Question about Watches
My jc penney model 3565 cuckoo clock chimes 2 hours ahead of the set time
Also, the angels at the top don't rotate
escapement
  • 2334 Answers
SOURCE: Strausbourg Manor Wall Clock chime adjustment
It is normal for the average wall clock. Of course, this can be adjusted, but without watch/clockmaking knowledge it is impossible, because first you need to find out which part of the movement is causing early chiming - and there are plenty of them.
Super fine adjustment can be found only in top of the range clocks. Hundreds of hours of craftsmenship are spent to adjust and fine tune them. That's why they cost a fortune.
If you can not live with that early chiming, you have to bring your clock down to the watch/clock repair shop and ask for help. Be ready to pay quite a money, as this job takes the skill and a lot of time.
Rate me, please.
Posted on Jul 29, 2009
cmcduncand
  • 714 Answers
SOURCE: my new wall clock chimes 2 minutes BEFORE the
You will need to do a mechanical adjustment to the hand.
Loosen the hand nut and adjust the hand the tighten.
Hope this tip helps to solve your problems
R/
David
Posted on Mar 19, 2010
Testimonial: "i will try this. thank you so much"
alpug
  • 1961 Answers
SOURCE: How do you set the
Please be guided by this rule:
1. Use the minute hand only
2. Never move the hour hand by itself to set the clock
3.Never move the hand while the clock is chiming or striking.
These are the instructions. Please be guided too that It will take up to twelve hours before the chime sounds completely synchronize with the correct time.
1. Open the clock door to gain access to the clock hands.
2. Set the day/night lever all the way up --the strike position-- if applicable. Also, if your clock has automatic chime sequencing, turn it off. Setting the time with the lever set on "auto" may damage the chime mechanism.
3. Move the minute hand backward to the correct time. Do not move the hour hand--it will move as you adjust the minute hand. Moving the hand backward removes the need to wait for the chimes to sound when you pass each quarter hour. The chimes automatically synchronize with the time. It can take up to 12 hours for the chimes to sound properly and in sync with the time
I hope these will help you in your setup while patiently waits until the chime sync with your time.
Thank you for using Fixya.
Alp
Posted on Sep 25, 2010
SOURCE: timex westminster anniversary chime clock doesn't chime correct number
Take the batteries out from the base, where the chime mechanism is. Wait till it gets close (20 seconds till) to a specific hour time, like 8:00 or 9:00, replace the batteries for the chime mechanism. And then count the chimes at the hour. If they are correct, you are set. If they are incorrect, turn the time back 15 minutes before the hour and bring it right back and monitor the chimes again. Hopefully this should fix it. Please post the results.
Posted on Nov 10, 2010
SOURCE: Kaiser clock model kc-2.
remove the batheries and then advance the mintue hand slowly until you hear a clicking noice then remove both the hour and minute hand and place both at 12 oclock high postion advance the minute hand again to confirm you hear the click noise when the minute hand is at 12 and the hour hand is at 1. then replace batteries and the clock should cuckoo properly on each hour,,,,,best regards
kaiser clock
Posted on Mar 09, 2011
NEED DIRECTIONS FOR CHIME
clocks chime the hour
what is the point of having a clock that chimes every 2 hours because you will not know how long it was from the last chime or be able to calculate the time between chimes
Dec 28, 2015 | Watches
I have a cuckoo clock . Time is 11 and the cuckoo chimes 8 times . What do I do? It's a non mechanical clock
If the clock is chiming like this it means that the hour hand is out. GENTLY loosen the hands, place the hour hand on the hour that the clock has chimed then fasten the hands in place. Gently move the minute hand clockwise Only, and check each hour that it strikes right. If the cuckoo has a button at the back use that instead. For more information email me at yvonne.finch@gmail.com
Mar 08, 2013 | Watches
How to sync. an old Black Forest cuckoo clock.
Suppose the cuckoo is calling three and the time is showing eleven, then to synchronize, simply stop the clock till the time is the same as the bird (three) and restart the clock at that time.
If the error persisys, then pull off the hour hand, and replace it at the synchonized time.
Jul 13, 2012 | Watches
LGC310 mobile phone has a cuckoo chime every hour on the hour, how do I turn this off?
Press the "OK" button then "settings" then "date and time" then "time" then scroll down to "hour indication" and change this to off.
Feb 09, 2012 | Watches
Edward Meyer 31 Day Grandfather Clock manual
I recently bought an Edward Meyer clock from Grandfather clocks for less. The clock is beautiful, but it never chimed. I even took it apart and repaired the chimes, the hammers were too far away from the chiming rods, but now that it does chime, it sounds like someone banging pots and pans together, it's horrible. I've been looking online to find replacement chime and hammer parts so I can fix it myself.
Jan 23, 2012 | Watches
How do I turn off chime?
Hi mfchester,
You can easily change the time of your Timex watch by following the steps below.
1. With the time and date showing, press the top left button.
2. Press the right top button (this sets seconds).
3. Press the bottom left button. This flashes the hour; press the top right button until you have the correct hour (there is no symbol for am, pm will show if pm).
4. Press the bottom left button, minutes flash. Press the top right button until correct minutes.
5. Press the bottom left button, month flashes. Press the top right button until correct.
6. Press bottom left button, date flashes. Press the top right button until correct.
7. Press bottom left button, day flashes. Press right top button until correct.
8. Press bottom left button, time format flashes (can be set to 24 hour clock). If correct, you're done. Press top left button if you're done (can be pressed at any step if you're finished).
To turn off the chime and alarm: Press bottom left until in the alarm screen. Then press the top right button repeatedly until the CHIME or CH symbol is gone and/or ALARM or ALM to disappear, then press the bottom left button to go back to main time.
Hope it helps.
Thank you for using FixYa.
Apr 19, 2011 | Timex 1440 Nylon watch
Kaiser clock model kc-2. The cuckoo doesn't go off on the hour and I want to know how to set it so the cuckoo will go off on the hour.
kaiser clock
Aug 04, 2010 | Watches
I have A 1440 sports watch. I cant get the chime or alarm to sound off.
Hi Guest,
Hope it helps.
Jul 13, 2010 | Timex 1440 Nylon watch
I have an antique clock that requires two places to wind it up. Since Daylight Savings Time went into effect, the clock has gone crazy, chiming the hour on the half hour and chiming three hours ahead. What...
With only limited information provided about your type of actual antique clock this symptom has to conclude that your clock is a non self correcting style.
Step one: Ensure clock is striking the hour. during the time of the hour strike quickly move the minute hand to the hour.
Step two: Move to the half hour allow to strike, move hand to hour allow to strike then move the hour hand to align with the correct count.
Step three: Stop the clock until the correct time has been achieved and start clock OR strike ever hour and half hour until clock is set to the correct time.
Hope this tip guides you to a solution for your clock.
r/ David
http://antiqueclock.clockstop.com/
Apr 06, 2010 | Watches
Timex 1440 sports watch. How do you turn off the chime on the hour every hour?
Hi aburns983,
You can easily change the time and turn off the chime of your Timex watch by following the steps below.
Hope it helps.
Nov 05, 2009 | Timex 1440 Nylon watch
Watches Logo
37 people viewed this question
Top Watches Experts
Jimmy Accardi
Are you a Watch Expert? Answer questions, earn points and help others
