Question about Toro Garden
Is there a belt adjustment for the belly mower?
I bought a brand new belt for the belly mower and it seems to be too loose. It causes the blade to stop. It's a Toro wheel Horse 8-25. Model number is 70044. Serial is 9903139
  • 666 Answers
SOURCE: john deere model 14sb lawn mower repair
Check for bad bearing in clutch immediately, Remove belt, try and turn the clutch pulley if it is hard to turn or feels rough, replace the bearing in the clutch. If you do not replace bearing immediately you will be buying a $300.00 clutch very soon. I know from experience. You possibly have been hearing a loud unusual roar from engine area for awhile and wondered where it was coming from. As these bearing will usually squall a cry for awhile before they die.
Posted on Mar 28, 2009
  • 60 Answers
SOURCE: My Toro mower is 7 yrs old. 3 speeds, blade
I've noticed that when the blade get dull it work harder a cutting tall grass. I just put a new blade on mine and now it runs and sounds like a brand new mower. also if the inside of the deck is coated with old grass that makes a differance too
Posted on Jun 24, 2009
  • 68 Answers
SOURCE: Hello, I have a Craftsman Model 917.377790
Sounds like you lost the drive key out of the crankshaft, it's usually half-moon shaped and keeps the blade hub and the crankshaft turning together, the bolt just holds it all on the end of the crankshaft.
Hope this helps!
Posted on Jul 04, 2009
wadembly
  • 513 Answers
SOURCE: problem replacing belt on a ols rear engine snapper?
what kind of mower & model # i may be able to help thanks wade
  • 77 Answers
SOURCE: my toro self propelled isn't self propelling
It may just be a matter of adjusting the cable. Sometimes they dont get them adjusted just right from the factory,heres what you do. Locate the plastic shroud in front of the push mower that covers the drive unit.Determine which screwdriver or torx bit is needed to remove shroud and remove it. After removal you will see a pulley with belt around it, as you pull the handle back to engage self propel you should see the pulley move into the belt to put tension on the belt. You can do this with it running to see if enough tension is being put on the belt,if not, locate the cable end where the small bracket holds the cable in place. Loosen the cable bracket and move cable until you have correct tension again,hope this helps.
Posted on Aug 09, 2009
What would cause my mower deck to squeal loudly
Lots of things. Is belt loose? Wrong belt? Bad idler pulley? Bearing? Some decks have a brake pad that contacts against a pulley to stop blades when they are disengaged. May be out of adjustment. Just have to check and locate bad part or a rubbing condition. Is deck installed properly? Good luck in your search. You will find it! I would look for a belt problem. Loose, wore out, or installed wrong.
Aug 15, 2014 | Garden
Blade not cutting. How can I adjust? Craftsman model 358.796480
When the blades are engaged do they turn? It could be a belt is loose tha causes the blades not to spin. Check the handle that engages the mower deck to see if it goes into the proper slot which would cause the blades to spin.
May 18, 2014 | Garden
How to adjust a loose mower deck drive belt?
check your pulleys to make sure they haven't split as this does happen. Adjust the belt tensioner to tighten the belt when you engage the clutch to drive the mower. You should be able to see the belt tensioner by dropping the cutting deck to its lowest point and looking underneath the mower to see which pulley actually puts the tension on the belt to make it drive. there is no need to start the mower to find which pulley needs to be adjusted, it should be obvious when you look at the belt and the pulleys.
Hope this helps you
May 17, 2014 | Garden
Why does my blade drive belt on my riding mower not stay tight
You likely have a bearing going bad causing the belt to slip and wear out, or you are not getting the adjustment tight enough. (most use springs these days)
May 15, 2014 | Craftsman Garden
Husqvarna too slow when mowing
Some self-propelled mowers include a speed control, but sometimes it may seem that no matter how you adjust it, the mower just creeps along at a snail's pace. Most likely this isn't a mechanical malfunction, but an adjustment is probably needed.
Very tall or thick grass can bog down a self-propelled mower, but adjusting the height of the blade may allow it to roll through and cut the grass at normal speeds. If the blade is low, the amount of cutting required may slow down the movement of the entire mower. The frame of the mower may also stick in the high grass. Raise the blade little by little until the mower rolls at the appropriate speed. Going up hills may cause a similar response.
It's possible the drive belt on the mower can slip. Inspect this part to see if it is loose or cracked, and replace the belt to restore power.
May 08, 2012 | Garden
Having a hard time keeping the blade belt on , im not sure if it was ran right in the first place , cant seem to find a diagram for the blade belt . can you help ?
A diagram will be on the belly of the mower. If not the owners manual will have it. If not available they are on the web to view for free. Just google the make and model number to finf it
Mar 24, 2011 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Problem replacing belt on a ols rear engine snapper?
Jun 22, 2009 | Garden
Lawnmower loses power when I engage blades
This is most likely a belt problem. Check the deck drive belt that runs from the mower deck to the engine it/s come loose and got stuck between the guides.
Mar 15, 2009 | Garden
Garden Logo
Top Toro Garden Experts
Jim Parker
Jim Parker
Joseph Mueller
Joseph Mueller
lnbn1975
Are you a Toro Garden Expert? Answer questions, earn points and help others
