Question about Maytag Dryers
Maytag neptune mlg2000aww gas dryer won't heat up
Problem is intermittent. sometimes it heats and sometimes nothing
Illeagle
  • 525 Answers
SOURCE: maytag neptune (gas dryer) just stopped heating
Gas dryers utilize a gas valve, ignitor assembly, and a series of coils mounted on the gas valve to provide heat and safety. The gas valve coils are the usual suspect when it comes to a "No Heat" complaint. I have provided a checklist from www.repairclinic.com, for your convenience. They also provide disassembnly diagrams and repair parts.
Firstly, ascertain that you have made an adequate "Heat" selection, then read on:
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
If your dryer doesn't heat, check these:
Igniter
Gas valve coils
Thermal fuse
Igniter Modern gas dryers use an electric igniter to ignite the gas from the gas valve. When it's working properly, the igniter glows bright orange. When it burns out, the dryer tumbles but there's no heat because the gas can't ignite. When the igniter burns out, you need to replace it. If the igniter is held by a tension bracket, you very well may need to replace the bracket too.
The igniter is inside the dryer housing, near the bottom front, usually in a cone-shaped metal tube (the force cone). It's about 2 inches long. It's mounted to the far end of the burner tube, and it has two wires attached to it--or to the tension bracket, if there is one.
Gas valve coils Watch the igniter. Does it glow bright orange, then shut off without igniting the gas? (When the gas ignites there's a large blue flame.) If so, there may be defective coils on the gas valve. Mounted on the top of modern gas valves, there are black electrical coils. The coils, when energized, open the gas valve. If one or more of the coils are defective, the valve doesn't open and the gas cannot ignite. Because it's often difficult to properly test the coils, it's usually best to replace both (all) of them at the same time.
Thermal fuse On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing.
If the fuse has blown, it has no continuity. When this happens, your dryer either just stops heating, or it doesn't work at all. Be sure to inspect the venting/heating system before replacing the fuse to put the dryer back into operation. (You can't re-set this type of fuse.)
Posted on Jul 08, 2009
  • 532 Answers
SOURCE: Gas dryer heat (drying) works intermitenly, model Maytag MDG6700
check the exhaust tube for obstructions
Posted on Sep 11, 2009
milten1
  • 1304 Answers
SOURCE: Maytag Neptune Dryer Won't Heat up
these particular dryers have issues with the heat coils,
it probably has a bad element
Posted on Oct 03, 2009
richardsimpl
  • 230 Answers
SOURCE: dryer does not heat up.
Hello there:
normally on these units if the dryer was working ok and then suyddenly stopped heating your heating element or the ignitor (excitor ) has failed and is need of replacement
so i would start by having these things checked first by contacting a local repair man to do a evaluation on the unit and if kyou still have a valid warranty i would use it ok
I hope that this is very helpful for you
Best regards Richard
Posted on Nov 16, 2009
  • 3230 Answers
SOURCE: my dryer runs but no
Well if your dryer tumbles, but there is no heat then you may please check out the following -
1. First of all you can check out for proper air flow - Check the vent for proper air flow by placing your hand over the exterior vent while the dryer is running. You should feel a strong flow of air. If not then check the lint trap. It is located either on top of the dryer or possibly just inside the door. Remove any lint that has built up in the lint trap. Cleaning the lint trap should be done regularly, even as often as after every load. Do not operate the dryer without a lint trap in place.
2. Secondly you can check out the Ignitor - gas dryer blows air through a burner assembly to heat the air. The burner assembly consists essentially of a gas valve, ignitor and a flame sensor. If any part of the burner assembly malfunctions, the result will be low or no heat and slow drying of the clothes. Post comments for further help or information.....
Good Luck!!
Thanks for using FixYa!!
Posted on Sep 22, 2010
Dryer heat fails intermittently
Probably an intermittent timer, not the heating element.
Jul 26, 2017 | Maytag Neptune MCE8000AY Electric Dryer
Maytag neptune stacked MLG2000AWW wont heat
It's either the fuse, heating element, thermal cut-off or thermostat
May 20, 2012 | Maytag Neptune MLG2000A Front Load Stacked...
Maytag Neptune wont heat up what is problem
We just converted my neptune gas dryer to propane. It ignited yesterday but we could smell propane. So, my husband fixed that ,now it won't ignite and heat up
Nov 10, 2011 | Maytag Neptune MDG5500AW Gas Dryer
Dryer won t heat
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Dec 17, 2010 | Maytag Neptune MDG5500AW Gas Dryer
The lower dryer compartment won t heaT
heatman101
Jun 25, 2010 | Maytag Neptune MCE8000AY Electric Dryer
My Neptune gas dryer is working fine other than the heat. Sometimes it heats, sometimes it doesn't...very random. Fuse or thermostat?
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Jun 01, 2010 | Maytag Neptune MDG5500AW Gas Dryer
My maytag dryer is not staying hot to dry clothes
heatman101
May 19, 2010 | Maytag Neptune MDG9700A Gas Dryer
Neptune dryer heats up sometimes
hi there,
this is an older style dryer that has an igniter. check the valve itself, you may have an intermittent operation.
thanks
Sep 10, 2008 | Maytag Neptune MDG5500AW Gas Dryer
Dryers Logo
188 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
