Question about Bosch Kitchen Ranges
Bosch p4 gas stove soot
Bosch oven
  • 6 Answers
SOURCE: oven produces soot when running, broiler ok, stove top ok
Al, you need to seat the needle valve on the bake. Remove the bottom drawer, right below the bake burner you will see the nut just below the air shutter adjustment. Turn this nut clockwise a few times, it might seem hard but just do it. Then try the bake again, you should have a nice bluel flame. Tenbears.
Posted on Dec 20, 2008
  • 95 Answers
SOURCE: Kenmore gas stove. Oven burns big flame which soots
The manifold needs to be cleaned and adjusted could have rust etc in it Not a good thing to do yourself unless you know what you are doing
Posted on Jan 24, 2009
ldaala
  • 65 Answers
SOURCE: Smelling Gas and Soot in Oven
well its pretty normal u will smell gas when its preheating but if u think its not then u can pull the oven out and check the gas line connection is tight if it is then u can also get a spray bottle of soapy water and spray the whole line and if u see alot of bubbles then there is ur leak and for the soot problem u can use the clean cycle which all it does is reach a very high temp and pretty much burns everything like crumbs to a crisp and all u have to do is basically wipe it out with a damp cloth and maybe a mild soap and sponge good luck
Posted on May 18, 2009
Raphael11
  • 54 Answers
SOURCE: Bosch oven will not come on but broiler and burners work
sounds like your heating elememt in your stove try unscrewing it and taking it to home depo or appliance store and replace should work after that
Posted on Jul 14, 2009
iwillfixforu
  • 619 Answers
SOURCE: gas stove, oven has black soot all through it
There is a lever on the gas valve at the back. Flip it from what ever position it is in to the other positin and see if this helps. Valve is where the gas line connects. Small lever.
Posted on Feb 02, 2010
Black smoke coming from oven while preheating
CLEAN the OVEN put a drip pan under stuff when cooking
Dec 21, 2013 | Premier 24 inch Compact Gas Range w/ Solid...
Jenn-air jdr8895 sabbath error
Faulty range/oven parts aren't the only worry a gas range owner has; the threat of carbon monoxide is very real and should be paid close attention to when doing repairs on the range.
If your range or oven gives off soot, you definitely have a carbon monoxide problem. Soot is the result of inefficient or incomplete combustion. There are always elevated levels of carbon monoxide with soot production. Properly adjusted range/oven parts do not give off soot. You may have poorly adjusted gas pressure, the air shutter may need to be opened, or you may be supplying fuel the oven isn't designed to handle. Don't use natural gas in liquid propane stove or vice-versa.
Increase Engine horsepower.
Jun 02, 2012 | Jenn-Air JJW8230D Electric Double Oven
I noticed soot in my lp gas oven that had been clean. concerned when it started to ruin my food I decided to run the self cleaning cycle again. My whole house filled with toxic soot. My eyes were on fire...
Normally soot is from a range that hasn't been converted for the gas type, like natural or propane. It may be set up for natural when you're on propane or visa versa. Has this range ever worked properly without sooting?
Sep 20, 2011 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
The gas stove fire burns with black soot and is only 1 month old
Gas should not burn with soot, if it does it is dangerous as poisonus fumes will be produced as the air/fuel mix is wrong.
Call a qualified gas engineer to check out the installation and make it safe.
Nov 11, 2010 | Microwave Ovens
Soot from my gas oven
Have a Whirlpool Continuous Cleaning Oven It left soot on the top of the stove after baking the other night why ?
Nov 25, 2009 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Propane stove burns yellow & creates soot
clean the orfices and tubes and then if possible adjust your air mixture setting also
Sep 21, 2009 | Frigidaire FGB24S5A Gas Single Oven
Jan 24, 2009 | Frigidaire 30" Self-Cleaning Slide-In Gas...
Oven produces soot when running, broiler ok, stove top ok
Dec 20, 2008 | GE Spectra JGBP30 Gas Kitchen Range
Gas oven that cooks unevenly
clean your orifaces.
Also make sure that it's the correct stove for your gas type. If you're using a NG stove on Propane, you're wrong. It's making a lot of soot, and could potentially blow up your house. Stop using it until you're sure.
Dec 05, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Kitchen Ranges Logo
29 people viewed this question
Top Bosch Kitchen Ranges Experts
Oloyede Monsuru
Jim Thurston
Are you a Bosch Kitchen Range Expert? Answer questions, earn points and help others
