Question about Panasonic KX-TG4731B DECT 6.0 Plus Expandable Digital Phones System with Talking Caller ID and Digital Answering System, KX-TG4731-B, KXTG4731B, KXTG-4731B, KXTG-4731-B, KXTG4731-B
Static on panasonic cordless
Static on both phones
4 Suggested Answers
SOURCE: KX-TG2632 causing static to my baby monitor.
Baby monitors apparently are all on 2.4GHz frequency range. Phones have to be either beneath ie 1.8GHz or above eg 5.4GHz and no interference will occur. So simply had to change the phone because its frequency range was 2.4GHz.
Posted on May 28, 2009
SOURCE: My Panasonic KX-TG2352PW 2.4GHz cordless phone has loud static.
I don't yet have a solution, but I do not want to be obligated to pay for your advice...so I will find another way to solve the problem. Thank you.
Posted on Jan 01, 2010
  • 6771 Answers
SOURCE: static
This can be a tough one, if the phone is moved to a new location without change could indicate a crack in the phone line outside allowing moisture in, more likely when it rains
Posted on Nov 12, 2011
Cordless phones
1) unplug all phones
2) plug them back in and check line.
If you still have the issue,!take a corded phone with. Phone jack coed to your box on the outside of the house. Usually gray, unscrew the first box - you'll see modules there - the one with the last four of your phone number is the module we'll use. Follow the directions on the box to open that module - plug your phone into the module. Here's the important thing - if you don't hear static, then the problem is from inside your house. If you call att to come out they will charge you - but that's the whole unplug the phones and centralize your base better. However, if you still hear static in the outside box, it's an att issue and have to come out at no charge.
Jun 24, 2014 | Panasonic KX-TG1033S Cordless Phone
RE : Panasonic KX-TG6461 I installed this phone
thats an hardware fail , you need a service shop to fix it
Sep 13, 2013 | Panasonic KX-TG6461ET DECT Corded and...
Static
it more than likly operats at the same frequency, move the phone or router to another location
Nov 11, 2011 | Panasonic 5.8 Ghz Cordless Phone System
I am getting static on all handsets. What can I do to stop it?
sounds like it may be your phone lines or loose connection at the base station. buy a cheap hardwire phone to test this if the new phone has static it is your phone lines. if it doesn't have static check the connection to the base station.
Mar 12, 2010 | Panasonic KX-TG9341T Cordless Phone
Jan 01, 2010 | Panasonic Lands Phones
How to get rid of static in phone
read through the instrucyion manual, all cordless phones can transmit to the base on lots of different channels, you may need to reset the channel nuber to a better setting for the base.
Dec 02, 2009 | Panasonic Lands Phones
May 27, 2009 | Panasonic KX-TG2631 Cordless Phone
Static on Telephone Base Unit
Try powercycling the basephone and remove the battery from the cordless phone, wait for 10 sec and then reconnect the battery, after that connect the power to base phone,probably it will fix the issue.if your phone have the option to change the channel,try changing the channel to 11 or 6.try and get it fixed.
Mar 26, 2009 | Panasonic KX-TG1033S Cordless Phone
Static in my panasonic telephones
A possible cause for the static in your cordless phones could be dimmer switches around the area of your phone that causes static. Turn the switches completely off (not just turned down) and see if the static leaves. You can replace the dimmers with regular switches if that clears your static. If it does not, another trace for interference: you will have to take a portable radio and turn it to AM 550 mHz and tune it to the loudest crackling noise. Carry the radio around looking for the loudest static interference. Could be a loose connection in a receptacle or panel box. Any small malfunction can cause static on wireless devices.
Nov 21, 2008 | Panasonic KX-TG1033S Cordless Phone
RCA H5400 Cordless phone
Lots of static when I turn it on. Changing the channels does not work. Having no onother appliance plugged into the outlet doesn't work. Moving it away from other appliances doesn't work. What should I do?
Dec 22, 2007 | Panasonic KX-TG1033S Cordless Phone
Panasonic KX-TG4731B DECT 6.0 Plus Expandable Digital Phones System with Talking Caller ID and Digital Answering System, KX-TG4731-B, KXTG4731B, KXTG-4731B, KXTG-4731-B, KXTG4731-B Logo
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
