Question about Electrolux EW1200i Front Load Washer / Dryer
Electrolux dryer eied55hiw0 e34 error code - Electrolux EW1200i Front Load Washer / Dryer
2 Suggested Answers
protek480
  • 1723 Answers
SOURCE: Electrolux dryer error code e61
There is a 'tech sheet' in the back pf the dryer. Unplug machine, Remove the access panel on the back to get to it. Reach in and it should be there. It will tell you how to do a button check. You have to enter a test mode through the buttons.
The E 61 is a stuck button.
Enter function test mode and perform key
stuck closed (active). (button) test to determine which button is at
fault. Carefully free the and perform the test
again. If button is free but the key struck code
still exists, replace electronic control.
Posted on Sep 25, 2009
E75 default code on Electrolux gallery series dryer
I appreciate your inquiry, Ape!
From what you have described your Electrolux dryer is displaying an error code of "E75". An"E75" error code is not showing as a valid error code it could be a possible miscommunication with the control panel and I would recommend performing a reset on your dryer. You can do that by disconnecting the power from it for ten minutes. Could you please provide me with your model number? You can normally locate the model number on the serial tag which is located on the door frame. Also, once you reset it can you provide feedback if you continue to receive that error code. Good luck. -Matt
May 19, 2015 | Electrolux Dryers
How to take front panel off an Electrolux EIED55HIWO dryer?
Good Afternoon Friend,
I understand you want to know how to remove the front panel of your Electrolux dryer, model# EIED55HIW0. Typically, this is not a do it yourself repair, as there are no step by step instruction manuals. I suggest contacting your local authorized technician for further assistance. They have been trained on your particular appliance, and should be able to remove the front panel with ease. Hope this is helpful.
-Best Regards-
WP
Jun 27, 2014 | Electrolux EIED55H Dryer
Electrolux dryer error code e62
I understand you are receiving an E62 error code on your Electrolux dryer, model# EIED55H. I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Restore power and start any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your dryer status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 11, 2014 | Electrolux EIED55H Dryer
Error code 08
Good Morning Friend,
I understand that you are receiving a 08 error code on your Electrolux dryer, model# T4530. I have researched your appliance and noticed that it was manufactured in the UK. What is suggested for the North American appliances is to reset them, by either unplugging them or shutting the power off at your home's circuit breaker, for 3-5 minutes. You can try this. If this does not work, I suggest contacting the manufacturer for further assistance. Hope this is helpful.
-Best Regards-
WP
May 29, 2014 | Electrolux Dryers
Electrolux Dryer quit and has a code E 63
Mark, the heating element is underneath the drum, on the left (as facing the front of the unit).
Per the Dryer Tech Data Sheet:
E63 Error Code indicates: [Fault] Heater to Earth Ground [Possible Fault Conditions] Heating element or wiring defective [Possible Solutions] Check heater coils and connections for short circuits to the cabinet. Replace heater and/or wiring and retest.
To open the cabinet is quite difficult, speaking as a non-professional. There may be easier methods than what I used, but I was successful. First I removed all the screws from the back (there are many). This got the top and the back panels removed. The left side (where I could see the heating element was) gave me considerable trouble until I realized I had to remove the door trim to reveal one last screw. Finally got the side off and swapped out the heater. Much much vacuuming for me. I am still trying to figure out how to clean out the bottom of the duct (underneath lint filter), but that's another post.
Also, just in case you don't have the manual and/or need to order parts, I will include a link.
http://www.searspartsdirect.com/partsdirect/part-model/Electrolux-Parts/Dryer-Parts/model-EIED55HIW0/1412/0151200
For some reason, the Sears Parts Direct website lists the dryer as a Gas dryer, which it obviously isn't, as the part in question is very clearly an electric heating element. Hope this helps.
-Nick
Mar 03, 2014 | Electrolux EIED55H Dryer
I own a 1Q-Touch Front-Load Electrolux washing machine. The door won't open. What can I do?
Hello Elizabeth P Cochran - Try resetting the unit by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and restart unit. If the door does not open, then it sounds like the washer is possibly experiencing a communication problem with the control board, wiring failure or faulty door lock. Contact a professional to move forward accurately to properly diagnose/repair unit.
Jan 15, 2013 | Electrolux EIED55HIW Electric Front Load...
How do I access the fault codes on an electrolux 1200
I see many posts about Error Codes that aren't in the user manual. Here's what I found: Go to Google and type in "Electrolux Error Codes" and you will find the following site. It details an Electrolux Service Flash that helps with error codes that don't appear in your user manual. Good Hunting!
Customer Error Codes On All Digital Display Frontload Washers - [ Terjemahkan laman ini ]Electrolux Service Flash LN071 02.13.07. NOTE. These customererror codes are not included in the error code chart on the technical data sheet located ...
www.applianceblog.com/...electrolux/886d1212672468-frigidaire-front-load-washer-doesnt-start-frigidaireerrorcodesonalldigitaldisplayfrontloadwasher...
Sep 16, 2012 | Electrolux EW1200i Front Load Washer /...
ELECTROLUX DRYER T4130, error code E08 show on panel. have tried turning power on and off, but still the error code E08.
Dryer had been overheated (clogged or damaged air filter). Reset 3 thermo-fuses (small red buttons): 2 under top cover and 1 under back side round cover
Jan 02, 2011 | Electrolux Dryers
ELECTROLUX DRYER T4190, error code E08 flashing on panel. have tried turning power on and off, but still flashing. problem?
How to solve this problem
Aug 14, 2010 | Electrolux Dryers
Sep 25, 2009 | Electrolux EIED55H Dryer
Electrolux EW1200i Front Load Washer / Dryer Logo
52 people viewed this question
Top Electrolux Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
