Question about Microwave Ovens
Tappan tmv151fs microwave bulb blown - Microwave Ovens
  • 135 Answers
SOURCE: Light bulb replacement in a Tappan Microwave
Hi Mike.
Difficult to say on yours. You may try the following. On the back or side, if there is a little cover that's screwed into the panel. Otherwise browse around on the inside. Be sure to unplug the micro before checking. Once found be sure to replace with a microwave lamp and not a fridge lamp. There is a difference. Good Luck,JUS004
Posted on Feb 29, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: User manual for a Tappan mod TMV151FS
You can download your owner's manual here.
Posted on Jan 01, 2009
MicrowaveSvc
  • 9098 Answers
SOURCE: filter replacement
That's covered on page 20 & 21 of your owner's manual under the heading"CHARCOAL FILTER REPLACEMENT"
1. Unplug oven or turn off power at the main power
supply.
2. Open the door.
3. Remove the two vent grille mounting screws. (3 middle screws)
4. Slide the grille to the left, then pull straight out.
You can find helpful exploded view diagrams and order parts (including filters) by entering your full model number from the tag on the oven here.
Posted on Feb 17, 2009
  • 4088 Answers
SOURCE: Tappan TMV151FS over range microwave starts to work and then dies
Never run the microwave without a load (something to heat)!!! That kills the microwave generating parts.
Sounds like a 'thermal' protect switch is activating after running. Make sure that (if the unit is mounted in a cabinet) that there is sufficient space around the unit for proper air flow and that nothing is blocking the vents. Try setting it on a counter top and heat something. If it works properly and doesn't shut off, the venting space is the problem. You may have to have the cabinet that it sits in redesigned for more clearance.
Posted on Aug 19, 2009
hardrocko
  • 1476 Answers
SOURCE: Tappan over range has no heat!
You have a bad high voltage diode, bad filter capacitro or a bad magnatron. The diode and capacitor does not cost very much. You can get them at www.mcmelectroncs.com . Replacement would mean removing the unit from under the counter, remove the case. Locate the diode and capacitor. They should be near the power section and the diode is attached to the chassis and one side of the filter capacitor. After replaceing both parts if the unit will not heat you would need a new magnatron. The part is fairly expensive but depending on the cost of your unit it may pay to replace it. Let me know if you need anymore help.
hardrocko
Thanks for using FixYa
Posted on Feb 27, 2010
Tappan Electrolux tmv151fs microwave/rangehood. turntable and cavity light intermittent (but work/fail in unison), all else work ok
Either a wiring problem or worn contacts on the relay that powers the two would be possibilities.
Nov 24, 2016 | Microwave Ovens
Everything on our microwave works except the most important part-its not heating. TMV151FS
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic
Microwave Oven Troubleshooting Tips
heatman101
Mar 09, 2011 | Tappan Microwave Ovens
hardrocko
Feb 27, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Aug 19, 2009 | Tappan TMT104E1 Microwave Oven
Filter replacement
supply.
2. Open the door.
Feb 16, 2009 | Tappan TMT104E1 Microwave Oven
Jan 01, 2009 | Tappan Microwave Ovens
Microwave Ovens Logo
21 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
