Question about RIM BlackBerry Curve 8310 Smartphone
I can't hear out of my handset for voice calls. PPlcan hear me fine but it sounds like they are whispering. I was having no problems until tonight. Speaker phone is working fine. What can I do to fix it?
  • 173 Answers
You need to open up your phone and clean both the actual ear speaker and the two small pin holes on the cover with 91% or higher alcohol. If that doesn't solve the problem then need to replace your ear speaker.
Posted on Mar 18, 2009
I have a Panasonic KX-TGA652 dual handset no answering machine. The problem I have is the 1st handset "the base set", doesn't seem to work properly, the 2nd handset works 100% fine. The problem is this,...
Id try the following in this order:
  1. Try swapping batteries with another set and see if the problem follows the battery
  2. Try re-registering the handset, they could of missed one at the factory. that is done by selecting menu->initial settings->register handset
If this doesn't work, then return for warranty/exchange. Mine seem to work great right out of the box.
the poodle guy!
Sep 29, 2010 | Panasonic Lands Phones
I have the DECT1580 cordless phone with 4 handsets. Lately, people cannot hear me when I call them. Sometimes it cuts in and out. It's happening with more than one of the handsets. Help.
Weak or Hard to Hear Audio (From the Uniden Manual)
If the caller’s voice sounds weak or soft, the signal might be blocked by large metal objects or walls; you might also
be too far from the base, or the handset’s battery may be weak.
  1. Try adjusting the volume of the earpiece (see page 36) or the audio tone
  2. Try moving around while you’re on a call or moving closer to the base to see if the sound gets louder.
  3. Make sure the handset’s battery is fully charged.
Jan 04, 2010 | Uniden DECT 6.0 Cordless Telephone...
How to put cell phone to speakerphone mode
Manual:
http://www.cellphones.ca/upload/manuals/samsung-sph-m300-manual.pdf
From Page 39 of the manual:
Selecting Options (right softkey) during a call displays a list of
features you may use during the course of a call. To select an
option, press the corresponding keypad number or highlight
the option and press . The following options are available
through the Options menu:
 (1) Key Mute/Unmute allows you to mute the microphone
on your phone so the caller is unable to hear any sound.
 (2) Turn Speaker On enables the speakerphone feature.
 (3) Set Whisper increases the microphone to its maximum
level. During a call turn on Set Whisper when speaking
softly or when the caller cannot hear your voice clearly.
This mode is useful in meetings or public places.
 (4) Call History checks your call log for Outgoing, Incoming,
Missed, and Recent calls. You can also erase the logs from
this menu.
 (5) Contacts accesses the Contacts menu.
 (6) 3-Way Call allows you to talk to two different people at
the same time. (For more information, see “Making a
Three-Way Call” on page 189.)
 (7) Messaging accesses the Messaging menu options.
 (8) Voice Memo allows you to record incoming audio from
your conversation. (For more information, see “Managing
Voice Memos” on page 135.)
 (9) Tools accesses the Tools menu options.
Manual:
Mar 21, 2009 | Samsung SPH-M300 Cellular Phone
I have a problem with 6610i set that I can't able to hear other person's voice -
This sounds like the speaker in your handset which transmits sound to your ear is either faulty or turned down. Check the volume on your handset is set to max.
If the speaker in the handset is faulty - to trouble shoot this try using a handsfree kit which plugs in to the bottom of the phone and if the ear piece works correclty on a call through the handsfree eairpiece then your phone may have a fault.
Please dont forget to rate..
Jul 16, 2008 | Nokia 6610i Cellular Phone
Whisper mode
The problem might be the hearing volume. As far as I know, the only way to change it is in the middle of a call.
Here's what you should try...
1) Call someone.
2) Using the silver button on the left side of the phone, press the up arrow key a few times until the volume is all the way up. It will say "Hearing Volume".
3) During the call, go into the options menu and select the first option that will say "Whisper Mode On/Off". Select that and your problem should be fixed.
May 14, 2008 | Samsung SYNC SGH-A707 Cellular Phone
New Voice Mail flashing light
press "mute" key to access menu, press the up or down arrow key labeled "caller ID- volume" until you get to "handset setup", press the "mute" key again, press the down or up arrow until you have "defaultsetting" selected, press "mute" key, press "1", then press "mute" once more. At this point your handset will reset clearing the indicator for all the handsets. I've had to do this twice on my phones and it worked every time.
May 10, 2008 | Uniden Cordless Phone
PANASONIC kx-tga300s
http://www.panasonic.com/help 17
Handset clarity booster
This feature can improve sound clarity
when the handset is used in an area
where there may be interference.
During an outside call, this feature is
turned on automatically when
necessary. You can also turn this
feature on or off manually.
1 Press {MENU} during an outside
call.
2 {V}/{^}: Select “Booster on” or
Booster off”. i {Select}
Note:
LWhen this feature is turned on,
BOOST” flashes.
LWhen this feature is turned off
manually during a call, it does not turn
on automatically during the same call.
LWhile this feature is turned on;
– the battery operating time is
shortened (page 11).
– the maximum number of extensions
that can be used at a time may
decrease.
Handset voice enhancer
This feature clarifies the voice of the
person you are talking to, reproducing a
more natural-sounding voice that is
easier to hear and understand (page 25)
Feb 24, 2008 | Lands Phones
Sound
During call, repeatedly press the "+" button located on the side of the handset, until it is audible.
Jan 28, 2008 | Sony Ericsson K300i Cellular Phone
My voice is not being heard
hi alwayes start chcking a problem from the end and back 1) check the MIC on your handset - connect it to something else and see if it works good... 2) check your output if there is any noise (voltage, other system....) if all is good then the problem is probeply in your COMP: check all audio configurations if that didnt help then its a hardware problem.... good luck
Apr 24, 2006 | Actiontec (DHUSB00020C01)
RIM BlackBerry Curve 8310 Smartphone Logo
172 people viewed this question
Top RIM Computers & Internet Experts
Computer Repairing
Computer Repairing
ismael castillo
David
Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
