Question about Micro Electronics PowerSpec 8250 PC Desktop
I have no sound from the speakers while using a microphone xp pro
My system has an onboard sound card. I use a usb microphone to use dragon systems. After in started using the microphone I now have no sound from speakers. The system utilizes xp pro.
  • 25 Answers
I had the same problem. sorry to say i didn't. save info .go to google engine and type in 'no sounds from speakers' the advice came from a fellow named 'William'. you actually delete your sound system, in spite of the warning you get, then upon rebooting ,the computer looks for sound drivers for your system. if your computer is old , there might be no new drivers available.
Posted on Mar 12, 2009
Need drivers for the sound system for my pc w/XP Pro
Just install a sound card .. i prefer Sony sound card...
That will allow to work the speaker..
May 30, 2010 | Cyber Acoustics A-3780 Computer Speakers
No sound
Check if the speakers are working. If they are the next thing to check is the drivers for the sound card are installed.
Apr 09, 2010 | Microsoft Windows XP Home Edition
What do the 4 color coded openings in the back of the sound blaster card mean? What plugs into which opening?I've got a Dragon dictating system microphone that has different colors. I'm away from home whee...
Hi, I know of three of your colors which may be the following.
blue.....Aux port
green...Soud (use this for your Dragon sound)
pink......Mic (this will be use for your Dragon connection mic.)
let me know if it worked.
WBTech
Jan 14, 2010 | Dell Sound Blaster Card
Connected to laptop with vista via USB connection to speakers - NO sound
A letter from Altec: E-mail from Altec Lansing explaining how to use the ACS 495 speakers with Windows XP and Vista: "These speakers require no special drivers or software to work properly. At the current time we do not have AMS software or an USB audio device driver compatible with Windows XP or Vista. There are no plans at this time to develop this software. Your speakers will work with Windows XP & Vista. Just make sure you use the audio cable from the back of the subwoofer to the audio or sound out port of your sound card. Do not use the USB cable. Sound does not come through the USB port The USB cable just allows you to use the AMS software. This software gives you some control over some of the sound features. The same functionality of the AMS software can be gotten by using the buttons on the speakers and the volume control software that comes with your Windows system. If you double click the speaker icon from the system tray, that will open this software up. With the USB connector removed or the computer turned off, STEREO or PRO LOGIC modes can be selected by depressing and holding the center control down for approximately three seconds. The mode selected will be indicated by the color of the LED on the front right speaker. When the light glows yellow it is in the STEREO mode. When the light is green it is in the PRO LOGIC mode."
Nov 09, 2009 | Altec Lansing ACS 495 Computer Speakers
I think I need a driver for a Mikomi headset with mike.
mikomi head and mic set drivers for xp pro meed pls
Mar 18, 2009 | Audio Players & Recorders
Configuring two soundcards for parallel functioning
a windows computer can only use one sound card for one function
you can use the internal sound card for output
you can use the usb sound card for input / recording.
you can't use both for both.
Start -> control panel -> sounds and audio devices properties
open up audio page
You can have one device selected on Sound playback
You can have one device selected on Sound recording.
you can change which sound card is used for which function on this page. if you want to use the internal sound card set both settings to the internal if you want to use the external change both settings to the external.
Jan 09, 2009 | IBM Lenovo ThinkCentre M55e PC Desktop
Skype
Audio Setup for Windows XP and Vista
1. Audio settings, in Windows and Skype
XP: Windows Control Panel / Sounds, Speech and Audio Devices / Sounds & Audio Devices
or Right-click speaker icon in system tray and select "Adjust Audio Properties"
Volume / Device Volume: Make sure “Mute” is NOT checked in this window.
Volume / Device Volume / Advanced: If there is no “Microphone” section in this window, go to Options / Properties and check “Microphone” in the “Playback” list. Then make sure “Mute” IS checked in this window
Audio / Sound Playback: Your on board sound/Sound Card
Audio / Sound Recording: Your on board sound/Sound Card
Audio / Sound Recording / Volume: Make sure "Microphone" is selected and the volume slider is at the center or higher
Audio / Sound Recording / Volume / Advanced: If “Microphone Boost” or “20db Boost” is present, select it
Vista: Windows Control Panel / Hardware and Sound / Sound / Manage Audio Devices
or Right-click speaker icon in system tray and select "Playback devices"
Playback: Your speakers or on board sound/Sound Card must appear in this list, and must show “Working”
Playback: Select your speakers or on board sound/Sound Card, then click “Set Default”
Playback / Properties / General: Device Usage: “Use this device (enable)”
Playback / Properties / Levels: “Mute” is not on, volume slider in the middle
Recording: Your Microphone or on board sound/Sound card must appear in this list, and must show “Working”
Recording: Select your Microphone or on board sound/Sound Card, then click “Set Default”
Recording / Properties / General: Device Usage: “Use this device (enable)”
Recording / Properties / Custom: If “Microphone Boost” is present, select it.
Recording / Properties / Levels: Microphone volume should be centre or higher
Recording / Properties / Levels: If there is a “Mute” button, it must not be on
Skype / Tools / Options / Audio Settings:
Microphone: Your headset/mic or USB device or Web cam mic, as you prefer
Speakers: Your headset, USB device or speakers, as you prefer
Ringing: VoIPVoice USB Phone or on board sound/Sound Card; also tick Ring PC speaker
Note: The audio devices you want to use MUST be present in these Skype device lists. If they are not, check the device connections and driver installations again.
2. Microphone and Speaker connections
Check if your mic (pink) and speaker (lime) jacks are in the proper sockets (it is easy to reverse them) and fully inserted (they sometimes stick only partially inserted)
If your microphone or headset has a “Mute” switch, make sure it is not on
If your speakers or headset has a volume control, make sure it is turned up
For test only you can use an earphone instead of microphone (really)! Just unplug the microphone, plug the earphone into the microphone jack, and talk into your earphones. (I know it sounds silly, but it might tell you if your microphone is defective)
A standard microphone plugged into Line In will NOT work.
3. Check audio in Windows.
XP: Start / All Programs / Accessories / Entertainment / Sound Recorder
Vista: Start [Orb] / All Programs / Accessories / Sound Recorder
Make a short recording with the microphone; you should see the level meters moving as you speak. On Windows XP, you can then play back what you recorded.
4. Once done, test with Skype Test Call (echo123).
Oct 19, 2008 | Computers & Internet
Audio on motherboard not working.
If the southbridge chipset is intact and operational, either physically open the case and see if you can visually see the chip set #,
or my favorite, download and run everesthome,
click on + by motherboard
click on chipset
click on southbridge in right column,
google the chip set drivers or the audio control set drivers
or click on the "ask me " under my id .and give me the #'s I'll link you to the updated drivers.
Mar 30, 2008 | Intel DG965WH Motherboard
Possible sound card problem?!
To the best of my knowledge this could be a sound card driver problem. Try updating your sound driver. If that doesn't work uninstall the driver and get the updated version on the net.
If your not sure how to do this come back and let me know.
Dec 10, 2007 | ASUS A8V-E Deluxe Motherboard
Micro Electronics PowerSpec 8250 PC Desktop Logo
89 people viewed this question
Top Micro Electronics Computers & Internet Experts
Dennis Maeder
RSole
Masood Rasool
Level 1 Expert
Are you a Micro Electronics Computer and Internet Expert? Answer questions, earn points and help others
