Question about AT&T Blackberry Curve 8300 Smartphone
My blacberry 8300 wont charge up , i think my charger terminal on my fone is not working can ne1 help?
  • 173 Answers
If you are sure that your charger is ok, then it is the USB port on your phone. This can be replaced. Please contact me or another dealer near you from the Cellular Repair service directory at the buttom of the page for help on this
Posted on Mar 14, 2009
I have a problem with my mobile nokia n81 8gb charging problems. When i put the charger in my mobile it says charging but the battery doesnt go up and down like it use too also when i press the charger...
from your explanation, the problem is from your charger, it is either its making partial contact somewhere or if you have purchased another charger asides the one which originally came with the fone, then it might have been substandard. try using a different charger on your fone or/and your charger on a different fone, this should help you confirm where the problem is from
Jan 01, 2011 | Cell Phones
Blacberry turned off suddenly,no red light
you need to reflash the OS on the phone you should take the battery out first then connect it via the usb cable to the laptop/pc you are using then open the blackberry desktop manager,click on the apploader, then install the OS.
pls not that when u click on the apploader the pin should be PIN:UNKNOWN you make need to do this like 4x before the pc sees the pin:unknown but it will work once it see the pin:unknown you can re-insert the battery and continue with reflashing the phone
Oct 05, 2009 | AT&T Blackberry Curve 8300 Smartphone
My Lg Env VX9900 wont charge or play sound!!!
u do i had the same problem had to buy a new charger it has a shortage
Jul 10, 2009 | Cell Phones
6230 not charging
it seems that there was a problem on the charger terminals thats why it will not charge, it is better to send it out for repair to check the charging terminals on it,
Jul 02, 2009 | Nokia 6230
Problem downloading Blackbery messenger for 8300
go to www.blacberry.com then update your OS (messenger included)
Mar 07, 2009 | AT&T Blackberry Curve 8300 Smartphone
Won't Charge- Is there anything I can do?
well i dont have any long term ansa but here is a short term one while you find a new charger.
Take the charger and dismantle the end that plugs into fone. you should have 2 wires a black & white or black & red. Leave the blobs of solder on the end of the wires as this helps. Leave the wall socket end of charger in tact.
Take your battery out of fone. As with a normal battery you will see a (+) and (-) sign on it. Attach the black or darkest wire to the negative (-) metal square on the battery and the white or lightest wire (maybe red) to the positive (+) metal square on the battery (after trial & error i found a clothes peg to be the best form of attaching it). Leave attached for 15 minutes and this will give you around an hours usage when you put the battery back in the fone. If you leave it overnight then it will be on all day.
Basically you are making the circuit without the fone which bypasses your pin problem. Any charger will work with any fone as the charging components are in the wall end. Just make sure the voltage is compatible ie, 5v fone charger replacing 5v charger etc. Although majority of chargers are 5v.
I know this works cos i did it to mine last nite as i needed to ansa my emails. Really simple but a little drastic like i said but if the pin connector is broke anyway wot you got to lose?? I am a girl so if i can do it anyone can lol!!
Only drawback is you cant use the fone while it is charging unless you have 2 batteries and you use one while the other charges which is what i am doing. In fact i might not buy a new charger lol, i dont need one now ive found this method works.
Happy charging!! Hope this helps! Gail-michelle
Jun 14, 2008 | LG enV VX9900 Cellular Phone
N95 is dead and wnt charge
It could be a software problem. Try performing a master reset or firmware update.
May 30, 2008 | Nokia N95 Cellular Phone
My fone
it wont charge may be bcoz there is some problem in charger or there is a problem in battery..
this may also happens if you are not using the charger which is specified for that cell...
try changing battery first from any of your friend s cell ..
if problem persists then change the charger and try ..
if the same problem persists then the charging IC is gone i think so just take your cell to technician .......
Feb 14, 2008 | Sony Ericsson Walkman W810i Cellular Phone
Charging problems
umm dat mite be a prob becuz the car usually pumps more voltage in the fone...........and if too much is pumped it damage the circuit board and mite even fry the system...... be care ful and keep trying the wall charger..........hope it works
Feb 21, 2007 | Motorola Mobility RAZR V3
AT&T Blackberry Curve 8300 Smartphone Logo
155 people viewed this question
Top AT&T Computers & Internet Experts
Computer Repairing
Computer Repairing
Prashant M
Prashant M
Are you an AT&T Computer and Internet Expert? Answer questions, earn points and help others
