Question about liftmaster Chamberlain Garage Door Opener Transmitter 300MC
Garage door motor just humms
It's chain driven and all i get is a humming noise and the spocket does not move
Sorry to say you may have a burned out motor. i replaced my motor when i had that problem and it worked. Pretty simple to do if you are handy with tools.
Posted on Mar 16, 2009
My Lift Master garage door will not close. It makes the closing noise but the door does not slide down. Whcan I talk to to fix this?
Sounds like you have a chain drive garage door opener and you hear a humming sound when you push the wall console. The motor is running but the chain does not move. You need to replace the gear & sprocket assembly.
Jul 06, 2014 | liftmaster Lift Master 377LM 376LM 315 MHz...
M otor hums but door does not open
If the motor is running and the chain or belt isn't moving, you have a broken gear in the opener.
Mar 26, 2014 | Sears Craftsman LiftMaster Chamberlain...
Chamberlain LiftMaster Pro 2245 garage door has started making a noise (slight clunking) only when closing. I disconnected the garage door and the noise continues. I've looked at the sprockets and the...
I would take a close look at the sprocket/gear assembly. There is a bronze bushing that wears and lets that assembly lean. This can cause the chain to miss the teeth on the sprocket just a bit and will cause some weird noises. If it gets bad enough the chain will come off the sprocket. I have no idea why it would only do it in the down direction when there is much less strain on the whole thing. You might also remove the cover from the motor unit and check the drive gear. It is white nylon and wears out. It will be obvious if it is going bad.
Mar 19, 2011 | Sears Craftsman LiftMaster Chamberlain...
Door will not move up or down,the drive motor just hums.
On the inside of the motor box, check to make sure the chain has not come off the gear.
Apr 05, 2010 | Chamberlain Powerdrive PD422D 1/2 HP...
Garage door does not open or close
You have a stripped drive gear. Remove the cover from the motor unit and you will find white sawdust all over. The part number for the gear kit is 41A2817 and is available at any good door opener service company. It comes with instructions.
Feb 12, 2010 | Sears Craftsman LiftMaster Chamberlain...
Motor hums but door doesn't move. If I disconnect door and give chain a horizontal poke, it will move. When I reconnect door it returns to humming, without movement.
Remove the cover from the motor unit and you will find the drive gear has stripped. White sawdust all over. The part number for the gear kit is 41A2817 and it comes with instructions. It is available at any good door opener service company.
Feb 04, 2010 | Sears Craftsman LiftMaster Chamberlain...
Liftmaster door opener, motor hums but chain and door does not move. Any ideas? Thanks
If the motor is running but the chain isn't moving you have a stripped drive gear. Remove the cover from the motor unit and check. It should be obvious.
Jan 08, 2010 | Sears Craftsman LiftMaster Chamberlain...
Garage door doesn't open or close
You should check the gears inside the box, After years , the gears get dry and die, you can by online or from Sears the kit and replace the old gears. I just changed mine...not too difficult :) .
Mar 11, 2009 | Chamberlain Powerdrive PD422D 1/2 HP...
Lift-master chain drive garage door stuck at the protection bolt
you will have to find were the chain is binding look around the drive sprocket and check the chain to see if it is tight at the bottom or top this will tell you were to start looking for the problem.
Sep 19, 2008 | Sears Craftsman LiftMaster Chamberlain...
liftmaster Chamberlain Garage Door Opener Transmitter 300MC Logo
266 people viewed this question
Top liftmaster Electrical Supplies Experts
Vince Heuser
tamska1102
Level 1 Expert
ray gallant
Are you a liftmaster Electrical Supply Expert? Answer questions, earn points and help others
