Question about IBM NetVista PC Desktop
I was trying to hook up 3 monitors on my dell optiplrx gx620 with a new video card- then i put 2 video card hoping to get 3rd monitor working ---now i dont get any display and alarm sounds when i turn on computer- and it wount boot up.
  • 54 Answers
Take out the two last cards you added and boot again.
Then turn it off and insert only one card at the time to find which one is the faulty.
Good Luck!!!
Posted on Mar 12, 2009
I can't hook my monitor up to my pc I have a dell optiplex gx620 Sff
On the back of your PC there is a blue 15 pin video connection. Connect your monitor to this video connector, power up your monitor the boot up your PC.
Mar 23, 2013 | Computers & Internet
Dell optiplex light turns orange
Does anything ever post on the screen when you hit the power button?
Maybe the monitor is bad or the video card inside the computer is bad. Normally if the video card is bad the monitor will display a message of No Signal. If you are getting no message then I think your monitor is bad. To isolate the problem you need to put another monitor on the computer.
Borrow a monitor from a neighbor, friend, family member or co-worker and connect it to the computer. If the Borrowed Monitor displays and works, then your original monitor is bad. If the Borrowed monitor does the same as the original monitor then your video card is bad.
May 12, 2012 | Dell OptiPlex GX620 PC Desktop
Monitor says no signal and will not run a dvd
It could be a couple of things. If this monitor is hooked up to a computer, it could be a bad video card. A video card is easily fixed on a desktop, if you're using a laptop you're probably out of luck.
If it's hooked up to a DVD player, check that the cord to the monitor is hooked up properly (make sure the connection goes from the "Video Out" on the player to the "Video In" on the monitor and that all connections are tight, not barely hanging on). If that doesn't work, try a new cable.
This is probably insulting, but also make sure that the monitor is set to the right channel if it's multichannel. For example, if your DVD player is hooked up to HDMI 2, make sure the monitor is set to use HDMI 2 for signal.
If none of these work, it's time to find a tech-happy friend that can inspect everything visually. Hope that helps!
Feb 21, 2012 | Dell Computers & Internet
THE LIGHT TURN ON BUT DOSNT DO ANYTHING YOU CANT SEE ANYTHING ON THE SCREEN
do the following 1.check if the monitor power cable is fixed good.
2.try to connect your cpu to another monitor and see if its working.(if it works no prb with the video card else prb with the video card)
3.if your video card is good .then there must be a prb with your monitor a little soldering will fix it !!!
Jun 14, 2011 | Dell OptiPlex GX620 PC Desktop
Whenever the monitor is turned on, it displays for about 3 seconds and then goes black. what to do? It is only about 3 yrs old
One of three things is the most likely culprit.
1. Onboard video card is either disabled or bad.
2. Cable is bad
3. Monitor is bad.
You can check the last 2 relativly easily by hooking the monitor and cable up to another computer to see if they function. if they don't then first try swapping out the cable (i say this first because its cheaper) then swap out the monitor.
To see if the video card is bad try hooking up a different monitor to the system. If the new monitor is not displaying anything then you most likely will need to put a new video card in the machine.
Apr 18, 2011 | Dell Dimension 2400 PC Desktop
Monitor changed to yellow colour.... what is the problem...?
Monitors mix the 3 "primary" colours, in various proportions, to produce all other colours.
Mix equal parts of all 3 colours, and you get WHITE.
Mix equal parts of only 2 colours, and you get YELLOW.
So, either:
1. your computer's video-card is not sending the 3rd colour;
2. your video-cable between the computer and the monitor is broken, and is not transmitting the 3rd colour;
3. your video-cable is not TIGHTLY connected at each end;
4. the electronics inside the monitor that SHOULD be producing the 3rd colour have failed.
Try connecting the monitor to a different computer, with the same video-cable. If it works correctly, your video-card is the problem.
Try connecting the monitor with a different video-cable, to see if replacing the cable fixes the problem.
Try connecting the monitor to a different computer, with a different video-cable. If it still is incorrect, then the monitor needs repair/replacement.
Jan 14, 2010 | Computers & Internet
No image on onitor dell desktop -
if you have no image on the monitor when you hook monitor to other pc and you installed the video drivers for monitor and still no image then you got either a bad power cable for your monitor or your monitor is shot...get a new monitor... try testing again with a different power cable... if still the same... then monitor is shot... replace it...
Dec 22, 2009 | Dell Dimension 3100 PC Desktop
I want to run 3 monitors on my dell vostro
Couple of points I’d like to mention. Vostro has two models slim and mini tower. Both of them are mostly similar so this should be applicable for whichever you have.
The default graphics card on the computer is integrated on the motherboard. When you add another video card, say to the PCI-Express 16x slot on the motherboard, this disables the integrated video card.
If the 2 monitors are connected to the video card, both would get display.
When the computer is turned ON, if you plug in the 3rd monitor to the integrated video card, you would not get any display on the 3rd monitor. BUT if you restart the computer with the 3rd monitor plugged in, the computer would give a signal to the 3rd monitor and disable the two monitors connected to the video card. This feature is added on purpose to diagnose any possible video card problems. Eg. Assuming there was a problem with the video card, if this feature were not available you would not get any display on the monitor from any of the ports and you would not be able to diagnose if the problem was with the monitor, integrated video or the video card.
Hope this helps. Please rate your feedback!
Thanks,
VJ
Mar 04, 2009 | Dell Vostro 200 Desktop Computer
Power save mode
What kind of video card do you have?
Jan 23, 2009 | Dell SE198WFP LCD Monitor
Intel 82845G Graphics doesn't support 1680x1050
You also have to install the monitor drivers.
And yes, the drivers directly from Intel will not work. Dell has a perpritory video, and you have to use the Dell Intel drivers.
I've installed a few of these, and I know they will work.
But I had to go with a 1280x1040 setting. It does work, and will fill the entire screen.
Another option is to put in a PCI video card (yes, a full size card will fit in the GX260's) One bonus to that is you can do multiple monitors. I've had best luck in the GX260's using video cards with an ATI chipset.
Aug 14, 2008 | Dell OptiPlex GX260 PC Desktop
IBM NetVista PC Desktop Logo
101 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
