Question about Martha Stewart Living Patio Tables. Welland Patio Side Table
Plastic bracket that metal leg fits onto under glass table
The glass in our round coffee table doesn't fit in the table
Check the table with a level and shim the leg or maybe the groove for the glass is not even. It was OK. before?
Mar 17, 2013 | Anderson Collection s Montage Coffee Table
What is a folding table?
A folding table is a two or four legged table that can be flattened via hinges on each of the legs. Folding tables are very convenience because they tend to be very light weight and can save space.
May 29, 2012 | Furniture
Back seat passenger window is broken on nissan terrano
Cut up a block of hard plastic, rounding the corner to make it easy for the wire to slide on, or make a small roller out of a curtain rail component and fit it onto a metal plate with a nut and bolt though its centre. Then rivet it onto the regulator bracket. As you rivet it, pull the wire and compress the springs into their nylon sockets to make the wires remain under tension. I successfully repaired mine and the result was better than the pathetically weak original bits.
May 10, 2012 | 2005 Nissan Terrano 2.7
How do I reattach threat view mirror on my 328xi 2007
make sure metal tab is still attached to windshield diconnect the wires to give you room to rotate mirror bracket. rotate braket on 120deg. right or left from strait up and down you will need to also turn/adjust glass so you can rotate base other wise glass hits roof. then place braket on windshild base tab on glass should fit flush then rotoate strait and will lock into place then connect wires and snap plastic covers back together. note if wires not tucked back good plastic cover can be a pain to re install
Feb 27, 2011 | 2007 BMW 328xi Sports Wagon
I need to replace the light bulb in my whirlpool self-cleaning oven but I can not remove the glass cover. How do I remove it?
hello,
Here is a solution to go about the glass bellow
Removing your microwave door allows you to quickly clean out any accumulated food or grease. This also makes it easy to get to all the crumbs and debris around the door hinges. While you have the door off its hinges, examine the plastic panel and glass window for signs of damage. Make sure you install a replacement door that is designed for your brand of microwave to ensure that it will fit correctly.
  • Remove the power cord from the electrical outlet and move your microwave onto a workbench or sturdy table. For cabinet-mounted microwaves, pry off the decorative grills or front panels and remove the mounting screws. You should then be able to slide the microwave out of its mounting bracket.
  • 2 Open the microwave door and remove the glass tray. Use a flathead screwdriver or putty knife to pry off the plastic cover on the inside of the door. Work around the edge of the glass until the cover slips free.
  • 3 Remove the door by pulling the mounting pins out of the hinges at the top and bottom. You may need an assistant to steady the door so you can have both hands free to work with the pins.
  • hope this solution help?
    Thanks for visiting fixya.
    Oct 03, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
    Cosco Alpha Omega Elite can't get straps back on right!
    replace harness: 1) take **** harness and place metel bracket through the base of the seat(slot in shell) make sure buckle is facing out and not inwards. slide metal clip under small tab and push down on clip until it snaps in and locks into place... 2) thread harness without latch plate or harness retainer down through slot on one side of shell, under seat and up through slot on other side. 3) thread latch plate(clip that goes into ****clip)harness retainer onto the harness making sure they are correct. 4) thread harness end through other slot 5) make sure the harness goes over the barbut under the plastic bar, then fit loops on harness ends onto the harness bracket that looks like a triangle(kind of) 6) from the front even up harness to fit properly. And there you go the rest is pretty straight forward the base is pretty sraight forward to attach...
    Aug 17, 2009 | Cosco Alpha Omega Elite 5-Point 22-155
    How do i remove and replace the driver's side mirror?
    If the metal pivot arm is not broken you can just replace the glass and plastic housing. To remove the glass you tilt the glass down towards the floor and use a wide plastic or wood bladed object to prise from behind, the glass should pop off from its clips. Remember to catch it if its not damaged. To remove the housing once the glass is out you need to look underneath the mirror unit, there you will find a small plastic bung, gently prise it out and then use a long small flat bladed screwdriver straight up inside the hole and lever towards the front of the car whilst lifting straight up on the plastic housing, this should then lift off. To replace just slot the new housing on and click into place then fit the glass back, remember to connect the wires first if it is a heated glass.
    If the metal pivot arm is broken then you will find the remaining screws behind the plastic trim inside the vehicle.
    Oct 26, 2008 | 1998 Volkswagen Beetle
    Front Glass Door Panel on Jenn-Air JDB1270AWF Dishwasher
    Hi Fairhill,
    I'm Harvey the Master Plumber.
    Your question is: It appears that the black rubber-like adhesive that is (was) between the glass panel and the small brackets (flanges) has let go. You don't need the metal brackets; you need the black adhesive to reapply the glass panel to the brackets. Can you help identify what the black adhesive is so that we can order it?
    Any good adhesive will work. If you're never going to remove the glass panel then use liquiod nails allowing 24 hrs for drying time. If you might want to remove at a later date then any adhesive that remains plyable will work.
    Feel free contact me again!
    Please give me a rating here at fixya.com before you sign off
    Thank you,
    Harvey your Master Plumber
    Sep 27, 2008 | Jenn-Air Dishwashers
    Martha Stewart Living Patio Tables. Welland Patio Side Table Logo
    636 people viewed this question
    Top Martha Stewart Living Garden Experts
    Dennis Key
    Dennis Key
    john h
    Are you a Martha Stewart Living Garden Expert? Answer questions, earn points and help others
