Question about Bissell 1400 Little Green Pro Canister Steam Vacuum
Won't spray I can't get my bissell to spray soapy water. I got on line to find advice to unclog the nossel by sending water through the opposite direction. I used a water pik to do that. It took several attempts before water came out the other end. Then I tried to spray water again and only got a drizzle. What next?
  • poohspot Dec 10, 2008
    I have same problem. Bought the cleaner, used 2-3 times, would not squirt for at least first 5 minutes of run time. Brought back to store, got another, same deal. Searching for some other user / same problem /
    answers before I take apart and solve myself.
    New Friend:
Throw the piece of **** away and go rent one like I did.
Posted on May 04, 2012
  • 281 Answers
Your pump is bad.i have one doing the same thing.everything works fine except it won't spray,just dribbles
Posted on Apr 27, 2009
SOURCE:
My Bissell pro heat upright carpet cleaner will not spray water from attachment
Many times due to not cleaning the nozzle when done they clog with the soapy mixture between uses . they must be cleaned (clear water flush)after every use to maintain good service
Jun 02, 2018 | Bissell Vacuums
Water won't stop spraying water 9400 bissell
Hey, you may want to have a Qualified Technician at a BISSELL Authorized Service Center inspect your machine.
Here's a quick link to locating one of our Authorized Service Centers in your area.
http://www.bissell.com/service-centers/?cid=ccsocial
Jan 27, 2013 | Bissell ProHeat Turbo Deep Cleaner Upright...
My bissell spot lifter model 1716 won't spray water at all, how do i fix this?
ok - this works even though it probably isn't the "best" solution. Unclog the input and output nozzle ares with a pin. The input area (behind the solution) was my clog problem - I put 2 or 3 drops of CLR into the hole, waited 5 minutes, then primed the trigger. This unclogged it! Fill the tank with a 1:1 ratio of white vinegar and warm water. Insert tank into unit and spray out the contents into the sink. This will eliminate any leftover CLR residue and clean the nozzle thoroughly. For the intake (suction part of the tank) I just rinsed through the lines with the vinegar mix and it seemed to unclog the rest. These things are a pain to take apart and if you break any pieces you'll be stuck - replacement parts have been discontinued for older models.
Sep 20, 2012 | Bissell 1716 SpotLifter PowerBrush
Bissell proheat turbo sprays water but does not spray the cleaning solution. How do I unclog it?
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
rsttsr
Jun 14, 2010 | Bissell ProHeat Turbo Deep Cleaner Upright...
Unable to get the cleaning solution/water to spray out...haven't used it for months. How do I unclog the line?
Can you disconnect the line at both ends? If so, do that and using a syringe, or a long piece of wire, poke out the obstruction and reattach.
Sep 22, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
The dirtlifter powerbrush do not trun.the belt are ok and i unplug it and trun it back . still not working
I have a Bissell Dirtlifter Powerbrush that will not spray soap. I assume the soap lines are clogged, but how in the heck to you "unclog" them? I've searched high and low on the Internet looking for that answer.......
Apr 20, 2008 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissell Spot Lifter
Feb 29, 2008 | Bissell 1715-G Spotlifter Bagless Handheld...
Bissell 1400 Little Green Pro Canister Steam Vacuum Logo
657 people viewed this question
Top Bissell Vacuums Experts
CJ C
CJ C
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
