Question about Sylvania WV20D5 20 inch TV/DVD Combo TV
Region code for SV2000 WV20D5
I have had this TV for years, and I want to play some norwegian movies without having to buy a new tv or dvd player. How do I make it play films from Europe as well? Thanks!
5 Suggested Answers
  • 4 Answers
SOURCE: Sylvania 6427CTC TV problem
uqgfqe.
Posted on Jul 23, 2008
greenspan
  • 1734 Answers
SOURCE: Sylvania TV CR202SL8 no remote, can't play DVD
Ask Manualfox.com - it is a personal Document Search Service for electronic user, service manuals and drivers. They help you to save time and money by finding your needed product information.
Posted on Feb 22, 2009
SOURCE: trying to use my tv in game mode without the remote
Try a cheap Radio Shack RC or AV adapter...instead of using the frickin game mode, it let's you just go back to the old school options of channel 3 or 4! Hope this helps. It's about 10 bucks and only will take minimal work to set up (just rescrew your cable cord into the box and the other end into the tv). Picked up this lil trick when we had older tvs and I wanted to play video games! HAHAH, hope my epiphany works. Feedback is more than welcomed!...or you can just buy another original remote like "that other guy on here" was suggesting @ http://www.electronicadventure.us/Merchant2/merchant.mv?screen=prod&store_code=EA&product_code=N0108UD
Posted on Jan 09, 2010
yammy_alf
  • 666 Answers
SOURCE: HOOKUP A MAGNAVOX DVD/VCR PLAYER TO TV AND DISHNET WORK CA
may be your tv systems don't have an accessory for audio video input. but you can hookup that by using an RF modulator adapter, this is a converter from audio / video to RF signal and connected directly to your antenna connection. you can purchase that RF modulator adapter to an electronics store.
Posted on Apr 18, 2010
  • 144 Answers
SOURCE: I have a Sylvania TV/DVD/VCR combo that I
the chances are the laser is bust try cleaning it with cd cleaner disc and liquid if it does not work laser is done buy another dvd player much cheaper than replacing the laser unit
Posted on Oct 14, 2010
How do i get a vcr to work without a remote
Answer #1: You can get up out of your chair walk over to your TV & VCR player and
Turn it ON then Insert a VCR Tape then Turn on the TV,Hit the Play Button
on your VCR Then go back and set in your Chair AND ENJOY the Movie.
When the Movie is Finished You do the same thing all over again Except in Reverse. I do this every time I want to watch a Movie. Answer #2:You
can go to the Electronics Store and Purchase A VCR Or DVD Player that Does Have a Remote or Just Buy a Universal Remote for about $10.00 it has all the codes for all TV's, VCR & DVD Players in the Package. I sure hope that one of these Answers is of some Help. Good Luck!
Apr 10, 2012 | Sylvania 6419TA 19" TV
I have a Sanyo 19"
I would buy a universal remote control for your tv as some won't operate without the remote control features on it.
Feb 24, 2011 | Sanyo DS19310 19" TV
What channel does it need to be on to play a dvd player I have the converter box
Ur tv have a video input holes R,Y,W.?Use the RCA cable R,Y,W to hook up to play the DVD player.Use the tv video 1 input to watch dvd movie.
May 27, 2010 | Sanyo DS25390 TV
No signal on TV when we go to watch a movie on the DVD player
You may have to select a different input on the tv. iIs there an "input" put on the tv remote? If not, try channel down.
Apr 30, 2009 | Sanyo DS31520 31" TV
Trying to hookup and play standard DVD player
Yellow is video and red&white audio ,so when you hook up dvd does picture preview of dvd come on?You may have to switch to aux for dvd or different channel try checking each channel .
Dec 12, 2008 | RCA F25441 25" TV
Disney C1320PTVD TV/DVD Combi. Won't play discs just makes a spinning sound!?
You have to replace the DVD player. The problem is that parts are not available and it's difficult to open the unit. There are about 20 screws to remove, including four screws hidden behind each fender. You have to pry the fenders and rip them off to break two brackets that hold each fender on. The fenders still hold on fine with the remaining seven tabs on each fender. You have to eject the disc to get the mouth off.
I have a working DVD player for sale. It's from a car TV with a defective picture circuit, but the player runs and I hear the movie soundtrack, so I'm 99% sure it's good. I broke the mouth off the player, but it could be glued back.
If you have a good motherboard for sale with a bad DVD player, I might buy the motherboard from you.
Chris
email me: chris_goulet [at] yahoo [dot] ca
Oct 13, 2008 | Disney DTD1363-CAR 13" TV/DVD
Is there an input select?
I can view channels but cannot view a DVD from the TV/DVD Disney Princess Combo. Only see static on the screen with no sound. I wonder if I need to change the input select to view a movie but cannot find a button on the TV or remote control. I have a 6 button remote which I am sure operates the DVD and another remote with 39 buttons I thought would operate the player as well as the TV. However, so far only the player functions from it. The buttons only have small pictures without words which sometimes leaves some question about purpose. This is a second hand unit. I do not have a manual. It did play movies at first. I think the trouble may have started when I programed cable channels. Any help will be greatly appreciated
Apr 24, 2008 | Disney DT1300-P 13" TV
I cannot switch my TV mode to video mode
Hi, all you have to do is go past Channel 2 and the screen on t.v. will say Line that is where you will watch all your DVD movies...
Good Luck as I had the same problem when I first hooked up the dvd player to the t.v. , I thought I was going crazy , turned out it was simple... Enjoy ...
Mar 30, 2008 | Broksonic CTVG-5463GVC 19" TV
Can't get the DVD connected to the TV directly without Cable or Satellite...
what brand is your TV and your DVD? Most TVs have a Audio In(put) and Video In(put) connection at the rear. Similarly, most DVD players have a Video OUT and Audio (L) and Audio (R) outputs at the rear. Now all you need to do take the supplied cable - or if you do not have one, buy a cable from radio shack - should not cost you more than 5$ - and connect the Video Out of the DVD player to the Video IN of the TV and Audio Out of the DVD to the Audio Input of the TV. On the TV, using the remote, select Video Input using the TV/AV button. Play your DVD machine, and enjoy your movies.
Apr 07, 2007 | Durabrand DWT1905 TV
How do I reset the password on the dvd player?
SpongeBob SquarePants 13" TV Is the DVD player in this 13 inch television; if it is then you can ring the product support number 905-940-5089 I hope this is correct for the USA. Or you could try hypnotizing your son to get the password!
Oct 22, 2006 | Emerson SpongeBob SquarePants TV
Sylvania WV20D5 20 inch TV/DVD Combo TV Logo
213 people viewed this question
Top Sylvania Televison & Video Experts
matt martin
matt martin
Dave Naylor
Dave Naylor
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
