Question about Kenwood KDC-132 CD Player
No sound when hooked up
Every thing is hooked up but the mute wire.It seems to be working find other wise
How do i take a chrysler corporation model no. P04704383AE and replace with a jvc radio when the 4 extra wires are ill park mute and ant ... do i hook these wires to something els ?
Stop by a sound shop for auto's or most parts stores and they should have an adapter that plugs in to convert one to other automatically and not have to guess or play with existing wiring.
Jan 29, 2015 | Dodge Dakota Cars & Trucks
No Sound from Jensen VM9725BT
Jimmie Monica Hey, Its not a problem with the unit. You have the blue or Blue/White wire hooked up wrong. Disconnect both the blue wire and the blue and white wire and I guarantee the sound starts working on everything. If you have one of those two wires hooked up for a power antenna or remote amp turn on, then switch which one you are using and that will fix the problem permanently. Disconnecting them both will get it to work though. I guarantee it. Please post back and let me know if it works for you. Thanks
Sep 06, 2013
Feb 22, 2013 | Jensen VM9725BT Navigation receiver
Home Theatre system goes into MUTE mode while film playing
Sounds like your system is going into a safe mode. This happens when you have a neg/pos reversed hooked up, or your wires are touching. This feature prevents you from blowing up your amp. Check your wires, and make sure the positive is hooked to positive etc. and make sure no bare wires are touching.
Sep 01, 2009 | Audio Players & Recorders
No sound from radio, display works, speakers work, wires correct
do you have an amp hooked up to your car stereo ?
Apr 25, 2009 | Car Audio & Video
Jensen vm9511ts cuts out
It sounds like the phone mute is going on and off, but I'm just guessing because I don't know your grounds, speaker wire hookup configuration, etc. Look at the screen when the music cuts off and goes back on and if you see a little red phone with the cross through speaker symbol (aka mute) it's probably the phone mute feature which is supposed to be hooked up to bluetooth and mute the stereo when you get a call. Like I said I'm just guessing, but if so there's a brown wire in the back that needs to be hooked up.
Jun 19, 2008 | Jensen VM9511TS AM/FM/CD/DVD/SD Player/7"...
Razr V3 No Sound When Hooked to a Charger
Seems like some setting on the phone is muting your ringer when connected to the charger.
You can try resetting your phone (will default your settings), just be sure to back-up your content (music, phonebook, pics...) first.
Jan 11, 2008 | Motorola Mobility V31 RAZR GSM Cell Phone,...
CD player that doesn't play
I had the same problem.
I cut the orange wire which went into the black connecter block
and WOW I had sound...
brilliant
thanks a lot
Andy - North Yorkshire, England
Oct 11, 2007 | Panasonic CQ-C1303U CD Player
Kenwood KDC-132 CD Player Logo
23 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
