Question about Kenmore Dryers
The dryer will not turn when loaded and the belt is not broke. when it is empty the drum will turn
  • 686 Answers
Try a new belt stretched belts will cause this problem if that's not it then i think your motor is getting weak too weak to turn the full drum
Posted on Mar 12, 2009
Maytag ensignia dryer drum not turning
The belt would be the first thing I would check sounds like it may have broke off.
Here is a link for parts and other causes. Maytag Dryer Drum Not Turning
Jul 14, 2016 | Maytag Dryers
Dryer heats but doesn't turn.
Most likely the belt broke on the drum. Less likely the motor died. When turn the dryer on do you hear the motor running? If so you probably broke the belt. You will have to unlock the top and pull the front off. The belt rides around the drum towards the back of the dryer.
Jul 21, 2015 | Dryers
Tumble dryer drum not turning under load
Was the belt changed recently? The reason I ask is because it sounds like the belt was put on backwards, meaning the ribbed tire looking side of the belt is facing upwards instead of making contact with the drum. The symptoms of this are the exact same you are describing.
May 15, 2012 | Dryers
My whirlpool dryer front loading wont turn the drum i change the control board but still wont work .
did you check the belt to see if it's broke,the belt raps around the drum and the motor,when the motor turns on and spins the belt spins the drum.
Mar 28, 2011 | Whirlpool Duet Front Loading Dryer Rack...
Dryer heats but drum does not turn when the start button is pushe
You need to check the drum belt. With dryer empty, reach in and give it a spin. If the belt is good, it will stop in 1/2 turn or less when released. If the belt broke, it will spin almost a full turn.
Oct 25, 2009 | Kenmore 62602 Electric Dryer
Past few days, dryer got very noisy. Then drum
The noise is coming from a moving part. There are only a few that normally cause a problem. Also the dryer drum not turning freely is what broke your belt. Here is what I would replace. Drum rollers, Drum slides and idler pulley. You can check these parts before you replace them. If the drum rollers don't spin real easy, replace. If the idler pulley does not turn easy, replace. If the drum slides are worn, replace. Your model may be one with a front drum bearing. If it looks worn, replace.
You may be able to take dryer apart, try turning drum. Listen for the noise and notice if the drum is hard to turn. If so, you may be able to determine if the problem is in the front or back of drum. Keep on mind that the noise might have been the belt slipping due to the drum being hard to turn. Either way, when you have it repaired, it should run with the noise. Good luck.
Oct 16, 2009 | Kenmore 400 6943 Dryer
Dryer drum does not turn
Most likely the belt broke, replace the belt
Aug 14, 2009 | Dryers
Element heats but dryer drum does not turn. It is a front loading Kenmore dryer. It seems the drum is off what ever it is that keeps it in place.
Your belt broke or just came off. The belt keeps it in line and turns the drum. If you're handy you can replace it yourself. make sure the thing is unplugged, it's 220 volts. take the back off. the belt goes around the whole drum and the motors pully. It takes some doing but it is doable. If it's broken, Order a new belt from the dealer and replace it. or if you're not so handy or just don't want to deal with it call a service man to replace it.
Aug 10, 2009 | Dryers
Drum turns but not when it is fully loaded
Do you hear a loud hum when fully loaded? Or does it go away when empty?
Sep 20, 2008 | Amana DLE330RAW Electric Dryer
Dryers Logo
53 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
