POWER INPUT Remove circuit breaker. Test battery side of circuit breaker. If battery voltage is not present, repair open to splice. Test across circuit breaker terminals. Tester reading should be zero (0) ohms. If not, replace circuit breaker. 2. GROUND Connector A unplugged. Test terminal G. Tester reading should be zero (0) ohms. If not, repair open to ground. 3. INTERMITTENT WIPERS Ignition switch in ACCY. Remove delay module and plug connectors together from the module. If wiper operate in LO and HI speed modes and mist (washer) is working, if wipers and mist operate, replace intermittent module. If not go to step 4. 4. WIPER/WASHER SWITCH Ignition in RUN, wiper switch position as indicated, back probe switch side of connector A for standard, connector B for intermittent: Test connector terminal E-wiper switch in LO and mist/intermittent. If battery voltage is not present, replace switch. test connector terminal C-wiper switch in HI. If battery voltage is not present, replace switch. Test connector terminal F-wiper switch to OFF. If battery voltage is present until wipers stop and then voltage drops to zero (0), system is working fine. If this does not occur, replace switch. 5. INTERMITTENT WIPERS Connector B unplug. Test across terminal A and D while rotating switch from minimum to maximum delay. If tester reading is not between 0-500 ohms, replace switch. Test across terminal A and G while rotating switch from minimum delay to maximum delay. If tester reading is between 0 and 500 ohms, replace wiper module. If not replace switch. 6. WIPER MOTOR Ignition in ACCY, wiper switch position as indicated, probe connector D. Test connector terminal 1. If resistance is no zero (0) ohms,repair open to ground. Test connector terminal 4-wiper switch in any position. If battery voltage is present, replace motor. if is not repair open from fuse panel. Test connector terminal 2-wiper switch in LO. If battery voltage is present, replace motor. If not , repair open from wiper switch. Test connector terminal 2-wiper switch in HI. If battery voltage is present, replace motor. If not , repair open from wiper switch. Test connector terminal 5-wiper switch OFF with voltmeter connected. If battery voltage is present until wipers stop and then voltage drops to zero, system is OK, replace motor. If not, repair open from wiper switch.
Found on the web. I hope this helps.
Rich Long
Jan 26, 2014 | Jeep Cars & Trucks
Ford airbag code 54
94+ AIR BAG DIAGNOSTIC TROUBLE CODES/CLEARING
Code Component/Fault Description
No Air Bag Indicator - Inoperative Indicator Circuit
Continuous Air Bag Indicator - Diagnostic Trouble Code Timed Out, Diagnostic Monitor Disconnected or Inoperative, or No Ignition Voltage to Diagnostic Monitor.
12 Lost Battery Feed
13 Air Bag Circuit Shorted to Ground
14 Primary Crash Sensor Circuit Shorted to Ground
21 Diagnostic Monitor Not Mounted to Vehicle Properly
22 Safing Sensor Output Circuit Shorted to Battery Voltage
23 Memory Clear Circuit Improperly Grounded
24 System Disarm Failure or Internal Diagnostic Monitor Fault
32 Driver Side Air Bag Circuit High Resistance or Open
33 Passenger Side Air Bag Circuit High Resistance or Open
34 Driver Side Air Bag Circuit Low Resistance or Shorted
35 Passenger Side Air Bag Circuit Low Resistance or Shorted
41 RH Radiator Primary Crash Sensor Feed/Return Circuit Open
42 LH Radiator Primary Crash Sensor Feed/Return Circuit Open
44 RH Radiator Primary Crash Sensor Not Mounted to Vehicle Properly
45 LH Radiator Primary Crash Sensor Not Mounted to Vehicle Properly
52 Intermittent or Repaired Lost Battery Feed
53 Intermittent or Repaired Air Bag Circuit Shorted to Ground
54 Intermittent or Repaired Primary Crash Sensor Circuit Shorted to Ground
61 Intermittent or Repaired Diagnostic Monitor Not Mounted to Vehicle Properly
62 Intermittent or Repaired Safing Sensor Output Circuit Shorted to Battery Voltage
63 Intermittent or Repaired Memory Clear Circuit Improperly Grounded
64 Intermittent or Repaired System Disarm Failure or Internal Diagnostic Monitor Fault
72 Intermittent or Repaired Driver Side Air Bag Circuit High Resistance or Open
73 Intermittent or Repaired Passenger Side Air Bag Circuit High Resistance or Open
74 Intermittent or Repaired Driver Side Air Bag Circuit Low Resistance or Shorted
75 Intermittent or Repaired Passenger Side Air Bag Circuit Low Resistance or Shorted
81 Intermittent or Repaired RH Radiator Primary Crash Sensor Feed/Return Circuit Open
82 Intermittent or Repaired LH Radiator Primary Crash Sensor Feed/Return Circuit Open
84 Intermittent or Repaired RH Radiator Primary Crash Sensor Not Mounted to Vehicle
85 Intermittent or Repaired LH Radiator Primary Crash Sensor Not Mounted to Vehicle
Rapid Continuous Flashing of Air Bag Indicator (No Diagnostic Trouble Code) Both Primary Crash Sensors Disconnected Assembly Plant Mode
TROUBLE CODE CLEARING
1. Follow the diagnostic procedures to service the fault condition flashing on the air bag indicator prior to code clearing.
