Question about Delta Home
Triton t90z shower head disassembly
Anybody know how to do it? GOt a small plastic tool that fits into five small divets on the face of the shower but i've no clue how to get it off, anybody any tips.
keemo68
  • 1263 Answers
SOURCE: Triton Millenium Power Shower
generally if the flow sensor notices no water through the pump it will auto matically shut the pump down. so it could be the flow sensor is bad or the pump is not working like it should. now it depends on how old the pump is. i would start with the flow sensor.
Posted on Sep 03, 2008
  • 44 Answers
SOURCE: triton electric shower runs cold
hi it sounds as though the thermostat has gone on top of the can assembly, or moreover it has scaled up & the element needs replacing, if thats the case your better off buying a new unit as the cost of the can assembly & the fitting it will be nearly as much, plus witha new unit you'll be getting a 2 yr guarantee?
Just a thought!
Posted on Dec 15, 2008
  • 659 Answers
SOURCE: my shower works. water also poors out of a tube beneath the unit
Are you talking about water still coming through the spout at the same time? What overflow pipe are you talking about? If you are talking about the spout, there is a device in the spout that when you pull up on it, the water is diverted to the shower. They have washers in them and it sounds as though the washer is worn out and not making a good seal anymore. You can buy a new generic spout to stop the water or you can take the old one apart and try to find replacement pieces. I have taken one apart and bought a new one to rob the parts off of it before. I hope this is the answer you were looking for. If not, reply to this for clarification and I will try and answer your question more clearly.
Posted on Apr 03, 2009
  • 20 Answers
SOURCE: I have a Triton Rapide R2 electric shower problem
you can check the pipe lines there are normally more thane one way to set the pressure of the water one by the shower knobs 2 by the behind the head in the wall there are some water valves that may need to be opened up or by the water heater there are some valves there one coming off the heater one just on a pipe by the heater they may need to be opened. try that if that doesnt work come back and let us know and see what else you can do to fix it
Posted on Nov 11, 2009
jeff_drakesr
  • 155 Answers
SOURCE: i have a drip, drip, drip from my shower head on
A shower head will drip for a period of time but I will assume that it is dripping continually. Servicing the Mixing Valve is what is needed to fix the continual drip. there are several 'O' rings washers that eventually wear down causing problems. These parts are serviceable and kits with instructions can be purchased at plumbing shops, DIY Stores, Hardware Stores. I hope this has helped thanks for using FIXYA. Good luck and have a great day. Jeff
Posted on Apr 07, 2010
Testimonial: "THANKS FOR YOUR HELP I WILL TRY THAT"
I need a new shower unit that will fit my existing plumbing and electrics
most shower heads are the same size plumbing . pick out what you like and get it installed
Jan 05, 2016 | Home
How to disassemble of moen shower head,where i can start the dismantling?
U don't remove the plastic u stick them hole shower head down in vinegar and let it sit for a while, that will clean it out
Feb 24, 2015 | Moen 6302 flo Deluxe Shower Head Shower...
The water flow from my triton electric shower does not stop even after unit is switched off
28487001 is not an electronic shower head made by Hansgrohe. It is an overhead shower head that has no electronic parts. Triton is a completely different company. If you have an electronic shower system by Triton you will need to contact Triton. If you have a Hansgrohe product feel free to contact Hansgrohe at 1-800-334-0455.
Apr 13, 2013 | Hansgrohe Showerhead Shower Power ...
My triton t90z has no water coming through
If you hear the pump pumping as normal then it is most likely the solenoid. Try phoning www.dublinshowerrepair.com
0872885385 they'll give free advice and stock Triton and Mira parts
Jan 12, 2013 | Home
Theres only a low flow of water coming out of the shower.
remove the head and make sure you have a good flow to the head if you do look to see if a plug needed to be removed before installation if their isn't return the product
Jul 06, 2012 | Home
I have a triton dart shower which is operated by turning a flow control block. This is so hard to turn that I sometimes struggle and my family require my assistance. It is just as difficult to turn off...
