Question about Sanyo DS31590 31" TV
TV only shows line across middle of screen.Still have audio.
Picture shrank to a line while watching. Turned off TV for about 15 minutes - turned back on and it played as always .about 25 -30 minutes ,The screen shrank again
  • Anonymous May 02, 2009
    this worked for mine. I resoldered all the joints listed. thanks
  • 75 Answers
Sounds like you have bad solder joints on the vertical ic which should be numbered IC501 on the board.also there are capastors that coud be going bad but i would look for bad solder joints on ic frist.
The capastors numbers on board are C502 / C516 also need to check R 483 which is a resistor.
resolder the ic if you know how to solder. That is a comon problem a lot of tvs out there have. The only thing is the tv has high voltage on it even if it is unpluged from the wall. Some of the capastors hold there voltage for a long time. Be sure and unplug tv before you try anything if you are going to do it yourself and stay away from the capastor in the AC line should be marked 200 V or moor.
Posted on Mar 12, 2009
I turned my television on then it made the tv frame made a noise!and now the screen is black except for this thin line across the middle of the screen which is display the picture
Most likely the vertical oscillator circuit has failed. As CRT televisions have gone the way of the dinosaur, my advice to you is to give a fond adieu and invest in a new TV.
Nov 05, 2015 | Televison & Video
LG 32LH30 LCD TV Problem
IMO Seriously for $119 it's not worth it.
However, it does sound like a capacitor problem
If you are "Serious" about fixing I'd find a TV repair Forum.
Else I'd go here and get a new one.
Best Wishes.
Apr 29, 2017 | LG 32LH30 32 in. LCD HDTV
SANYO TV Picture
I just bought a new Sanyo DP19649 and we can watch it for about 15 minutes then the screen goes black but the sou nd stays on. We have to turn it off and turn it back on to get the picture back for another 15 minutes-then it's the same thing all over again. The sleep mode is off and it isn't on automatic shutoff.
Jul 21, 2009 | Sanyo Televison & Video
Sony Trinitron 20" TV (KV-2093R) Suddenly Shut Off
2 things that will cause that vertical IC or Yoke! Listen to this one went on service call 2wks ago Customer had a 50 INCH1988 pioneer big screen replaced 3 capacitors resolder poor connections TV is now working like New ?
Jun 23, 2009 | Sony KP-51HW40 51" Rear Projection...
The Picture on my Mitsubishi vs-60805 "shrank" then disappeared
it isnt worth it, your verticle diflection is out, that board is about 3-4 hundred, and you would probabily need a service center do it(messing with like 30000 volts)and they will probabily charge around 200
Jan 07, 2009 | Mitsubishi VS-6041 60" Rear Projection...
Picture on RCA TV shrinks to a horizontal line
Sounds to me you have a cold solder joint ( loose solder connection ) on the printer circuit board around or on the vertical chip or on one of the vertical capacitors. You may also have a bad vertical chip or a bad vertical capacitor, but I doubt it since it did come and go. I'de get a soldering iron and some solder and touch up the connections. I will remind you that you need to always excersise saftey by making sure, before removing the back, unplug the TV from the wall, and use care not to come in contact with the large red wire going to the back of the picture tube as the picture tube can be turned off and still store lots of voltage ( up to 35,000 volts). Always stay safe and when soldering, use care not to run solder across places that will make a short.
Good Luck and I hope this helps
Ed Meshechek ( Radio Man )
NC Electronics
Mills, Wyoming
Dec 19, 2008 | Televison & Video
Problem with tv
Its known as 'screen collapse' and yes it can be fixed but it may not be economical you should get some quotes from your local tv repairers.
Nov 14, 2007 | Televison & Video
Red Line across Screen
sounds like you have a vertical sweep problem. Where the fault lies cpuld be the vertical output IC the verticle b+ feed, could be the capacitors in the vertical circuit?? Your gonna need to troubleshoot thr vrtical circuit if your not a tech thin my advise is to take the set to a pro for sn est. Good Luck
May 22, 2006 | Hitachi 36UX01S 36" TV
Sanyo DS31590 31" TV Logo
1,384 people viewed this question
Top Sanyo Televison & Video Experts
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
