Question about Troy-Bilt 12avb29q711 Tb260 21-inch 160cc Honda Gcv160 Gas Powered 3-
Mower starts but won't stay started - Troy-Bilt 12avb29q711 Tb260 21-inch 160cc Honda Gcv160 Gas Powered 3-
Why does my Cub cadet mower blade stops and not restart?
check for worn belt or tensioner not being tight enough. check for a failed bearing on a cutter spindle.
Jun 16, 2013 | Garden
My cub cadet zero turn won't run. Changed pluggs
Try cleaning the carburetor that might mean that it is not getting gas
Apr 17, 2013 | Garden
Won't stay running
sounds like carburetor is clogged or has something in the jets or possibly fuel line or tank is clogged. check fuel tank and line to make sure fuel flows easily then carburetor cleaning and rebuild may be required
Aug 24, 2012 | Mtd 22" Yard Machine Push Mower
Not Staying Started
I can't tell you how many pieces of small equipment I have been given for free because it "just won't start" or "won't stay running". Start by draining the tank and cleaning it out - use a good carb cleaner. It only takes a grain of sand to create a problem. You may have to take the carb apart and clean that out too.
Aug 01, 2012 | Husqvarna 7021 21Inch 160cc Honda GCV Gas...
Where is the primer ball
It may not have a primer ball. If it does, it would be attached to the carberator. If it starts, but won't stay running, that could mean your carberator needs to be cleaned/serviced.
May 29, 2012 | Mtd 22" Yard Machine Push Mower
Engine starts but won't continue to run. Choke doesn't stay closed after starting. will stay running only if I hold choke closed manually.
let it warm up with choke closed manually after it starts to stall with choke closed open it and dont let it stall u can learn to play with the choke a little to get it to run right GOOD LUCK!
Aug 14, 2011 | Toro Lawnmower 20099 Mower Mowers Lawn
Mower starts but won't stay running
check the inside of the cap. Check the underside of the gas cap for a cardboard disk. Remove the disk, and try starting again. My mower had same problem, and I removed the disk and suddenly it ran like there was no problem at all.
Aug 13, 2011 | Mtd 22" Yard Machine Push Mower
Start, won't stay running
check fuel plug. nut holding on silver fuel bowl
Jun 24, 2011 | Briggs & Stratton Garden
Troy-Bilt 12avb29q711 Tb260 21-inch 160cc Honda Gcv160 Gas Powered 3- Logo
23 people viewed this question
Top Troy-Bilt Garden Experts
Jay Finke
Jay Finke
Jim Parker
Jim Parker
Are you a Troy-Bilt Garden Expert? Answer questions, earn points and help others