I can't offer you a solution but will say that I have the same problem with my Triton Dart. I have put it down to a build up of hard water inside the valve but not sure. Think I'm going to have to contact Triton under their warranty although they do say that they will not cover faults resulting from limescale.Great
Nov 09, 2010 | Home
I have a Moen shower faucet that is six years old(copper sweated plumbing). My wife noticed water dripping profusely from the downstairs ceiling during my shower. The screws holding the face plate were...
Try removing the handle, then the face plate. With a flashlight handy, check inside the wall around the valve to see if you see any leaks. Then, try the valve by pulling the stem (may need a plier to grab this). Keep checking inside the wall. Next, try the shower, and again watch in the hole you have. You may find that the connection(s) to the valve is/are leaking, particularly at the top of the valve where the shower pipe heads up the wall. Or, it may be that the shower head's arm is leaking somewhere above. If you only see water dripping down from above, try the flashlight with a small make-up mirror to see if you can see where it's coming from. Sometimes the pressure in the shower head builds up from the flow restrictor, or the head's spray holes may need cleaning out (try soaking the head in a solution of CLR [stands for Calcium, Lime, Rust] available at most home improvement/ hardware stores). Sometimes the shower arm (the bent 1/2" diameter pipe that the shower head mounts to) isn't fastened in tightly enough. A good trick to help here is to wrap the threads with teflon tape, then apply teflon paste also. Wrap the tape clockwise around the threads so that it doesn't unwrap when you screw the pipe back into the fitting in the wall. Also, make sure the threads in the fitting in the wall are cleaned out, and don't let any debris contaminate the new teflon paste as you slip it back through the hole in the wall. If you find that the pipe out of the top of the valve is leaking, I recommend you call the plumber. He/she can likely fix it without taking the wall apart.
Aug 27, 2010 | Moen & One Handle Tub & Shower Faucet
My triton martinique electric shower low pressure light comes on and the water goes cold but there is nothing wrong with the pressure
I had a brand new Triton Rapide 3 with this issue, we had good water pressure but the light on the front would keep coming on.
I found there was a micro switch located at the front almost dead center of the shower, couldn't miss it when you removed the cover. A plastic arm below this switch is raised when the water pressure increases tripping this switch and allowing the heater to come on.
I found two things wrong with this, one this plastic leaver was thin and bent easily and secondly the switch did no line up overly well with the lever. Easily fixed, I cut an inch off the end of a zip tie or panduit strap, and super-glued it to the top of the lever (not the switch as the glue will probably ruin the micro switch.) 5 minute job later and with the shower back together it works beautifully. My wife will be happy, you wouldn't believe the torrid of curses I got this morning having only replaced the old unit last night.
Probably don't need to say this but, make sure you isolate the power before removing the cover.
Jun 03, 2009 | Sony Playstation 3 (PS3) Console
Shower spout
There is a threaded stem that passes through the spout and attaches to the white plastic diveter valve. If you are starting from scratch (everything apart), you can put it back together in this order:
1) Place the white plastic diverter inside the spout. the circular side with the black round washer should face the the wall side of the shower (mating up against the threads for the water pipe).
2) The stem can now be inserted from the top and into the notched section of the white plastic diverter valve. The threaded end of the stem shoud be outside of the spout (from the top side).
3) A round black washer fits over the threads. It should sit right where the threads end. Dont push it all the way on to the unthreaded portion of the stem.
4) Screw the threaded knob onto the threads.
Should be ready to install now. Including the spout itself, there are 5 parts and are configured in this order from top to bottom.
1) Female threaded knob (the knob for operating the spout)
2) Threaded stem (threads on top)
3) Round black washer
4) Spout
5) Whit plastic diverter valve.
Mine leaks when I turn on the shower, thus reducing shower pressure. I looks like a poor design to me. The stem is not a tight fit in the spout and this allows the diverter to "wobble". The washer on the diverter valve does not seat tightly and allows water to leak out the tub spout when showering. I would replace the spout.
Jan 30, 2009 | Price Pfister 01-311 Shower Head, Tub...
Home Logo
124 people viewed this question
Top Delta Home Experts
Mike
Donni Steen
john h
Are you a Delta Home Expert? Answer questions, earn points and help others
