Question about Mitsubishi VS-50501 50" Rear Projection Television
TV Board Flashing
I have a Mitsubishi vs-50501 projection tv and when i turn it on, one of the anodes or something in the back is fried and sending charges which are sparking out of this piece on the motherboard. Didn;t know if I could cut of that circuit and solder on a new one.
    Genius:
  • 1,153 Answers
High Voltage Transformer, FLYBACK try www.bluestar-online.com
Posted on Aug 16, 2007
SOURCE:
I need a new Lamp. what is the parts number for a mitsubishi rear projection model number VS 50501
Hello.
in VS models there is no such a thing as a lamp. Your TV have 3 CRT tubes (picture tubes) each of them dedicated to Green, Red and Blue part of image accordingly.
It is not the part that you can easy replace by yourself and it cost new around $600 and just to refurbish existing one around $320.
But you have to refurbish all three of them at the same time. So we are talking about $1000 just for parts, not to mention enormous effort to align everything back together.
If you have bad CRT in your TV - I would advise just to trash it and invest in new one.
Lamp is replaceable in DLP projection Mitsubishi TV and it is next generation of TV"s. Model number starts with: "WD".
If you still insist on part number - I need to know what color of CRT you need - they have different part numbers.
Best regards
Russ.
Aug 18, 2010 | Mitsubishi VS-50501 50" Rear Projection...
My Mitsubishi VS50501A Rear Projection TV turns on then off!
Hi name is Ernie, and i have a mitsubishi vs-50501a .... my problem is that the picture is out.. i got sound but no picture.. the problem started with the tv turning off after 15min. then i would turn it back on, 15min later it turned off again. So now it stays on but no picture.. let me know if i can fix it myself.. im mechanically incline.. thanks.
Sep 04, 2009 | Mitsubishi VS-50501 50" Rear Projection...
Mitsubishi 50inch TV Turns off right after I turn it on
tv is in shut down.could be several things.call a repairman.
May 10, 2009 | Mitsubishi VS-50501 50" Rear Projection...
Mitsubishi VS-50501 no picture sound works great
Odds are real good that the solder connections on the deflection yokes are bad. Go through the front access panel and with a small mirror look and the back side of the connector on each yoke. The top two pins of each will probably show 'ringed' solder connections.
May 07, 2009 | Mitsubishi VS-50501 50" Rear Projection...
Gradually lost picture; Mitsubishi VS-50501A
you need to buy a new lamp and replace the old one thats your only problem its about $200 for the lamp
Mar 27, 2009 | Mitsubishi VS-50501 50" Rear Projection...
Vs-50501 50inch projection with no picture only sound!
Are there any other symptoms like blinking lights on the front or just no picture? This could be as simple as a few capacitors being bad or something more severe. Can you solder? Do you feel comfortable working inside the set where there are potentially dangerous high voltages present even with the set unplugged? Let me know and we'll work through the diagnostic process and hopfully resolve this.
Thanks,
Dan
Dec 31, 2008 | Mitsubishi VS-50501 50" Rear Projection...
Sound no picture
Try resoldering the vertical output IC this is acommon problem with this model
Mar 20, 2008 | Mitsubishi VS-5043 50" Rear Projection...
Mitsubishi VS-50501 - Black Screen
Is the power light staying on? If so press imput and menu together for 5 seconds to see if the set will blink a 2 digit repeating code. If that doesnt work. Check for CRT coolant leaks on the boards. This seems to happen alot as do faulty capacitors. Coolant leaks will be located on the chassis directly under the tubes they can cause corrosion and prevent your set from starting especially in the VS models.
Dec 30, 2007 | Mitsubishi VS-50501 50" Rear Projection...
Mitsubishi projection tv
I have a similar problem. I have tried to fix the convergence via the remote and that has not helped. My three colors are separated and the edge of the picture is bent in toward the center. I am going to try a hard reset but i suspect the convergence IC are fried. Since the set is not HD, I will probably replace it if the hard reset does not work.
Nov 22, 2007 | Mitsubishi VS-50501 50" Rear Projection...
Mitsubishi VS-50501 TV turns off by itself
First check see if timer is set to come on by going throu the menu. If not then check Service Menu by pressing Menu2357 and check in there for timer on or off
Aug 16, 2007 | Mitsubishi VS-50501 50" Rear Projection...
Televison & Video Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