2. Cycle the ignition switch to OFF and then to RUN.
3. Observe air bag indicator prove-out (six ? two seconds) followed by diagnostic trouble code (52-85) flashing completely one time.
4. Locate the Diagnostic "Trouble Code Clear" Connector (grey connector). located underneath the glove compartment, left side (06010) containing Circuits 631 (T/R) and 57 (BK).
5. Use a jumper wire to short Circuit 631 (T/R) to Circuit 57 (BK) or to another good ground. This short must be made after the diagnostic trouble code flashes completely one time, but before the warning light stays on continuously.
6. Hold short until air bag diagnostic monitor tone sounds (approximately five seconds).
7. Release short on Circuit 631 (T/R) to Circuit 57 (BK). This short must be released within 25 seconds after the diagnostic monitor tone sounds.
Diagnostic trouble code is now cleared from memory. Next highest priority diagnostic trouble code stored (if one exists) will begin flashing.
The codes and clearing proceedure above are to be used as a guide, NO claims are implied as to the correctness or accuracy of either.
Sep 11, 2013 | Cars & Trucks
Er 8 code on 90T lifefittness treadmill
A motor control failure had been detected. This prevent to the motor goes on. This happen to the intermittent failure power loss in the line.
Do not use any extension Power cord, or some circuit, where there many devices connected. Use a clean circuit from directly panel circuit breaker and if is possible use stabilizer voltage.
God bless you
Jun 06, 2013 | Exercise & Fitness
2002 Taurus: 2002 taurus has p1633 code. what does it mean...
The code is for ( Keep Alive Power Voltage To Low ) Description: is the KAPWR has experienced a power interrupt. Possible problems: Open KAPWR circuit... Damaged PCM ...or a intermittent KAPWR circuit
May 18, 2010 | 2002 Ford Taurus
I have a circuit breaker that is intermittent
It is unlikely that those temperatures would cause the circuit breaker to shut off and come back on intermittently. (If the breaker trips it has to be reset manually.) It is possible that the breaker is defective internally or that there is a loose connection in the wiring. If you are not knowledgeable about electrical work you should have an electrician check it out for you.
Nov 25, 2009 | Electrical Supplies
Siemans fxd63b225 breaker trips,56amps A phase, 49amps B phase, 48amps C phase, adjustable trip at 6, all lugs tight. breaker is main for 277v lighting panel.???
How long does the breaker hold after resetting? You probably have an 'intermittent ground fault' . If the breaker just trips randomly. One way to locate it would be a megger test on all three phases going out to the loads. Any phase that shows a possible ground could help narrow it down. Sometimes, if possible, you can turn certain breakers off and see if your problem goes away.A meter in record mode could be the best solution. Fluke meters have this option and you could monitor the phase voltage and during a 'ground fault' the voltage will drop some and you'll lock in the dip on the meter.
Jul 14, 2009 | NRS Siemens Fxd63s250a Circuit Breaker...
DTC Codes
P0113-Intake Air Temperature (IAT) Sensor Circuit High Voltage
P1111-Intake Air Temperature (IAT) Sensor Circuit Intermittent High Voltage
I am unable to dig up any C code with that number.
Sep 04, 2008 | 1997 GMC Sierra
JMC7000ADW Blows circuit breaker
I've had this problem twice with our microwave. The hint to where the problem lies is that the breaker blows when you open the door at times. Inside the microwave are three microswitches; primary and secondary interlock micro switches and an Interlock Monitor switch. The switches are supposed to shut down the microwave if it is running and the door is opened. But, I've found the upper primary switch can stick internal at times and when the door is opened the stuck switch will, because of the way it is wired as a safety switch, cause either the fuse or possibly the main circuit breaker for the oven to pop. The reason the stuck switch blows the breaker or fuse is when the door is opened the interlock switch will cause the neutral wire from the AC power to be applied to the Upper Primary Interlock switch which normally should be open when the door is opened, but if the switch is intermittent or the contacts weld themselves shut the neutral line is connected direct to the "hot" side of the power line through the fuse and thermostat. The first time my microwave failed the switch had melted the contacts together inside the switch and the second time the switch became intermittent and would blow the breaker to the over ever so often. I suspected the switch the second time this happened and utilizing an ohm meter I checked the switch several times by opening and closing the door and once in a while it would remain closed instead of opening when the door was opened. Of course while trouble shooting the power cord to the microwave must be disconnected and use all safety precautions when working around the high voltage areas inside the microwave. I wrote Jenn-Air about the bad switch and the way it is wired into the circuit, but never received any acknowledgement. I suspect these microswitches are under rated for the amount of current that passes through the switch, thus they overheat and eventually arc the contacts together. I hope this helps explain the intermittent problem and could explain many of the intermittent blown fuse problems I see in these internet help sessions
May 09, 2008 | Jenn-Air JMC7000 Microwave Oven
Measuring Tools & Sensors Logo
79 people viewed this question
Top Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Measuring Tool and Sensor Expert? Answer questions, earn points and help others
