Question about VillaWare Kitchen Appliances - Others
Music does not play in toaster model 5555-11 - VillaWare Kitchen Appliances - Others
The keyboard light does not go on when the cover is opened. It does go on when the cover is closed.
Probably, but without knowing the make or model number of the item in question, we may as well be talking about toasters or interior lights of vehicles.
Jan 03, 2016 | Music
Need Manual for VillaWare Micky Toaster 5555-07
You will only find a manual on how to use it . If it doesn't work buy a new one ,as it will cost more to get it repaired .
Oct 16, 2014 | VillaWare Kitchen Appliances - Others
When I depress the carriage control levers they do
my toaster did this once, i suggest that you get a new toaster from a different company, because if you've only had the toaster a month
and its doing this already that's a crappy toaster
Apr 20, 2010 | Cuisinart CPT-180 Metal Classic 4-Slice...
Power ct70 wattage = ????
In the US (110/120V model) the CT70 is a 970 watt toaster
If this helps, please be sure to hit the "thumbs up" for me.
Feb 21, 2010 | Breville CT70XL 2-Slice Toaster
Toaster needs new heat coil
Find a comparable model at flea shops, yard sales, or e-bay and take the parts off and install them on yours.
Feb 04, 2010 | Kitchen Appliances - Others
I have a old wall built in thermador toaster & need parts
I have a Thermador built-in toaster ( new in box). It has never been used but I have had it for many years. Willing to sell.
Mar 29, 2009 | Kitchen Appliances - Others
I need instructions for Toaster VTT090
Below the only manuals for toasters available from breville.
Sandwich Toaster
Die Cast Model
Ikon model
Hope they can help
Mar 02, 2009 | Breville Kitchen Appliances - Others
Duraband 4 slice toaster manual model # TS-5221
if u need a manual for a toaster, then u r really in trouble...espcially for the amt of money u paid for it.
ok...
if u need instructions on how to use a toaster...here goes:
When:
A toaster is used to heat slices of bread, bagels, waffles, etc. to a hot, crispy consistency. Most toasters allow the user to set the toasting length to ensure the toasted bread comes out to temperature and crispiness to the user’s likes.
Where:
Toasters should be used on a flat, uncluttered surface near an electrical outlet but far from sinks, or running/standing water.
How:
To toast bread in a toaster, follow these instructions:
1. Place slices of toast, one each, in the slots on the top of the toaster.
2. Find the toast setting (a knob or lever) and adjust to the desired wellness of the toast. (Generally, there is a scale printed near the knob or lever ranging from light to dark toast).
3. Push down the toasting lever (moving the slices of bread down into the toaster between the heating elements.
4. When the toast is finished, the slices will “pop” up automatically.
5. Remove the toast from the toaster.
WARNING:
If the bread should get stuck inside the toaster, DO NOT PUT ANYTHING INSIDE THE TOASTER in attempt to dig it out. UNPLUG the toaster, turn it upside down and shake. If the toast does not fall out, use a plastic fork or knife to gently remove it from the toaster. Using metal utensils could damage the heating elements. NEVER stick anything in the toaster while it is plugged in.
*For further safety, it is recommended that the toaster be unplugged after each use.
I wish u luck and happy toasting.
Oct 14, 2007 | Kitchen Appliances - Others
Kitchen Appliances - Others Logo
Top VillaWare Kitchen Appliances - Others Experts
Jerry Greenberg
Jerry Greenberg
Michael Vincent Cruz
Angel Joseph Jr.
Angel Joseph Jr.
Are you a VillaWare Kitchen Appliances - Other Expert? Answer questions, earn points and help others
