Question about Kenmore 54701 Dehumidifier
Very similar problem---Leak
Seems to be the same spot, lower left front corner. Any ideas?
  • Anonymous Nov 22, 2007
    The unit leaks water on the floor although the bucket is properly positioned.
  • Anonymous Dec 04, 2007
    It works fine, but it doesn't flow into the holding tank, but leaks around the sides and onto the floor. Seems like a tube is plugged. I cleaned the radiator front, and the screen of the filter and am trying it again. Any ideas?
This is happening to me as well. My motor shroud is cracked...I assume that's it. I'll replace it and see.
Posted on Oct 09, 2007
SOURCE:
I have a Royal Sovereign BHD 450 dehumidifier. I moved and I do not know how to install the hose into the unit. It looks like it goes into a place in the bottom of the unit. The online manuals I found do...
Yes, there should be a screw out plug for the drain hole on the lower left. If the plug is not in there, the you will have water all over the floor. Unless, you can find the drain cap for it. The auto drain hose connection is about 6" above the manual drain hole, I just mentioned. That is where the auto drain hose connect. It's held in place by a squeeze clamp, that goes on the hose before making the connection. But, keep in mind, with out the drain hole screw in plug, water will still spill onto the floor.
If you can't find it, try Appliance Factory Parts 1-800-955-7075. As they may can help you.
Hope this helped you and thanks for choosing FixYa
Aug 10, 2011 | Royal Sovereign BDH450 Dehumidifier
I acquired used Amcor AHD65 Dehumidifier a couple days ago. I was told that it is just beyond the warranty period. I assume that it is a barely a year old. However, It worked this evening a sort since it...
You may still have some packaging materials left inside the unit. The plastic pan doesn't stay in side the bucket. It's used as a drain pan on the outside. Also, be sure the air intake filter is in place, is clean and there are no packaging materials behind it.
To extract more humidity, after checking all the things mentioned above. Lower the extraction level to 32 to 35%. Lower percentages means extraction of more humidity. (i.e.200% -35% = 5% drop in humidity).
Hope this helps you troubleshoot and solve the problem. Please let me know. Thanks.
Jun 11, 2011 | Amcor AHD65 Dehumidifier
Bucket not filling, unit seems to be making more noise
If you are running and not pulling moisture first check air flow. Vacuum the front and back grills and make sure the coils are clean. If you have good air flow the cause of the problem is most like a sealed system issue. This is most commonly a refrigerant (freon) leak. check your use and care manual to find how long the warranty on the system is, sometimes it is as long as 5 years. If it is out of warranty then the repairs are more costly than a new unit.
Jul 24, 2010 | Whirlpool AD65USL / AD65USM Dehumidifier
Bucket not filling - ice forming on lid.
You've developed a sealed system problem.
Apr 07, 2010 | LG LHD45EL Dehumidifier
Maytag Dehumidifer still works, but is leaking
Well life span is 3-15 years depends how long and hard you run them. 45 pint is about 1000sqft basment. rule of thumbs bigger better. run less and do a better job. I would start by filling the bucket and place in a dry shower see if you have a crack. cant find a source for the bucket discontinued this might be your problem. http://www.repairclinic.com/SSPartDetail.aspx?s=t-M7DH45B2A-%3d%3di1025984&PartID=1025984 Repair cost are about 40-50 and hour!!!! good luck
Nov 01, 2009 | Maytag M7DH45B2A Dehumidifier
Goldstar dehumidifier model DH305Y6 is there an outlet on this model for a hose so can drain into sump pump?
I have a Goldstar dehumidifier, Model DH305Y6. I bought it about 5 years ago at a local Walmart. During the summer I run it in the basement, here in south-central Pa. When it was brand new it worked very well, for about 2 yrs. Then it began turning on & off very irregularly. At first I thought it was the sensor on the front of the coils. So I moved it to the lower left side of the coils, and had the same results. The other day the water heater in the basement developed a leak. About 300 gals. of water covered the floor. After sumping/wet-vac'ing down to a wet carpet, I pulled out the dehumidifier and plugged it in,(the filter was cleaned before put away last summer). It began its on/off cycling again. It runs for about 2-3 mins., then shuts off for about 5-10 mins. So, I took the On/Off switch apart and read the resistance. It read 48k, for the 50k switch. I turned the switch all the way left to all the way right and it went from 48k, down to about 8k. The two wires to the switch were attached to the #2 and #3 poles,(only 3 poles). I did some testing, then removed the wires and re-soldered them to the #1 and #3 poles. I put everything back together, and now it works. It runs constantly, but it works/runs just fine. I need to get the basement dry, so I will let it run until the job is done. In the Spring I will get a new 50k potentiometer,(on/off switch), and see if that works. I will post results if I remember to.
Sep 29, 2009 | Goldstar Dehumidifiers
Powers on but will not remove any moisture
It seems these units only last about a year or two before this happens. Unless you can get it replaced under warranty (mine had 5 year warranty) you probably will be better off getting a new one. They leak their freon out and then just run, usually forming ice near the top of the unit in the front. Classic case of not enough refrigerant.
Jul 28, 2009 | LG LHD45EL Dehumidifier
Coils freezing up
Its likely one of two things. 1) the fan isn't moving enough air through the unit. If there is a filter, clean it. 2)If aire flow is OK and its freezing up on one end of the coil and the other end of the coil is not very cold at all then refrigerant charge is probably low. I know that seems counter intuitive but a low charge in a refrigerator or A/C unit (which this dehumidifier is a derivative of) can actually frost up when slightly under charged. Now if the charge is determined to be low there is a leak somewhere and that leak will need to be found and repaired. It will probably take an electronic leak detector to find it. If the leak is on a section of aluminum tubing in a tight location it may be impossible to repair the leak and that may force you into a new unit. If its on a copper tube it can be fixed. If its on aluminum tubing it can be clamped shut if there is physical access for attaching a clamp and seal. Sometimes a leak pushes out some refrigerant oil at the site of the leak making it a visible spot to the naked eye. Hope these comments are of some help
Jan 15, 2009 | Kenmore 53301 Dehumidifier
Front panel removal
You should see the tabs near each corner on the top and near each corner on the sides up towards the top. What I recommend is pull out slightly where you removed the screws. Then when you look closely you will be able to see the tabs. Once you see the tabs you can compress them with a small flat head screwdriver.
Jul 05, 2008 | LG Goldstar LD65EL Dehumidifier
Leak
Mine did this last year. I took the housing off of the left side and found a clear plastic tube had popped off the fitting, I put it back on and it worked fine. The tube was toward the lower front of the unit.
Jun 01, 2008 | DeLonghi DE400 Dehumidifier
Kenmore 54701 Dehumidifier Logo
Top Kenmore Dehumidifiers Experts
Bill Long
Marvin
Marvin
Are you a Kenmore Dehumidifier Expert? Answer questions, earn points and help others
