Question about Dehumidifiers
Friedrich dehumidifier d50bp brand new set up leaking all over the floor with no water in bucket?
SOURCE: humidifier not taking out water
On my third unit.
First unit worked well (but loud) died in 5 weeks, replacement (14.99 to ship) was DOA, third unit appears to be working. Horrible bucket design, it's impossible to remove and carry when full without spilling. Float level is set too high, no adjustment..
Would not recommend.
Posted on Jul 08, 2008
SOURCE: ghd30y7 goldstar dehumidifier
We came home to this problem the other day, water all over the basement, leaking out the bottom left side, nothing in the collection basin but plenty would spill out if I tipped the unit forward. After searching the web and these forums I theorized that the coils were frozen. I let the unit thaw. No luck. I removed the faceplate and discovered thick, wet silt had filled the internal collection plate and was clogging the drain. I stuck a pipe-cleaner through the drain and the problem was fixed. Took some paper towels and cleaned the whole thing. Works like new. I assume the unit will need to be cleaned regularly to keep it going. To remove the faceplate, unscrew the two phillips' head screws under the faceplate along the sides, then take a flat head screwdriver and pop the tabs holding the face on, one tabe along each side. There are also two tabs on top, but you don't need to mess with those, as they simply act against gravity. Whole thing just clips back together after cleaning. I have no idea if this voids the warranty.
Posted on Oct 01, 2008
SOURCE: Dehumidifier Error?
Same problem with Goldstar model DH404EY7 -- stop code 01 on startup, bucket full light blinks (drains to floor).
Replaced the main controller board to fix it.
For my model dehumidifer the part # is 6871A20888A, and cost $77.44 (not counting shipping) from Appliance Factory Parts. The Appliance Factory Parts web site also provides parts breakdown (exploded parts diagram) diagrams and service manuals in PDF form.
Posted on May 02, 2009
  • 5 Answers
SOURCE: water not draining in the bucket
have u checked the drain on it?? or if there is a filter might be dirty
Posted on Jul 01, 2009
SOURCE: DeLonghi dehumidifier hose by drain tray leaking
I think that I am having the same problem, but I'm not sure that this tube needs to be plugging into anything. However, my humidifier seems to be draining out of this tube rather than from the tray into the bucket.
Posted on Jul 18, 2010
Hi. My dehumidifier stopped working. It powers on, but does not do anything.
Check if the full light is lit. If so check that the float switch is free.
On page 5 step 3 they discribe how the float switch needs to be free?
http://www.sylvane.com/media/documents/products/friedrich-d70bp-dehumidifier-owners-manual.pdf
Jan 16, 2016 | Friedrich Dehumidifiers D70bp
It is making a lot of noise. Still seems to work.
I get this complaint a few times a month , what I usually find is that the circulation fan has a build up of fuzzy lint on the blades and it throws the fan out of balance (hence the noise) a soak in a warm water/soap solution usually takes care of it , disassembly is required for this , I usually charge two hours labor for this
Dec 01, 2015 | Friedrich D50BP Dehumidifier
How to make unit drain through hose, instead of filling bucket?
Assuming you have a hose connected to the bucket for drainage, it is necessary that the end of the hose be lower than the top level of the bucket or the bucket will fill before the hose drains. I see many people who have their units on the floor and run a hose up into a sink and wonder why the bucket fills. Gravity works.....if you cannot find a lower place to drain the water then you must raise the unit up on a table or stand of some sort to get the bucket higher than the drain.
Sep 16, 2015 | Friedrich 25 Pints Dehumidifier 115v power...
Dehumidifier seems to be running fine, but water leaking on floor even with minimal water accumulated in bucket?
Hey friend, thanks for your post!
It sounds like your dehumidifier needs to be professionally cleaned. What could be causing the problem is a buildup on the inside of your dehumidifier where the water drains out and it is causing the water to not drain properly. Additionally, I would check to verify that the drain hole is tightly secured with the plug. I know you stated that the bucket is not leaking but have you removed it to verify? Please comment back if further assist is needed. -Matt
Sep 13, 2014 | Frigidaire FDF50S Dehumidifier
Kenmore 54351 Dehumidifier is leaking -- water isn't going into the tray, but seems to be leaking out into the floor.
Mine is doing the same thing. The bucket is dry and the floor is flooded, so it is not an inability to condense, and it is not that the bucket has overflowed, and the bucket does not have a leak. It had been working great and then this suddenly started happening, it's as if the water is not flowing along the proper route and instead is gathering behind the bucket.
Nov 27, 2012 | Kenmore 54351 Dehumidifier
Amana D965e-e dehumidifier leaking
I encountered a similar problem (using the bucket, but still getting water leaking onto the floor) with my 970E-E. The problem is a design flaw. If the bucket is not firmly pressed into the dehumidifier, there is a slight air gap between the bucket and the dehumidifier on the left side. Within the gap, warm moist environmental air cools. Water condenses in the gap and pools up at the bottom of the bucket shelf, eventually spilling over onto the floor. You can check and see if this is your problem by pulling out the bucket and inspecting for droplets along the left side of the bucket shelf. My solution was the bungie the bucket into the shelf firmly so that there is no air gap.
May 29, 2012 | Amana Dehumidifiers
Our Friedrich D50C humidifier is six years old. Worked great until a week ago it seems to turn on- then an unordinary noise occurs and moisture is not pulled out.
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Sep 04, 2011 | Friedrich D50C Dehumidifier
Water is not collecting properly in the bucket. I ran it for an entire day, and only about half an inch collected in the bucket while more than that amount of water leaked from the unit. There was a puddle...
heatman101
Apr 30, 2011 | Soleus 8649045FB Dehumidifier
After 3 hours there is no water in the bucket. Why?
There are many reasons why a dehumidifier will not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier
heatman101
Apr 16, 2011 | Friedrich Dehumidifiers
LG dehumidifier
I Have an LG Dehumidifier and water has leaked out to the basement floor, it has a hose that drains into the floor
Sep 12, 2008 | LG LHD65EBL Dehumidifier
Dehumidifiers Logo
108 people viewed this question
Top Dehumidifiers Experts
Bill Long
Gil Shultz
jasbo
jasbo
Are you a Dehumidifier Expert? Answer questions, earn points and help others
