Question about Gilmour Garden
Need instructions for Green Thumb sprayer #131388
The sprayer body says "Important! Read instructions in carton before using sprayer. DANGER Failure to follow CAUTIONS and INSTRUCTIONS can cause tank, hose or other parts to weaken and burst. This can result in serious injury." The senior citizen I am helping does not have the instructions. Where can I find them on-line?
4 Suggested Answers
SOURCE: instructions for using ortho tree sprayette
The Ortho Tree and Shrub Sprayette has a fixed mixing jet set to a 24:1 ratio. 5.3 ounces of spray concentrate in the jar will mix to produce 1 gallon of diluted spray. The jar has a capacity of 42.7 ounces, so you can spray up to 8 gallons with 1 filling. If you look at the side of the jar, you will see two filling scales. On the left is the diluted spray capacity, and on the right is the concentrate scale. So you will see 8 gallons opposite 32 ounces, for instance.
You must dilute concentrates to the 24:1 mixing concentration. So if your concentrate says 1 ounce/gallon, and you want to spray 6 gallons, put in 6 ounces and add water to the jar to the 32 ounce level.
Posted on Jun 25, 2009
  • 623 Answers
SOURCE: 486 Sprayer, lost instructions, sprayer lable washed off
See if this helps:
http://www.gotosprayer.com/sprayers/hose-end-sprayers/gilmour-dial-a-mix-hose-end-486
Posted on May 25, 2010
  • 146 Answers
SOURCE: Need replacement part for 16-gal sprayer. It's
The spray wand has a short plastic tube that the rubber hose slides over. Here's what it should look like, if it's not broken: 4bc420c.jpg
A 'band clamp' goes over the rubber hose to tighten it onto that little tube. If the band clamp is missing, you can get one at a hardware store - just find the size that fits over the rubber hose. If the rubber hose end is torn or cracked, just make a new clean cut with a knife.
But if the plastic tube has broken off the wand, you need to get a new wand. Good news - it's not expensive. This one's only 8 bucks.
Hope that helps you, if so please rate my solution, thanks and good luck!
Posted on Jun 08, 2010
Where can I find a schematic for the Krause & Becker paint sprayer? Mine is no longer working, and I noticed a disconnected set of wires hanging out the bottom of the pump casing.
[PDF]Airless Paint Sprayer - Harbor Freight Tools
manuals.harborfreight.com/manuals/68000-68999/68001.pdf
Airless Paint Sprayer. Item 68001. Read this material before using this product. Failure to do so can result in serious injury. SAve thIS mAnuAl. Notice.
Sep 26, 2015 | Tools & Hardware - Others
DO I need to reprogram bcm if I will buy it brand new from ebay?
Yes it needs reprogramming ! The dealer is the place to have that done !
Body Control Module Programming and Setup
The procedures below are designed to set-up the body control module (BCM) correctly during BCM related service. Before you start, read these procedures carefully and completely.
Important: The following procedures must be followed:
  1. Programming the BCM
  2. Learning the restraints ID
  3. Programming Theft Deterrent System Components
  4. Program Key Fobs
  5. Program Tire Pressure Monitoring (TPM) System
Programming the BCM
Important: After the procedure is completed, the personalization settings of the BCM are set to a default setting. Inform the customer that the personalization must be set again.
Perform BCM special function "Request BCM Info. for SPS", then follow the instructions on the screen. Refer to Service Programming System (SPS) for more information.
Aug 11, 2015 | 2006 Hummer H3
Where can I get an instruction booklet?
the best thing you can do is to throw your oven onto trash instead to find booklet !! because this is the worse appliance that invented until now due to danger of high pulses on the human cells after a while
of using it. This technoloy not for help people for keeping their health but only saving time and energy . so which most important : health or saving time and energy?
like seedless watermelon easy to eat but no body know what its danger on health ?
Sep 23, 2014 | Microwave Ovens
Why does my Green thumb .5 gallon sprayer leaks when pressurized?
sounds like your your rubber seals have worn out,or one has broken fully or you have not put it back on properly
Jul 18, 2014 | Green Thumb HD Hudson 79142GT Gt 2L Hand...
Manual for 60000gt sprayer
Go online to company, customer service.
Jun 05, 2014 | Green Thumb HD Hudson 60000GT Gt...
When I pump up the Green Thumb two gallon sprayer, air escapes from the top in the center by the pump handle. Also why must I add oil to the holes in the top?
You add oil in the two holes to lubricate the seals around the pump shaft. Maybe the seals have dried up now and that is why the air leaks by.
May 26, 2010 | Gilmour No 2pgt Green Thumb 2 Gal Ld Tank...
Replace 0-ring
all I want to know is how I can get a replacement o-ring ASAP without paying to discuss my needphone number and person to call would be helpful.
Mar 23, 2009 | Gilmour & Spray Doc& Poly Tank Sprayer...
Garden Logo
672 people viewed this question
Top Gilmour Garden Experts
cackelberry
Level 1 Expert
Charles T Nevin
Charles T Nevin
Are you a Gilmour Garden Expert? Answer questions, earn points and help others
