Question about John Deere 22HP Hydrostatic 42" Riding Mower
John deere 212 no fire jut cranks
John deere 212 will not start just cranks i have adjusted points replaced solinoid condenser plug
  • 10865 Answers
SOURCE: john deere 420 trouble starting getting gas and
The engine needs air, so be sure the air filter is clean. If it is not, replace it.
The engine needs spark. Replace the spark plug and be sure that the battery has a complete charge.
The engine needs good fuel so be sure the gas is newly purchased, not gas that has been sitting around for months.
Posted on May 19, 2009
wilsodfarm
  • 986 Answers
SOURCE: 3020 carburetor ? john deere gas tractor, 3020
those carbs are real simple you will not have any problem
Posted on Jul 29, 2009
rwvanlue
  • 486 Answers
SOURCE: I have a John deere 317 tractor that does not start.
We will be testing for voltage to the points, coil, engine to tractor wiring harness, ignition switch
Tools needed:
volt meter to read 12 volts, or test light
1) with the points open: is there voltage at the connection wire at the points
If yes; adjust points to .020" and try to crank engine and check for spark
*** you may want to determine if condensor is connected to this wire also
if no
2) check point side (neg or - ) of coil for voltage
if yes, engine should start
if no
3) check for voltage at the + side of coil
If yes, coil is bad
if no
4) check wire connector from engine to frame wiring harness
if yes; engine should start
if no
5) check wiring on the back of ignition switch
if no
6) check that ignition switch RED or BATTERY supply wire has voltage
if yes; switch is bad
if no
7) check supply wire and circuit breaker connected to the battery side of the solenoid
if no; circuit breaker could be at fault or wire connector at battery supply
Posted on Nov 08, 2009
  • 10 Answers
SOURCE: Have John Deere 165 riding mower. Strong crank,
Has it been outside? May be water in the fuel.
Posted on Jul 25, 2010
alicantecoli
  • 22246 Answers
SOURCE: john deere 520 getting no
i think you may have set the points wrong ,now turn engine over till the corner of the cam is under the points ,then set the points gap to whatever it should be ,clean the points in case you have sprayed with wd40 as any oil will stop it from sparking or grease ,dab of grease on the cam and it should start ,iam sure this is your problem oily points or the wrong gap
Posted on Aug 18, 2010
John Deere L130 riding lawn tractor will not start what do I do?
I'm assuming the motor will crank over, but not start. Remove the air intake cover & filter off the carburetor air intake. Do you smell gas? Is gas dripping out of the carburetor? If not, spray a couple shots of starting fluid or carburetor cleaner into the carburetor air intake throat. Close the choke & crank the engine. If it starts, & stalls, repeat the process. If it won't stay running, your carburetor float jet is gummed up & needs to be cleaned. Check & clean the spark plug. Does the spark plug fire when the engine is cranked? If no, then you have an ignition problem.
Mar 05, 2016 | John Deere L100 Series
Why won't my mower start?
a weak spark indicates a coil problem
that problem can come from a faulty condenser in the ignition system or incorrect timing for the system
if it has an electronic ignition system test / replace it
if it has a points system replace the condenser and set the points to the correct gap
I
May 14, 2015 | John Deere Garden
John deere will not start
Charge the battery fully, verify good contact on the battery terminals. If it won't crank, check for voltage at the starter motor while trying to crank, check battery voltage while cranking (if it drops below 9V, the battery needs to be replaced).
If it cranks but doesn't fire, make sure it has plenty of good fresh gasoline, verify that the carburetor float valve isn't sticking shut, verify that the spark plug is good and you're getting good spark while you crank.
Aug 02, 2014 | John Deere Tractor Starter 285 345 2243...
I have a John Deere Z225 zero turn engine cranks but will not fire spark plug wet with fuel
as plug wet, either flooded, or not sparking, remove plug connect top lead and touch plug to metal, see if it sparks when turned over, if it does, with a good spark, flooding, check choke, if weak spark, check adjustment of points.
Jul 29, 2014 | John Deere Riding Lawn Mower. EZtrak Z225...
John deer 110 got spark at points but no spark at plug
If this is a Kohler engine make certain that you have replaced both the points and the condenser with new parts. You should not see sparking at the points if they are installed and adjusted correctly. For Kohler, the correct point gap should be about .020 inches - use a gauge. Don't assume that your spark plug is good - replace. While the number of spark plug failures is few I have had it happen.
Nov 03, 2013 | John Deere Garden
I have a John Deere 317 tractor that does not start. The engine turns but does not fire. The plugs and points are good. I do not get a spark at the points or plug. What should I check next next.
Tools needed:
if no
if no
If yes, coil is bad
if no
if no
if no
if no
Nov 08, 2009 | John Deere 420,1020,2010,2020,2510,2520...
BEEN RUNNING ROUGH WITH LESS POWER THAN BEFORE. NOW WON'T START AT ALL. NEW PLUG, CHANGED OIL AND FILTER, HAS A GOOD SPARK.
1956 420 john deere new plugs, wires,cap,plugs,rotor,points set on 20.condenser good blue fire on points and plugs carb rebuilt BUT want start you can pull off it will start and run
Sep 28, 2009 | John Deere 420,1020,2010,2020,2510,2520...
John deere 420 trouble starting getting gas and
May 19, 2009 | John Deere 420,1020,2010,2020,2510,2520...
John Deere 22HP Hydrostatic 42" Riding Mower Logo
60 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
