Question about Husqvarna 160 CC Honda OHC Engine 21 in
4514 Honda lawn tractor thread pattern fo a 42 inch deck
2 Suggested Answers
  • 407 Answers
SOURCE: My Husqvarna lawn tractor deck will not engage
First check the belt.Make sure it is tight when the lever is engaged,and the engine is off.Make sure the belt is on all pulleys,and inspect for frays in the belt.If the belt is ok then,run your hand under the fender around the area of the lever.Make sure there is no debris blocking the lever from fully engaging.If that is good.Next inspect the linkage between the lever`s handle and the deck.Again make sure there is no debris and all connections are snug.
Posted on May 16, 2011
Will an older 42 inch murray riding lawn mower deck interchange with an older rally riding lawn mower deck ?
Mower decks are very specific to the tractor. Unless it was the same manufactured mower, and just branded differently, then not likely! Belts are your next problem as even an inch longer or shorter will cause problems.
May 07, 2016 | Murray Garden
Craftsman Lawn tractor 20 hp twin clynder briggs with a 42 inch deck I need a model number the plate is unreadable
Maybe this will help.The mower deck part # 165892. Mower Deck Assembly 42" I not sure of the model # . I also don't know your tractor's model # either. This part # for the 42" mower deck,is installed on a 18.5 HP Craftsman Lawn Tractor. I believe there isn't any difference between a model !8.5 HP and a model 20.0 HP, tractor when it comes to a mower deck. B.Locke
Sep 14, 2015 | Craftsman Garden
What is the belt configeration for a Craftsman 917.254214 ride on mower?
This video shows several belt patterns for various mowers. I am assuming you are wanting the deck belt and not the drive belt. 4 seconds into the video is the standard craftsman 42 inch belt path. The belt at the bottom is put on the engine pulley. Tip from my own experince make sure that the belt is under the belt guides or you will ruin a belt in short order. Your model number is under the seat and is also a scanable barcode. Another tip is to snap a photo of your model numbers. This is handy when you need parts. More accurate and readable than writing it down. Riding Mower Deck Belt Diagram DIY
Jan 12, 2015 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Got a craftsman mower 42 inch deck changed spindles and blades and deck still shakes belt may not be tightening up
did you put the blades on right ??? they have a star pattern and it needs to be lined up correctly... if that's ok does the belt have a bad spot in it or is the engagement mechanism operating correctly ???
Oct 20, 2014 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
What is the diagram for steel deck installation for a poulan lawn tractor 42 " deck 14.5 hp ?
Do a search on goggle for the make model and deck size and you can see the routing diagram.
Jun 15, 2014 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
I am trying to change the blades on my Craftsman 42 in mowing deck, but cannot loosen the bolt. Is it a right hand thread?
they are real tight
reg thread
righty tighty lefty loosy
get a cheater bar some good leverage or an impact wrench
May 04, 2013 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
How do i replace a blade that had fallen off. 42 inch tractor. The main problem is how to get underneath the tractor?
To replace blades, belts, sharpen blades, etc. one must remove what is called the cutting deck from the tractor.
Once the deck is off the tractor, pull it out, turn it over and you can work on the blades.
Gary
Jul 10, 2011 | Ariens 42" Riding Lawn Mower Blade ...
Blades on my Sears Craftsman riding 42 inch lawn mower will not disengage.
It might be that a drive belt is too small and doesn't release. It would be where the power goes from the engine to the deck.May have to get bigger belt.
Apr 17, 2011 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Craftsman 42 inch belt diagram
look on deck or under foot pedal there is usually a diagram in those places
Jun 22, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Poulan Lawn Tractor 42" 14.5 hp Model 733-864 How do you remove the rear wheel to fix flat tire?
I need the diagram for a drive belt for a 42'' lawn tractor - 14.5 hp Can ANY ONE help me?
May 21, 2010 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
Husqvarna 160 CC Honda OHC Engine 21 in Logo
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
