Question about Garden
Swisher trailmower t1360b1 wont start unless i jump the solenoid. They told me the solenoid was bad. I've replaced it, and the fuse, nothing has changed...whats my next course of action?
3 Suggested Answers
  • 11 Answers
SOURCE: I need replacement parts for my 60
try e-bay
Posted on May 05, 2010
wvbiker59
  • 23 Answers
I RECENTLY BOUGHT A USED SWISHER FOR $700 13.5 HP 60 INCH I BELIEVE THE MODEL IS 1340D? I'M HOPING I DIDN'T GET RIPPED OFF AND THIS IS SOMETHING SIMPLE..I THINK THAT'S THE MODEL NUMBER I'M NOT EXACTLY SURE THE STAMP O N THE SIDE ISN'T TO LEGIBLE , ANYWAY WHEN I SPRAY STARTING FLUID INTO THE AIR FILTER IT RUNS BUT THEN STOPS. IT HAS A NEW BATTERY, FUEL LINE AND FILTER AND I JUST TOOK THE CARBURETOR OFF AND SPRAYED IT OUT WITH GUNK CLEANER TO NO AVAIL. THE FLOAT BOWL WAS REALLY CRUDDY. I'M WONDERING WHERE I CAN GET A NEW CARB? ARE THEY AVAILABLE? IF SO WHERE? THANKS
Posted on May 14, 2016
What could keep it from cranking?
change solenoid. check for voltage just because it is new it might be bad
Jul 16, 2014 | Swisher T14560 T - 60" Trailmower with 14...
How to replace belt
SWISHER 44 Finish Cut Trailmower Tension assembly belt bra Parts Model...
If you look at the diagram ( zoom in) part #94 , idler spring, is what puts tension on the belt.
Jun 07, 2014 | Swisher 44 Iinch 11.5 Hp Trailmower...
2009 zt bad boy wont start unless you jump solenoid which is new starter is rebuilt relay replaced . Ignition switch new replaced . wont turn on with key - jump solenoid fires up runs then pops the 25...
if you are blowing fuses then you have something shorted out or connected wrong. before you spend more money throwing parts at it get a wiring diagram and ensure the wires are good and connected right
If you need further help, I’m available over the phone at https://www.6ya.com/expert/kelly_69a0cf1b13789df1
Sep 28, 2013 | Garden
11.5 hp mower wont start
do you have spark?do you get spark with the connector on the side of the engine off if so the safety switch is bad does it fire on starting fluid?like there is a carb problem?
Jul 02, 2012 | Swisher 44 Iinch 11.5 Hp Trailmower...
Swisher 60
Sadly without the ability to physically test any of it , Fixya can offer nothing .
Oct 06, 2017 | Cars & Trucks
What size belt for my swisher 44" pull behind
I just replaced the belt on my 44" Trailmower and since I had to get it up and running without waiting for new Swisher 4220 belt I found an ordinary V-belt 1/2"X72" whith overall with of 74" works OK
Jun 28, 2011 | Swisher 44 Iinch 11.5 Hp Trailmower...
I need replacement parts for my 60" Swisher Trailmower / model T1360B1 When I went to the Swisher website, it says its obsolete. Where can I get parts.
May 05, 2010 | Swisher 60" 13 Hp Trailmower #T1360h
I have a pull start swisher trailmower. The cord
the cord could be tanlged up, pull it all the way out and make sure it is round the "bobbin" and not slipped off the side on the shaft. you wight be able to slip it back onto the bobbin with a screwdriver or piece of hooked wire - Also you are using the proper mix of 2 stroke and fuel?, 50:1 fuel to oil, or more for older.worn engines, say 40:1 for old engines, they run better like that - smell nice too.
apart from that... oil the puller mechanism, normal engine oil will do the trick - it can only help.
Jan 26, 2010 | Swisher 44 Iinch 11.5 Hp Trailmower...
My swisher pull behind was working fine and I was
take the cover off above the ignition switch ckeck 4 loose wires if nothing is found wrong jump it at the selinoid if it starts go to the nearest perts store and buy a selinoid for an ole ford truck transfer wire exact and it should wrk fine
May 03, 2009 | Swisher 60" 13 Hp Trailmower #T1360h
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
