Question about Linksys Wireless-G Broadband Router
Why can't get wireless connection with router?
It worked yesterday
  • jimsharon Mar 13, 2009
    Tried the off/on and still no connection on the lap top. There are twoboxes, one that looks like the picture with the rabbit ears. The othera little black box with lights in front. The black box input and out putlights not on. Assume that means it is not getting a connection fromthe cable input. Someone suggested to slow of speed from Cox cable. Recently added Magicjack. Think the speed is the issue? Do I need to jump up the speed?
  • 43 Answers
There are so many cause of that problem:
1.) Its due to interference of signal
2.) Due to hardware functionality.
3.) Due to driver problem.
Things to do if applicable:
1.) Check appliances that cause interference.
2.) Check the the hard if it function well.
3.) Reinstall driver.
Posted on Mar 12, 2009
    Genius:
  • 1,066 Answers
Unplug the router and the modem, reapply power and let them reboot, this should solve the problem
My Dell desktop using Windows XP can't connect to my Belkin 5720 router but my laptop still works?
This sounds like a hardware failure, but just in case go to your computer Control Panel-Network Connections(Network and Sharing Center for Vista and above), and check your Network adapter settings. If your Network card is not showing, you may have a driver issue, or a bad NIC (Network Interface Card). It shouldn't matter that your router says" wireless hardware not detected", because you are hardwired from the computer to the router. I would check to see if you may have turned off, or blocked Ethernet connections on your router, I would then change my Cat5 (Ethernet) cable, and finally open the desktop and change out the NIC (Network Interface Card).
Mar 24, 2012 | Belkin Computers & Internet
Cannot connect to internet today. Yesterday all was well.
If the modem works and a desktop pc works through the Ethernet port of the router, then try plugging the pc laptop into the same Ethernet port using the same cable as the desktop. Most laptops have an Ethernet port.
If this works, then the problem is the wireless access?
Check you still have the wireless set-up on the pc laptop, if not re-install it.
Mar 03, 2012 | EnGenius ESR-1221 EXT Router
Worked fine up till yesterday now wireless wont work
The wireless cards in the computers need to be configured with the router's wireless settings so the computers can connect to the wireless router.
Resetting the wireless router back to the factory defaults will not let the computers connect to the wireless router without configuring the network card in the computers with the router's wireless settings.
I suggest you configure your wireless router with encryption settings to prevent unauthorized persons accessing your wireless network and Internet connection and your computers.
To secure your wireless network from unauthorized access,please click on this link and follow my instructions :-http://www.fixya.com/support/r3559128-wireless_router_security
Mar 01, 2012 | Computers & Internet
Router connects to the internet using cat 5 cable but not wirelessly today. Worked fine yesterday. Icon in system tray has my home network connected, but, it says "no internet"
try pinhole resetting the router. Hold it down for 30 seconds, then pull the power, then press and hold it for 30 more seconds, then plug the power back in.. then press and hold it for another 30 seconds and let go.
Try connecting wireless again, if this doesnt work the router is broken. Get a new one.
Feb 05, 2011 | Linksys Wireless-G WRT54G Router
I have a linksys wireless g router that worked fine until yesterday. Now it won't connect to the internet. I have a desktop wired to the router and a laptop used wireless.
Check if you can connect to the internet when hooked directly to the modem. If your connection works fine through the modem, then your router needs to be reconfigured.
May 13, 2010 | Linksys Wireless-G WRT54G Router
My second computer wont connect to the internet. it was working fine yesterday and my girl shut it down because it was running slow. she turned it back on and it wouldnt connect.
Is it a wireless computer ?
If it is wireless computer then make sure that it is connected to the wireless network .
If ti is connected not connected to the wireless network then you will need to connect to the wireless network.
If it shows it is connected then check the IP address on the computer.
Click Here for more information about the routers and network
Feb 24, 2010 | D-Link RangeBooster G WBR-2310 Wireless...
Wireless Router suddenly stopped working.
Try resetting the Linksys back to the factory defaults and configure it again.
Power up the router and press the pinhole RESET button on the back of the router for 30 sec
Connect a LAN cable to the wireless router and open a browser and enter to router's configuration IP address and configure the wireless settings, remove the LAN cable when configuration is completed.
You need to configure then wireless card in the computer/laptop with the router's wireless settings.
Dec 10, 2009 | Linksys Wireless-G Broadband Router
DSL 2640 T - Wireless connection problem
go to your mom and ask if they know how to fixed that problem that you have ,, tc hahaha
Oct 19, 2008 | D-Link ADSL2/2+ Modem/Wireless Router...
Cant connect to wireless router
Make sure the wireless adapter is enabled on the elonex laptop and its properly installed.
Connect wirelessly on the elonex one laptop using the same SSID and security key that you used on your main laptop.
Aug 07, 2008 | Belkin (F5D7230-4) Router (587009)
Linksys Wireless-G Broadband Router Logo
105 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
